 Post subject: HDT721016SLA380
PostPosted: October 22nd, 2012, 6:28
I have a HDT721016SLA380 hdd. It start good no knocking sound giving DRD & DSC but not showing in utility. I run utility manually and there I read SA, as it have some corruption. I have attached the SA info.
Any help is appreciated.
HDT721016SLA380.log [2.45 KiB]
Downloaded 521 times
 Post subject: Re: HDT721016SLA380
PostPosted: October 22nd, 2012, 9:18
The follwing is the info readed from the hdd, but no access to it's Mdl No., S/N, Capacity and it's Data.
Module RSVD............................. : Ok
Module USAG............................. : Ok
Module not read (PSHT)
Error : Device error detected (UNC)
Module PSHT............................. : Error
Error : ModStg: composite reading impossible - reading error!
Module RDMT............................. : Ok
Module CNSL............................. : Ok
Module RWCN............................. : Ok
Module CHNM............................. : Ok
Module SRVP............................. : Ok
Module SRVM............................. : Ok
Module ALTC............................. : Ok
Module ZONE............................. : Ok
Module PTRT............................. : Ok
Module RAM0............................. : Ok
Module not read (OVR1)
Module OVR1............................. : Error
Module SMRT............................. : Ok
Module MLBA............................. : Ok
Module SECI............................. : Ok
Module SRIF............................. : Ok
Module SERL............................. : Ok
Module IDNT............................. : Ok
Module DCOT............................. : Ok
Module BULK............................. : Ok
Module PTCH............................. : Ok
Module SSPT............................. : Ok
Module not read (##01)
Module ##01............................. : Error
Module ##02............................. : Ok
Module ##03............................. : Ok
Module ##04............................. : Ok
Module ##05............................. : Ok
Module PESD............................. : Error
Error : Module not read (PESD)
Module SRST............................. : Error
Error : Module not read (SRST)
Module SSSC............................. : Ok
Module SSCD............................. : Ok
Module NVRC............................. : Ok
Modules reading completed
PostPosted: October 22nd, 2012, 14:19
That's going to be a tough cookie with PSHT (plist) damaged :-(
PostPosted: October 23rd, 2012, 8:20
Yes but any other way to access data.
PostPosted: October 23rd, 2012, 14:47
How badly are the copies of PSHT damaged?
You may get lucky and find that it's only "00" padding that's unreadable, so you can make a good PSHT module out of the two.
I'll bet the SA is damaged there too, so you'll have to relocate the SA to a different surface.
Users browsing this forum: No registered users and 77 guests
