 Post subject: Seagate ST31000528AS doesn't work any more. Help me
PostPosted: December 6th, 2012, 18:09
Hi folks,
My hard drive where i have put a lot of personnal data does not work any more
And i would like to know what to do and see if it's possible to recover some data.
That's why I need your help :roll:
The drive is a Seagate Barracuda 7200.12 - 1TB - 3,5"
ST31000528AS
Firmware = CC37
PCB Sticker = 4778K
PCB = 100536501 REV A
The drive is at the origin in an external box (Seagate Expansion)
One day the disk is neither recognized by the Bios not by Windows
When i plugged the drive directly with Sata cable or by USB the drive makes clicking noise
then he shuts down.
I have recorded the sound of the hard drive when I plug it.
(Please read the file enclosed "ST31000528AS.mp3", if the sound is bad tell me and i will retry to catch the sound)
To analyse the issue I have ordered the same PCB in USA (Hdd donor) and I have try the new PCB
The issue is the same.
According to you what the issue come from ?
Head issue, platter issue...
Do you think it's possible to fix it ? just to get my data still inside ?
What do you advise to me ?
Best regards :wink:
Baptiste
File comment: sound
ST31000528AS.zip [514.06 KiB]
Downloaded 505 times
 Post subject: Re: Seagate ST31000528AS doesn't work any more. Help me
PostPosted: December 6th, 2012, 18:27
Bad heads, maybe fixable but not DIY.
PostPosted: December 6th, 2012, 18:28
Duplicate post, sorry.
PostPosted: December 6th, 2012, 18:39
Hi pcimage,
Do you think that's it's head according to the sound recorded ?
How much do you think it's heads ? 90% ? 100% ?
How much a such intervention can cost to me to get the data back ?
I have made an other test with the new PCB i have received from Hdd Donor
I have not noticed but the behavior of the disk is not the same when i plug it (via USB)
With the new PCB the clicking noise are slower
then after the 12 first clicking noise and a quick moment, the drive start again and the motor continue to turn
With the old PCB the drive shut down after the 12 clocking noises
Find enclosed the sound of the drive with the new PCB
What do you think about that ?
File comment: sound with PCB2
ST31000528AS_withPCB2.zip [1.51 MiB]
Downloaded 508 times
PostPosted: December 6th, 2012, 18:46
99% certainly bad heads.
Unfortunately recovery on these with bad heads is very tricky and hence expensive.
I wouldn't expect you'd get much change from €1000
PostPosted: December 8th, 2012, 11:24
Thanks for your analyse pcimage,
As you imagine, i can't spend 1000$ for a data recovery
Any other solution ?
Fridge, shocks...
PostPosted: December 8th, 2012, 13:14
littlesquall wrote:
Fridge, shocks...
None of the above.
If you need the data and can't afford it, best to save the HDD until you can afford it
ACELab partner
PostPosted: December 8th, 2012, 15:50
PM sent.
PostPosted: December 12th, 2012, 17:32
it's very horrible to loose 1Tb of data just for a head pb
and i can't spent 245€ for a repair
i would like just get my personnal photos and videos back :(
PostPosted: December 13th, 2012, 0:20
If it is head problem and require head swap,
then 245€ is a reasonable price .
It is a Pro job.
DIY or cheap alternatives will ruin the drive or make recovery later very costly.
Store the drive properly and get it recovered later when you want and have the resources.
PostPosted: December 13th, 2012, 4:48
Hi sathyan, all
the drive is not mine but to my sister
The issue is that she won't want pay 245€ for a pro repair
So there is no need to store the drive properly.
I will never have the resources to pay a pro job...
I will prefer cheap alternatives to have a chance to get the data back (not all the 1Tb)
but i don't know what can be the cheap alternatives for a head swap
PostPosted: December 13th, 2012, 5:26
PM sent.
245€? The donor part would probably cost 100€ when specific requirements between patient and donor are needed...
PostPosted: December 13th, 2012, 7:53
You forgot the taxes.
PostPosted: December 14th, 2012, 4:00
245€? Is this a joke?
I 'd be very intrigued to see the end result...
PostPosted: December 14th, 2012, 9:22
If the result is good then maybe its time to start out scourcing at these prices :lol:
Loki
Users browsing this forum: Google [Bot] and 49 guests
