Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: Seagate Barracuda 7200.12 320GB
PostPosted: October 28th, 2012, 16:49
Hello everyone,
I got a weired case of the following drive:
Model: ST3320418AS
S/N: 6VM7DWPH
Firmware: CC66
The drive stays on BSY state without making clicking noise or bad sound.
On the terminal (PC3000) I got the following:
Rst 0x10M
SIM Error 2040
No HOST FIS-ReadyStatusFlags 2002A1A5
ASCII Diag mode
I tried shorting the read chanel of the drive than the following steps:
F3 T3>/2
F3 T3>Z
Realsing the short read chanel
F3 2>U
Spin Up Complete
F3 T3>/1
F3 1>N1
After this command I get of the following error:
Init SMART Fail
LED:000000CC FAddr:0024E59
Rst 0x10M
Rst 0x10M
(P) SATA Reset
LED:000000CD FAddr:00258A0F (loop of this error)
So I had to power off and power on the drive.
Than I repait the shoring chanel procedure and followed by this comand:
F3 T>m0,2,2,0,0,0,0,22
Got this:
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 00, Max Certify Rewrite Retries = 0000
LED:000000CD FAddr:00258A0F (loop error)
I reached SA modules through the sys files option
tools->Utility extentions->Hdd resources view and edit
I switched to "System files" and set next to read 2b translator module
Vol 0x03 File 0x028
Succeeded to read that module without any corruption.
Still the drive stays on BSY state.
The drive wasn't dropped to the floor or something.
User Track Slip list:
F3 T>V1
User Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
0 0 0 0 0 0 0 0 0 4 0
Head 0: entries 1 slips 0
Head 1: entries 0 slips 0
Total Entries 1 Total Slips 0
Cheack heads:
F3 T>/7
F3 7>X
Head 00 Resistance 010A
Head 01 Resistance 0174
Any tip/help for that drive?
Best Regards,
 Post subject: Re: Seagate Barracuda 7200.12 320GB
PostPosted: October 28th, 2012, 17:22
N1,,22
help-needed-diagnose-seagate-7200-t23999-20.html?hilit=n1
http://www.salvationdata.com/blog/how-t ... -problems/
PostPosted: October 28th, 2012, 17:30
I got an identical case on Friday - 7200.12 ST3250318AS
Rst 0x08M
SIM Error 203F
BSY and have terminal access. Heads and PCB are good.
Good luck! :D
Data Recovery Cape Town
PostPosted: October 28th, 2012, 17:52
Rst 0x08M
SIM Error 203F
Good luck! :D
Thank you for the tip, are you sure about that eventhough the drive couldn't clear the S.M.A.R.T and rebuild the translator?
By the way, I p.m you.
PostPosted: October 28th, 2012, 19:43
I noticed that pressing Ctrl + v on the terminal gives those different options (by every single press)
Ctrl + v
EchoInterfaceCmds: On
EchoBackgroundActivities: On
Ctrl + v
EchoInterfaceCmds: Off
EchoBackgroundActivities: Off
Ctrl + v
Ctrl + v
What option shold I choose?
PostPosted: October 29th, 2012, 3:51
The case I mentioned was solved by clearing g-list and regenerating translator.
F3 T>i4,1,22
F3 T>m0,6,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewrite Retries = not supported
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Zone re-format was skipped.
F3 T>
Rst 0x08M
(P) SATA Reset
Repower of drive and LBA access was restored.
Be careful and good luck.
PostPosted: October 29th, 2012, 5:08
In order to avoid
Init SMART Fail
we should clear first G-list (V4)
Is this correct Nick_CT ?
PostPosted: October 29th, 2012, 6:52
F3 T>i4,1,22
F3 T>m0,6,2,,,,,22
F3 T>
Rst 0x08M
(P) SATA Reset
F3 T>i4,1,22
F3 T>m0,6,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewrite Retries = 2DF8
(loop message)
PostPosted: October 29th, 2012, 7:23
Next step that I would try would be to clear SMART from 'user commands' menu (not via manual terminal commands).
PostPosted: October 29th, 2012, 8:47
F3 T>/1
F3 1>N1
Init SMART Fail
Rst 0x10M
SIM Error 2040
ASCII Diag mode
PostPosted: October 31st, 2012, 17:45
But Nick, if the drive stay in bsy it can't perform a smart clearing
PostPosted: August 21st, 2013, 11:55
Seagate ST3320418AS burnt PCB
we have an hdd with burnt inductor/s on pcb.
does anyone knows how to respolve this problem?
tks and brgds
ephraim
PostPosted: August 21st, 2013, 16:47
This has been covered ad infinitum at Seagate's forum.
PostPosted: August 21st, 2013, 23:40
hello fzabkar
i saw the article on seagate site. sorry but it's not clear to me. especially the 1st option.
can u add more info?
tks a lot
ephraim
PostPosted: August 23rd, 2013, 2:12
hello
can anybody helpp with this issue.
we were looking at seagate site. very poor help from there
tks a lot
ephraim
PostPosted: August 23rd, 2013, 2:29
You might get better help by not hijacking year old posts.
PostPosted: August 23rd, 2013, 3:52
thatdellguy
if u have nothing to say, then don't.
PostPosted: August 23rd, 2013, 4:55
Seems like I had something to say. Just trying to help.
PostPosted: August 23rd, 2013, 6:34
i am only waiting for technical assistance.
ephraim
PostPosted: August 23rd, 2013, 15:59
ephraim2 wrote:
hello
Numerous novices at Seagate's forum have been able to solve this trivial problem with a bit of wire by following the instructions and photos that were provided. Someone who has done a hundred head swaps (as stated by you in 2010) should have no problem understanding such a simple task. If you really can't handle such a job, then send your PCB to a supplier who will transfer the flash memory for you for free. That should cost you $50 at most.
Otherwise, if you have a photo, then I'd like to see it. And this is the second time I'm asking you for it.
Users browsing this forum: Google [Bot] and 49 guests
