 Post subject: Fujitsu MJA2320BH always BSY but normal sound
PostPosted: October 4th, 2012, 6:13
I have a Fujitsu MJA2320BH with a strange problem. The disk spins up, I can hear heads moving to platters and then it doesn't click or make any strange noise. It sounds like a functional HDD. But it always remais busy, it doesn't come ready and so it doesn't ID.
This disk comes from a notebook PC that fell down from few centimeters....
Maybe heads are damaged even if hdd sound is normal?
Simone
 Post subject: Re: Fujitsu MJA2320BH always BSY but normal sound
PostPosted: October 4th, 2012, 15:31
Dipende.
Se hai PC3000 puoi diagnosticarlo con quasi certezza.
It depends.
With PC3000 you can diagnose it with almost 100% certainty.
PostPosted: October 4th, 2012, 15:50
PC3K does not support this model
PostPosted: October 4th, 2012, 15:55
DIAGNOSE only 8)
PostPosted: October 5th, 2012, 4:36
Did you try to diagnose it via terminal (as a Toshiba drive)?
PostPosted: October 8th, 2012, 9:20
Yes, I tried to diagnose it with terminal, using pc3k fujitsu terminal adapter, but I can get no output.... what could be the reason?
