 Post subject: Only 801.6GB showing out of 3TB (Seagate 7200.14 ST3000DM001
PostPosted: December 28th, 2012, 11:35
Hi all,
I just noticed that my Seagate 7200.14 3TB drive was only showing 801.6 gB (746.5 GB) out of the entire 3 TB.
Thankfully, I had a RAID 1 setup and my data's safe, so I formatted this drive and it still showed 800 or so GB.
A quick error scan in HD tune showed 100% health, except it only could scan the 800 GB portion of it.
Any ideas what might have happened? Thanks!
Here's some info:
Testing:
Cheers!
 Post subject: Re: Only 801.6GB showing out of 3TB (Seagate 7200.14 ST3000D
PostPosted: December 28th, 2012, 12:47
Most probably your BIOS needs to be updated.
PostPosted: December 28th, 2012, 13:06
It was working fine the past two months... thanks for your reply though!
PostPosted: December 28th, 2012, 13:50
Ah, I think the problem was to the RAID array.
Moved the HD to another SATA port and it showed the full 3TB. Thanks for your help guys!
PostPosted: December 28th, 2012, 16:47
Check the sector size on the SATA port then check it again on the RAID port.
It is probably as Northwind suggests and a problem with BIOS but for RAID card.
https://www.mjm.co.uk/
PostPosted: December 28th, 2012, 17:09
4KB sector formatting, try it on a Visat/Win 7 64bit system and it should see the entire 3TB.
Users browsing this forum: No registered users and 187 guests
