WD Hot Swap doesn't work
October 11th, 2012, 21:15
Hi Guys,
I have a case where a WD2500AAJS-00B4A0 would not come ready but it sounds like the heads calibrating properly.
I managed to access the SA with manual load and copy the ROM and test the heads - the heads seems to be fine so i assume it is a FW issue.
So I got an exact donor, same model, same ROM, same PCB and did hot swap following the instructions of the attached document, I did exactly as told in this document attached but I can't get access to the data area of the patient drive all 6666.
Any suggestions?
Thanks,
Oded
Hotswap.zip
(2.45 MiB) Downloaded 240 times
Re: WD Hot Swap doesn't work
October 12th, 2012, 6:15
Do the head maps match?
How close are the MicroJogs?
Loki
October 12th, 2012, 8:59
The Salvation attachment talks about WD, but shows a Maxtor drive.
You need to back up more than P-List & G-List to the hot swap donor. Like all the tracks.
Their advice is bad and doesn't work with this model. Big surprise.
