 Post subject: wd800jb replacement
PostPosted: October 25th, 2012, 11:21
I have a WD800JB-00CRA1 that is not anymore visible in the bios.
I tried a pcb from an WD600BB-00CAA1 and the drive became visible.
Can I use this pcb with some adjustments?
 Post subject: Re: wd800jb replacement
PostPosted: October 25th, 2012, 15:31
What are the PCB numbers for the original and donor PCBs?
PostPosted: October 25th, 2012, 17:56
pcb number from 80gb: 2061-001102-300B
pcb number from 60gb: 0000-001092-300J
When I use the 60gb pcb on the 80gb disk i can see the directory structure (in TestDisk), but not the files in the directory's.
A scan (with TestDisk) results in bad sector reading.
PostPosted: October 25th, 2012, 18:06
Interesting that the folders are seen with donor board. It seems the ROM adaptives are close enough that it's reading. I think the problem now is bad sectors and partition corruption. The best step is to make a complete image of the drive, then scan that image using R-Studio, or similar data recovery software. For imaging the drive, you may want to try something like ddrescue.
PostPosted: October 25th, 2012, 18:37
Thank you very much for your answers!
But is it still better to find a pcb from a similar disk (with similar pcb-numers?)?
Or can I use this pcb to salvage data?
(bcometa: i like to send you a pm, but i can't send because to less posts.
If you send me a pm, maybe I can reply on that?)
PostPosted: October 25th, 2012, 18:48
I believe since even if just some of the data on the drive can be read, the PCB must be okay. I *think* (and may be wrong), that if the ROM wasn't compatible enough, NO user data would be accessible.
PostPosted: October 25th, 2012, 18:54
The problem occurred when I connected the drive to an ide-usb-adapter, minutes before it was just running Win + programs fine (as far as I know).
Is it possible that bad sectors and partition corruption is an effect of, for example, high current?
With the problem-pcb from the 80gb the drive was not spinning right, it was spinning on-off on-off with some sounds from the heads.
PostPosted: October 25th, 2012, 19:02
I think it's more likely the ide-usb-adapter messed up the original PCB and perhaps that messed up the partition. The on-off spinning could be symptoms of a "bad pcb." Try the full data recovery scan with some different software tools after imaging the drive.
PostPosted: October 25th, 2012, 19:09
Ok, thank you!
PostPosted: October 29th, 2012, 6:52
There are NOT ROM adaptives for this model! :D
You should know that...
PostPosted: October 31st, 2012, 1:00
According to donordrives.com, a chip swap or firmware adaptation service may be required, for whatever reason:
http://www.donordrives.com/western-digi ... e-pcb.html
Is this an error? :?
Users browsing this forum: Google [Bot] and 227 guests
