 Post subject: enclosure for Fujitsu MHT2060AT
PostPosted: October 28th, 2012, 23:38
Good day all
I have an externat drive as follows:
Brand Fujitsu
Model MHT2060AT
Part No. CA06297-B306
Firmware No. 07C5-0022
Rev. No. A [double line over 0 1 2] 3 4 5 6 7 8 9
PCB No. CA26325-B17204BA
this drive is giving me a hard time! The drive itself is in an external enclosure connected to the computer with a data USB cable and a power USB cable
when I plug the USB data cable AND the USB power cable (3.5 mm male barrel plug), the drive is not spinning, no light is lit on the drive/enclosure and obviously it is not recognised by the computer. Moreover it crashes the computer quite often.
when I plug only the USB data cable (no power cable), the drive is spinnning, the drive is recognized by the computer and I can read the drive with Windows Explorer although it is very very slow.; also te drive is clicking!
I was told the problem may be due to the enclosure interface, and not to the drive itself.
could anyone confirm this diagnistic? and indicate what type of enclosure I need to purchase to access the data on the drive (SATA, IDE, etc..)
thank you so much
 Post subject: Re: enclosure for Fujitsu MHT2060AT
PostPosted: October 29th, 2012, 3:53
If you want to eliminate power as an issue, then buy an enclosure that is powered from an AC adapter.
PostPosted: October 29th, 2012, 18:31
Dear fzabkar
could you make a recommendation as too what type of enclosure would be compatible with my HD
thanks
PostPosted: October 29th, 2012, 19:15
Dear fzabkar
My HHD drive is a 2.5" drive. three are thousands of enclosures on Ebay for 2.5" drive, but none with a A/C adapter. all the drive with a/c adapter are 3.5". So it seems I have to stay with a USB powered enclosure. Again, could you indicate what type of enclosure would be best suited mor my drive.
thanks
PostPosted: October 30th, 2012, 5:01
yvoneg wrote:
Dear fzabkar
thanks
Something like this works both with 2.5 and 3.5 sata drives: http://www.newegg.com/Product/Product.a ... 6817182221
Users browsing this forum: labtech and 48 guests
