 Post subject: Another Momentus 5400.4
PostPosted: October 14th, 2012, 12:15
here the log...
Rst 0x10M
(P) SATA Reset
(P) SATA Reset
ASCII Diag mode
F3 T>v4
Invalid Diag Cmd
F3 T>V4
Reassigned Sectors List
Original New log log log phy phy
LBA PBA cyl hd sctr zn cyl hd sctr SFI
Alt Pending Total Alted Total
Entries Entries Entries Alts Alts
Head 0 0
Head 1 0
Head 2 0
Head 3 0
Total 0 0 0 0 0
Total Alt Removals: 0
Checksum = 0000
F3 T>/1
F3 1>N1
F3 1>/2
F3 2>
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Another Momentus 5400.4
PostPosted: October 15th, 2012, 6:15
What I have done so far...
Did SMART RESET,
Power Reset
Glist Clear
Power Reset
Translator Regeneration
Power Reset
V1, V2, V3, V4
Kindly check out the Log file and advice to proceed.
(Exising problem I have been facing - ERROR in each 255Sectors under MHDD and detecting fine with right parameters)
NB: LOAD FROM HDD under HD Doctor produces MOD001, 002 and so on error...
sea.log.txt [374.4 KiB]
Downloaded 601 times
__________
THANK YOU
SHAHI
PostPosted: October 15th, 2012, 6:44
what is the problem? I do not see anything in the log.
EDIT: I see you have given additional info in second post.
PostPosted: October 15th, 2012, 10:25
If this is really Momentus 5400.4, this is not F3 arch.
PostPosted: October 15th, 2012, 14:34
Yes, this is the second post.
check the log ... N1 smart reset deosn't produce any message.
well, let me check instead of F3 also.
__________
THANK YOU
SHAHI
PostPosted: October 16th, 2012, 3:20
It usually doesn't.
I still don't see anything fancy in the log, apart from few entries in the slip list.
Do you have UDMA? This should be easily done with it.
Also, as pointed by freakzy, either this is not a .4 or ...?
Users browsing this forum: No registered users and 49 guests
