 Post subject: WD10EADS strange bahaviour
PostPosted: January 8th, 2013, 11:52
Hi
I've got one of those (NTFS fmt, 2 partitions)
When scanning in MHDD or cloning (ddrescue) it runs at 100-60 MB/s.
While opened in Win or Ubuntu becomes very very slow - avg.transfer 18MB/s (copying big files - 600-1500 MB), seek time - infinity (opening partition takes 20-30 sec).
Any ideas ?
data recovery Poland
 Post subject: Re: WD10EADS strange bahaviour
PostPosted: January 8th, 2013, 12:15
When you are transferring at slow speed, how is the drive connected to the system and to what are you transferring to? How are you copying 1.5TB files from a 1TB drive?
File system transfers will always be slower than sector level transfers. If you have a lot of files on the drive, the MFT table could be large and take longer to load, as well.
PostPosted: January 8th, 2013, 17:20
@ lcoughey: I think it is 1.5Gb :wink:
@ laptokowiec: could be a firmware issue.
http://www.rescue-it.se
PostPosted: January 9th, 2013, 10:23
It's 1,5GB like mr_spokk noticed.
It's connected through sata.
While copying it looks like it transfers some amount of data then stops/waits (for a few seconds) and again transfers next portion
PostPosted: January 9th, 2013, 10:50
I would suspect firmware issue as well
PostPosted: January 11th, 2013, 6:41
Have they (WD) released any firmware upgrade like Seagate for .11 ?
PostPosted: January 11th, 2013, 8:04
laptokowiec wrote:
Hi
Any ideas ?
Firmware, heads or logic board failure. Or a blended problem.
I would check each separately and also on different environment.
P.S. NTFS/MFT is not the culprit as the same problem comes out while scanning with MHDD tht is FS independent !
Users browsing this forum: Rendersmith and 61 guests
