Terminal log?
January 3rd, 2013, 17:37
I've seen a number of postings asking for the output of a hard drive's terminal log is retrieved and included in postings.
I am trying to recover the data from a Seagate Momentus 4200.3 80GB hard drive and it sounds like it would be useful if I can get the hard drive's terminal log out of it.
I assume that a serial connection needs to be made from my PC to the hard drive, but how do I found out where on the hard drive's PCB the TX and ground connections would be?
I can deal with the other end of the cable, as I've wired up many a modem and null-modem cable in my pre-Ethernet IT days!
Any help with the terminal log would be much appreciated.
Thanks in advance,
Richard.
Re: Terminal log?
January 3rd, 2013, 18:36
These two links can help you for your case.
https://sites.google.com/site/seagatefix/
seagate-terminal-commands-t6411.html
Good luck for your experiment.
Hope u success.
