 Post subject: WD Elements 1 TB external USB2 drive dead !!!
PostPosted: October 8th, 2012, 11:53
hi,
My WD elemenst external USB 1 TB drive is dead, it not recongized anymore. I tried changing the USB adapter & the USB cord also.
I even checked on different laptops, operating systems also still no luck. When i start the drive i hear 10-12 times access sound and after that it just dies. I even tried the Freezer solution still it wont detect and start.
Can anyone help,Can i manually repair it is possible?
 Post subject: Re: WD Elements 1 TB external USB2 drive dead !!!
PostPosted: October 8th, 2012, 13:07
This one most likely has bad heads and now with the freezer antics you have possibly destroyed the platters and data. Send it a pro for a quote this one is NOT a DIY recovery job.
PostPosted: October 8th, 2012, 16:33
+1 for heads
http://www.rescue-it.se
PostPosted: October 8th, 2012, 17:08
Freezer "solution" :shock:
Yeah, right!!
PostPosted: October 9th, 2012, 2:29
A simple search in this forum would reveal that the freezer "trick" is an urban legend that never worked for anyone.
