 Post subject: Maxtor MaxLine III series: PCB compatibility question
PostPosted: October 13th, 2012, 7:57
I'm having an older MaxLine III SATA drive here (7V300F0, JFTR), which does not contain world's most important data, but WTH, it works 100%, it just needs a kludgy self-made connector thing to "bypass" the broken-off cheap plastic top pieces that hold the connector in place. But as kludges are known for, they are always perfect sources of instability and data inaccuracy, too.
Look, I CAN solder. But only up to a certain extent. There can be cases where it's simply nonsensical to do such attempt (as here as well).
I got pretty surprised when I heard that a totally unrelated drive, the 6V200E0 uses the VERY SAME board as my drive:
Code: VA111630 [N,M,B,A]
PCB ID: 302136100
PDB desc: SABRE-S II/RC_I
Maxtor Corp
( cf. http://pcb-hdd.com/6v200e0-va111630-302 ... p-945.html )
Now to my actual question:
My EAN (barcode) says
ZBDJAKXS * R6GVC * 30066L8JSZ
whereas the EAN on the replacement PCB says
SBBLCACC * R6GVA * 1101603CSU
I'm asking especially because of the R6GVC / R6GVA difference.
What do these codes stand for?
I mean, the PCB ID is still the very same, although these are fairly different drives. (Rule of Thumb: 6..... = DiamondMax series, 7..... MaxLine series).
 Post subject: Re: Maxtor MaxLine III series: PCB compatibility question
PostPosted: October 22nd, 2012, 22:25
http://www.donordrives.com/blog/pcbswapguide
http://www.donordrives.com/hard-drive-p ... swap-match
Users browsing this forum: No registered users and 137 guests
