Post new topic Reply to topic  [ 54 posts ]  Go to page 1, 2, 3  Next
 Post subject: Need PCB Hitachi 1TB HDD HDT721010SLA360 P/N:0A38016
PostPosted: March 18th, 2011, 4:04
I need hitachi 1TB HDD PCB
Model: HTD721010SLA360
P/N: 0A38016
S/N: MH2NJ3GK
MLC:BA3013
APR-2009
If you have above mentioned PCB in your stock, plz feel free to contact me at kdhyun@hdec.co.kr
 Post subject: Re: Need PCB Hitachi 1TB HDD HDT721010SLA360 P/N:0A38016
PostPosted: March 18th, 2011, 18:47
Can you describe the failure symptom?
If you have a digital multimeter, one of us may be able to help you repair your board, or at least confirm that the problem isn't elsewhere. Many times the problem is only a shorted TVS diode, in which case it can simply be removed.
PostPosted: March 20th, 2011, 0:14
Thanks a lot, but i try that already. I failed, so i need an other pcb.
PostPosted: March 22nd, 2011, 9:21
I need one as well. Obviously priority should be given to the thread starter.
P/N: 0A38016
S/N: MH3YWLDK
MLC: BA3120
JUN-2009
I don't have specialized tools so i can't ask for support. My HDD just makes some rhytmic and extremely faint click - beep - click - beep sequences with two different tonalities few times, then stops. Doesn't even really spin up.
contact me at astwilightonme[AT]gmail[DOT]com.
PostPosted: March 22nd, 2011, 17:26
It appears that your drive may have a stiction fault, in which case a PCB swap won't help.
See this thread, but heed the warnings:
http://forums.seagate.com/t5/FreeAgent- ... 242#M11384
PostPosted: March 22nd, 2011, 20:15
Thanks for your suggestion, i'll try with a PCB swap first anyway, since it's the less "Invasive" method, then try more extreme methods..
PostPosted: March 23rd, 2011, 2:57
hi,
i have it in stock. please feel free to contact me by email or skype if need. :)
data recovery service[/b]
PostPosted: March 23rd, 2011, 12:22
Hi, Sir, I have this working PCB in stock, pls contact my hotmail if you need it.
Thanks, Eric
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: March 24th, 2011, 7:15
i need a controller card for my hitachi 1 tb hdt721010sla360
P/N 0138016
S/N mr23438p
MLC ba3013
MAR-2009
can anyone help me out, i'm new to this, i don't know exactly what to look for
thanks!
PostPosted: March 24th, 2011, 20:06
tianna_moon, could you describe the failure symptom?
One of us may be able to help you repair your board, or at least confirm that the problem isn't elsewhere.
PostPosted: March 27th, 2011, 22:13
hi fzabkar! well there was actually a problem with the power cable, and one chip (i think its the TVS) on the PCB was burned. smoke came out from the cable and the pc rebooted. i read somewhere that i should find a PCB that has the same first two digits with mine and then replace it. is this true? thanks a million!
PostPosted: March 28th, 2011, 1:09
I believe you will need to find a compatible board and then also transfer the NVRAM chip from patient to donor. However, if the problem is restricted to a shorted TVS diode, then just remove it with flush cutters.
The usual culprit (12V TVS diode) is identified in this photo:
http://www.media-itservices.com/burned1.jpg
The drive will work without the diode, but it will no longer have overvoltage protection on the +12V supply. The other large diode is the 5V TVS diode. You can replace the 12V TVS with an SMBJ12A, and the 5V TVS with an SMAJ5.0A. Both are available from Farnell, Mouser, Digikey.
Some light reading ...
Hitachi firmware repair important basics:
http://www.datarecoverytools.co.uk/2010 ... nt-basics/
Hitachi data recovery tips you must know :
http://www.datarecoverytools.co.uk/2009 ... must-know/
How to diagnose and repair Hitachi hard drives:
http://www.datarecoverytools.co.uk/2010 ... rd-drives/
NVRAM and NVRAM Repair:
http://www.datarecoverytools.co.uk/2009 ... am-repair/
PostPosted: March 28th, 2011, 12:13
ok, here's a picture of the PCB. i just noticed that another chip is a bit burnt by the other.
i'm not exactly sure what these two are.
PostPosted: March 28th, 2011, 12:16
and here's the hdd
PostPosted: March 28th, 2011, 12:53
I suspect that you swapped the 5V and 12V inputs. The burnt component is the 5V TVS diode. You can remove it, but be absolutely sure of your power supply.
Good luck.
PostPosted: November 2nd, 2011, 13:57
I think I have a similar problem with the same disk model. I had the HDD in a USB external housing, by mistake, connect the power source of the labtop to the USB external housing, giving over-voltage and amperage.
I bought a hard disk of the same model to take the PCB and put it into the damaged disc. first thing I notice is that the PCBs are not exactly alike.
before changing the PCB, connect the new Harddisk to the PC, the PC recognizes the drive and mount the disk driver but never appears on my pc, I try this is another PC with the same result. this makes me think that the disc is not quite right.
I take the new PCB and place it in the old HDD. then, when I turn on the PC, it shows an error message when loading the disk, before load the operating system.
I was so excited about it, not notice that the PBC has a different number after two days, even when the same disc, I guess that this should be the difference in the PBC components.
Here the HardDisk Damaged Data
HITACHI MODEL: HDT721010SLA360
P/N: 0A38016
PCB: 0A29989
http://img585.imageshack.us/img585/7342/img9128d.jpg
http://img228.imageshack.us/img228/4548/img91472.jpg
Here the new HardDisk Data
P/N: 0A38016
PCB: 0A29987
http://img407.imageshack.us/img407/5228/img91272.jpg
other data, I put the new HardDisk on a NAS (D-link Share center 320), in order to see if the disc works. during formatting five error messages are showed. I press "skip and continue". finally finished formatting. Then I tried copying and playing files on the disk and apparently works well, also made Scandisck and SMART Test with the NAS, both result ok.
Returning to the case, after reading this post. try to measure with a tester PCB components damaged. place the tester to measure conductivity. conductivity observed in the components shown in red. these same components in the new PCB show do not conductivity.
http://imageshack.us/photo/my-images/68 ... amage.jpg/
Please tell me what I can do. I do not know electronica, but every time there is a challenge trying to learn as much as possible. I am a chemist and amateur photographers. my best approximation to the electronics was at the university and when I was a child I had an electronic game called "150 in 1" made by RadioShack. :)
I'll go read the post that recommended by fzabkar.
Two questions. I can do with the damaged hard drive?
What happens to new HardDisk?
Best regards.
Cuando todo está perdido............siempre queda una salida.
PostPosted: November 3rd, 2011, 16:21
DaftShoot, remove the 12V TVS diode (L14 marking code), and heed the warnings in this thread. Hopefully that will do it.
Also see http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
As for your compatibility question, I'm not a data recovery professional, but I know that you must transfer the EEPROM ("NVRAM") at location U5 from patient to donor. Among other things, this IC (93C86) holds the location of the System Area which is unique to each drive.
One complication is the fact that one board has an external serial flash memory chip (25P10VP) at location U7, whereas the other incorporates the flash memory within the LSI MCU. I don't know what the requirements are for a match in such cases.
PostPosted: November 8th, 2011, 5:23
Hi people
If some one needs I steel have one of this drives in stock.
P/N: 0A38016
MLC:BA3013
Send me pm if you are interested.
PostPosted: November 11th, 2011, 13:51
please anybody can tell me what are the scuare brown component and what are the LS3 diode in the picture?
saludos
PostPosted: November 11th, 2011, 22:28
saludos
L14 appears to be a TVS diode with a working volage of 12V and a breakdown voltage of 14V.
LS3 is another diode. I don't recognise its marking code, but I suspect that it may be a 3A Schottky rectifier that provides protection from reverse voltages. If so, then it will probably have a reverse rating of the order of 30V or more, in which case it will probably have survived any overvoltage.
The brown components are capacitors. There is no need to remove them. If they test shorted, this will be because the parallel connected diode is making them look bad. After you remove L14, the capacitors should test OK.
Users browsing this forum: No registered users and 201 guests
