 Post subject: Samsung HM250JI 2.5" "bios not detect"
PostPosted: January 3rd, 2013, 4:44
Helo,
There's an HDD (2.5" Samsung HM250JI) removed from a broken notebook.
When the disk was connected to a PC to extract the information, it started getting hot and it turned out that the 3.3v supply converter is fried. So it was decided to get a donor and swap the PCB. The result - disk is spinning and heads are clicking. The disk now gets hot on the side of the heads only.
Then the magnetic disks were transferred into the donor hdd. It now passes the internal test, but bios would not detect disk and the terminal gives such info:
1.5G Limited
SPW 1.5G Link Ok!
IS=+00000
SO
H: +00000
Ld
SK C: 000019CF
ENG>SRV>
SvoTbl Loaded
BD
Any ideas on how to recover the data from this disk? Thanks.
 Post subject: Re: Samsung HM250JI 2.5" "bios not detect"
PostPosted: January 3rd, 2013, 13:28
Can you explain this part? What exactly you have done?...
www.datarecoveryne.com
PostPosted: January 3rd, 2013, 15:03
This pcb seems to not have external ROM. How do you know the problem was not just about incompatible ROM?
Did you swap the heads already?
PostPosted: January 4th, 2013, 3:53
I think he means he did a platter swap... :shock:
PostPosted: January 4th, 2013, 4:00
I think that's exactly what he did :oops:
Data Recovery Cape Town
PostPosted: January 4th, 2013, 4:01
ow worst then I thought !
PostPosted: January 4th, 2013, 6:57
Yes, I have swapped magnetic disk platters from the non-working disk into the donor disk like shown in this video http://www.youtube.com/watch?v=wgqOcEAdSas, but using plastic instead of metal and gloves.
Donor disk is the exat match of the non-working disk with few months difference between release dates. For me there was more easy to swap drivers than heads as the amplifier of the old heads is bad.
PostPosted: January 4th, 2013, 7:06
This is some crazy logic. Changing the media was a HUGE mistake and you have potentially caused some serious issues in addition to the original fault.
Did you at least read the comments for that youtube video before you copied it??
The hard drive he is using is a hard drive that he is never planning on using again.
absolutely ridiculous. You'd never be able to access your data for so many different reasons...
if you want to see a bunch geeks die of laughter show this to your IT department at work
For me, it seems that the data is not so valuable that you could be so reckless. Trash the disk and cut your losses.
If data is important to you professional recovery is needed to save data, if even possible now, and because of your botched attempt it will not be cheap.
PostPosted: January 4th, 2013, 10:19
OK now I think he's joking.
Users browsing this forum: Google [Bot] and 290 guests
