 Post subject: Lacie Biometric AES Encryption
PostPosted: December 6th, 2012, 8:46
Hi All,
We've just had a LACIE biometric HDD caddy with Samsung 3.5GB 500GB drive through our doors.
The device works fine, therefore I believe the issue is with the caddy itself. I would test this if the client decided to supply a power lead. Therefore we've ordered one but I just wanted to discuss the route to this.
If of course the caddy has failed, I presume there are no other tools that would be available to clear the encryption (HD Doctor?). I presume just as far-fetched would be getting a new caddy and asking the client to reset the encryption with a new print. Then test the other drive?
So if I'm deviating far off course, encryption and me don't get on.
Chris
 Post subject: Re: Lacie Biometric AES Encryption
PostPosted: December 6th, 2012, 9:05
If the client resets the encryption with a new print, you'll never be able to recover the files.
http://www.rescue-it.se
PostPosted: December 6th, 2012, 9:55
That's the all logic about encryption also :!:
PostPosted: December 6th, 2012, 19:29
Had one of these last year and the caddy had failed. From what I recall, we repaired the board instead, a far easier option!
Data Recovery Ireland
PostPosted: December 9th, 2012, 0:01
I think the OP was suggesting that the new caddy and new drive could be used as test subjects for educational purposes. Then any findings could be applied to the patient caddy and patient drive.
Users browsing this forum: Google [Bot], pepe and 100 guests
