 Post subject: Western Digital WD5000LMVW
PostPosted: January 12th, 2013, 13:31
Hello
Have a WD5000LMVW USB 3 drive. Does anyone know which pins are TX and RX? Have PC3000 but not come across one of these before.
 Post subject: Re: Western Digital WD5000LMVW
PostPosted: January 12th, 2013, 14:04
If you can take some hi quality pics of both sides of the pcb & upload them it will be helpful.
Loki
PostPosted: January 12th, 2013, 14:07
kpeddie wrote:
Hello
correction: WD5000KMVW right?
PostPosted: January 12th, 2013, 23:18
Will do but no it is indeed a WD5000LMVW.
Ive previously used the toshiba terminal connector to talk to WD USB drives but no luck with this drive. Its only got a single row of pins and they are surrounded by a plastic lip
PostPosted: January 13th, 2013, 3:54
can u upload clear image of pcb here?
something new really
or the link of this product in WDC
thnx
PostPosted: January 13th, 2013, 4:22
The COM adapter Samsung completely generic!
Figure: Samsung COM adapter to rely on the left side of the bottom pin is inserted! ! !
PostPosted: January 13th, 2013, 15:47
this is some how bad quality image, cannot read the pcb #
not even by googling
got only this WD5000LMVW-11CKRS0 with no CLEAR image really
PostPosted: January 13th, 2013, 15:57
WD My Passport Edge - heheh
Damn new
thnx i got it
PostPosted: January 14th, 2013, 3:20
The camera is not very clear
PostPosted: January 14th, 2013, 4:32
it will not work this way, totally Diff.
and you may ask the TS about that
good luck
PostPosted: January 14th, 2013, 10:50
Hope this helps
PostPosted: January 7th, 2015, 12:43
Just came across my own post regarding a SATA board for this. Anyone know what SATA board might work with 2060-771859-000? Its a WD5000LMVW-11CKRS0
PostPosted: January 7th, 2015, 14:01
That's a new board if I've seen one. I'd love to know what family it is if you manage to get terminal access to it.
PostPosted: January 7th, 2015, 14:06
I would try a Firebird board 2060-771823-000
Has the same IC, and I think the same MC.
PostPosted: January 7th, 2015, 14:09
Only issue I see is that the 2060-771823-000 board uses a different U12 chip.... so soldering might be an issue if you can't get terminal access... perhaps they've caught on to our methods and are making this more difficult.
PostPosted: January 7th, 2015, 15:21
The 771852 SATA PCB appears to use the same 88i9346-TFJ2 MCU and Nautilus motor controller.
http://ep.yimg.com/ay/yhst-44463692235217/771852-3.gif
http://ep.yimg.com/ay/yhst-144375849714 ... -001-9.gif
PostPosted: January 7th, 2015, 21:18
ill have a look to see if I have those here and report back if it works! might have a go at tracking tx and rx pins as well
PostPosted: January 14th, 2015, 12:34
pins are same as usb2 WD drives
I have terminal access with :
USB GND RxD TxD
___ I I I I I I
And PCB 771931 & 771959 seems to work for other users (not tested)
PostPosted: January 15th, 2015, 16:24
Did you figure out which SATA board works yet? I just want to update my sticky on this subject: http://data-medics.com/forum/viewtopic.php?f=5&t=13
PostPosted: October 8th, 2015, 8:32
The 771852 board works well with these drives....
