 Post subject: Seagate 5400.6 0MB issue
PostPosted: June 26th, 2012, 9:30
Quick question,
Can this be repaired in HD Doctor for Seagate V.5.2 ?
Presume it's translator problem.
Regards,
Chris
 Post subject: Re: Seagate 5400.6 0MB issue
PostPosted: June 26th, 2012, 11:50
Never used SD tools, but it will be a translator issue I agree.
Data Recovery Cape Town
PostPosted: June 26th, 2012, 13:53
There is a "one touch" fix in SD I believe, but it doesn't care about non-resident glists and stuff like that, so might bugger your drive up entirely.
Not used my SD tools in a couple of years.
PostPosted: June 26th, 2012, 13:59
The one touch 'fix' - succeeds, but in fact has done naff all.
Says it all about SD products really.
Chris
PostPosted: June 26th, 2012, 14:12
Is the drive still spinning?
PostPosted: June 27th, 2012, 11:39
Yes the device is still spinning, no noticeable problems. (Apart from the obvious capacity related issue).
Edit: You can write to the disk in HD Doctor.
Not up-to-date with the current terminal commands through RS232 socket - so quite stuck on this case.
PostPosted: June 27th, 2012, 12:17
Hi Possible solution / hit posted on SD forum.
PostPosted: November 19th, 2012, 22:29
if the drive stop to spinning,what 's wrong ? head ?
Users browsing this forum: Google [Bot] and 101 guests
