 Post subject: Would you replace this board?
PostPosted: December 13th, 2013, 19:07
I have a Seagate 7200.12 drive that does not respond when installed. The drive spins up and I can hear brief head movement, but nothing more. The drive PCB has some suspicious traces:
Would you replace this board? What other tests should I perform before dropping money into a new board with flash imaging service?
All the images for this drive are here:
https://plus.google.com/photos/10479056 ... 3ZijhNLDbw
I look forward to your response.
 Post subject: Re: Would you replace this board?
PostPosted: December 13th, 2013, 20:21
PCB is more than likely fine. Typically, these guys have other issues, firmware, read-write issues, bad sectors, etc. Often combination of two or three of these things.
PostPosted: December 14th, 2013, 6:19
Agree, more than likely a FW issue.
Is the drive "seen" correctly in the PC BIOS (i.e. correct model and capacity)?
PostPosted: December 14th, 2013, 6:37
Thank you for the quick reply.
Can it be seen in the BIOS, yes and no.
On cold boot, I can see the drive in the BIOS (it's an ST1000524AS). When I cold boot to openSUSE 12.3, it shows several attempts to initialize fail with the message "ata1: COMRESET failed (errno=-16)" Finally it stops attempting and fails the drive entirely.
If I perform a warm reboot at this point, the drive does not appear in the BIOS and the OS does not attempt (and fail) to access the drive. I can only get the drive to reappear with a hard power cycle.
I have tried to perform a Seagate firmware update from bootable CD. On cold boot the CD gets to the InitDisk message before hanging a very long time. (15-20 minutes seems very long when you've been rebooting the system a half-dozen times. :P) The message unable to read partition table drive 00 sector 0 shows up and repeats itself indefinitely. If I warm boot, the drive again has vanished from the BIOS and the firmware update cannot find the drive.
I have a very similar experience when I attempt to boot SeaTools from CD. Eventually SeaTools always starts and reports that it cannot find a drive.
This entire time, the drive spins up find with almost no head movement. Just a tick when the drive is first powered on. (I suspect it's the drive head unparking, but I'm not an expert on this)
I would agree that this seems to be a firmware problem, but how can it be fixed if the firmware does not respond to any attempt to communicate with it? Any suggestions?
PostPosted: December 14th, 2013, 14:55
If you can obtain a diagnostic report via the drive's serial terminal port, perhaps someone may be able to offer more detailed advice.
PostPosted: December 14th, 2013, 16:08
Yes, a terminal report could be helpful.
Search this forum for details on obtaining or making a serial adaptor.
PostPosted: December 15th, 2013, 3:03
Thank you fzabkar and pcimage. I have learned something new today. I have discovered that drives are smart enough that they allow me to TTY into them. As I haven't been working with storage hardware in any intimate details for years, I would not be surprised to discover that this capability has been around for a while. In any case, I'm geeking out right now.
As my soldering skills are pretty pathetic (D*mmit, Jim, I'm a programmer, not screw jockey!), I have ordered a cable from EBay that should do the trick for me. I expect it next week. I'll be able to post details at that time.
Again, thank you everyone. This has become quite the educational journey.
Users browsing this forum: No registered users and 234 guests
