 Post subject: Swap platter or replace head?
PostPosted: October 10th, 2012, 14:21
Hi All,
I have a 2.5" HTS725050A9A364 Hitachi TravelStar 500GB that suddenly died with an ominous clicking noise.
After opening the case I see the platter is spinning properly but the read arm continuously cycles across the platter and back to park.
I have another drive exactly the same and plan to use that to recover the data.
I probably damaged the read heads by touching them whilst trying to get it to work and am now wondering if I should move the new read arm to the defective drive or move the platter from the defective drive to the new drive?
What gives me a better chance of success?
Thanks for your help....
 Post subject: Re: Swap platter or replace head?
PostPosted: October 10th, 2012, 14:33
If you have to ask the question, you need a pro.
PostPosted: October 10th, 2012, 16:30
Ditto
PostPosted: October 10th, 2012, 16:49
Why do so many people want to "swap platters"??? :shock:
Data Recovery Cape Town
PostPosted: October 10th, 2012, 16:52
Trolls
PostPosted: October 10th, 2012, 17:52
You don't know? Platters swap is heal-all for any HDD disaster ;)
PostPosted: October 10th, 2012, 18:33
Nick_CT knows very well, his question is valid.
PostPosted: October 10th, 2012, 22:47
That advice is in the same manual that tells you to freeze a failed drive after hitting it with a hammer . . . :D
http://www.datasaversllc.com
PostPosted: October 11th, 2012, 3:31
I know that. Just joking :)
PostPosted: October 11th, 2012, 6:16
If hdd have 1 plater, better change plater or head stack assembly ?
Head with parking zone
PostPosted: October 11th, 2012, 6:48
As Luke said
"If you have to ask the question, you need a pro. "
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: October 11th, 2012, 10:20
Just Curious,
Practicing head / platter swaps. If a drive has one platter and heads are on a parking ramp. From a physical point of view (and assuming the donor is a match) it does seem easier to carry out a platter swap and use original PCB rather than to risk damaging heads.
Or am I missing something.
Logical (still persevering)
PostPosted: October 11th, 2012, 11:44
Logical wrote:
Just Curious,
I changed 2 pieces Samsung spinpoint 1 plater with stick motor (no parking ramp) and read all info at first attempt. But three weak ago with excelstor 80gb this focus dont work :( Or donor mismatch, use 2 donor pieces.
"If you have to ask the question, you need a pro."
What is means?
PostPosted: October 15th, 2012, 18:54
well thanks..... as the drive is a dual platter I swapped the head assembly. Worked a charm.
PostPosted: October 16th, 2012, 3:34
:roll: :serenade:
Users browsing this forum: Google [Bot] and 38 guests
