 Post subject: Apacer AC203 USB disk - windows don't see any data on him
PostPosted: December 1st, 2012, 6:04
Hi
I have external USB Apacer drive size 500 GB, and when I connect him with USB cable (cable with two USB ports) to computer, Windows Explorer shows only the name "Local disk" (before this it was labeled Apacer) and when I open him, there is no data on him, empty. When I go on properties, it shows Free Space 126GB and 596GB of Total size. Acronis Disk Director does not see disk at all. Suddenly it happened. I Changed cable and put him on other computers and it is the same, windows explorer don't see data but see the disk. Like it is empty. I don't want to lose data from him, is there any chance that I resolve this, and if I not, at least I will use some of the tools for recovery of lost data. Before that tool, however, I would like to tried something else to solve this!?
 Post subject: Re: Apacer AC203 USB disk - windows don't see any data on hi
PostPosted: December 1st, 2012, 7:00
Try DMDE.
PostPosted: December 1st, 2012, 8:49
northwind wrote:
Try DMDE.
Ok i will. I already opened the case, removed the disc (it is a Toshiba MK6459GSX disk) and connect it to another USB Hard disk electronics (WD 120 GB) that I have. And with this electronics windows explorer don't see the data, just empty "Local disk" with filled space.
PostPosted: December 1st, 2012, 13:43
Do not try USB interface .
Connect it directly to SATA connector of your PC if you can.
Or put it back into its original casing and run Recovery(DMDE) as suggested by Northwind
Users browsing this forum: Majestic-12 [Bot] and 93 guests
