 Post subject: Tips or programs to recover hd?
PostPosted: December 9th, 2012, 21:12
Hello friends, I have some HD's to try to "recover" them
Following is the list:
I have 2 that are very slow to start that first part to enter setup takes a while naughty ...
I have one that does not recognize
And I have one that after formatting it erases everything myself ..
I know the Zero Fill, tried to pass these 2 that are very slow but the lock timeout of zero fill.
Already tried passing the hdd regenerator 0.02% and also get that pile of bad blocks ...
Some tips that might solve some friends of hd's?
Thank you!
 Post subject: Re: Tips or programs to recover hd?
PostPosted: December 9th, 2012, 22:20
Do not think any software will be successful in recovering data off the slow drives. Maybe there is a chance for the one that has been formatted, though it depends on how, with what, etc.
PostPosted: December 10th, 2012, 0:00
Thank you!
I think you are trying to repair the Hard disks , not recovering Data from them ???
You may get advise on recovering data from your drives.
But to repair drives , tips or programs wont help , only expensive tools and knowledge.
PostPosted: December 10th, 2012, 2:49
Ditto. Better find someone in your area who has the right gear and knows what to do. If the drives are not devastated (yet) maybe there's a solution.
PostPosted: December 10th, 2012, 5:42
i Agree
Contact Member: Fabio here, very good in such cases
good luck
PostPosted: December 14th, 2012, 20:08
Some model numbers might help ...
