WD20EARX-00PASB0
October 23rd, 2012, 14:49
I have a WD20EARX-00PASB0 with DCM HARNHTJMAB Set 2011 and PCB 2060-771698-002 with bad heads.
I found 2 donors:
SN: WCAZAC988414
Model: WD20EARX-00PASB0
Date: 06 OCT 2011
DCM: HARNHTJCAB
R/N 771698
Product of: Thailand
PCB Sticker: 2061-771698-904 AB
PWB: 2060-771698-004 REV A
and
SN: WCAZAC953267
Date: 06 OCT 2011
DCM: HARNNTJCHB
R/N 771698
I tried to swap heads, from both donors and it doesn't work.
I have swapped back one head kit back to donor and it works fine, so heads are ok.
Also tried a hotswap with DDI and still no go.
What am I missing here?!?!?!
Re: WD20EARX-00PASB0
October 23rd, 2012, 14:55
Map, SA, adaptives...
October 23rd, 2012, 17:21
Must check modules....
October 24th, 2012, 3:07
When you say "it doesn't work" what does it mean?
October 24th, 2012, 3:49
northwind wrote:When you say "it doesn't work" what does it mean?
The disk don't get ID...
October 24th, 2012, 7:21
I have seen a lot of those drives failing because of SA specially P-list. Check modules first.
Good luck my friend
October 26th, 2012, 5:36
Problem solved. :mrgreen:
Disk imaging as we speak.
October 26th, 2012, 7:26
And the fault was...
