 Post subject: HDDScan SMART Report
PostPosted: January 15th, 2013, 0:20
I recently experience serious system (XP SP3) lags and random high cpu usage. I did a lot of troubleshootings and suspect that my HDD is the culprit.
Can someone please help me to evaluate the HDDScan SMART report?
Thanks!
 Post subject: Re: HDDScan SMART Report
PostPosted: January 15th, 2013, 1:10
Your drive has bad sectors, back up the data if it's important and replace the drive.
PostPosted: January 15th, 2013, 1:15
PostPosted: January 15th, 2013, 1:31
Thanks for your help, I'm just curious about which part of the report shows about bad sectors?
PostPosted: January 15th, 2013, 1:56
005, 197 and 198. There is still hope, anyway, before doing radical action : copy all data to another drive, then ZERO FILL / SECURITY ERASE the drive (WARNING : ALL DATA WILL BE LOST !) then recheck. If the values are now zero, it's OK. If not or the problem re-appears, ask a pro in your area to refurb it (pro gear required).
PostPosted: January 15th, 2013, 2:06
I have reformatted it not long ago (less than 2 months) when I experienced system lags and freezes. So I think I'll just backup the datas and replace it.
Thank you guys~
PostPosted: January 15th, 2013, 2:40
REFORMAT is not ZEROFILL neither SE.
Users browsing this forum: No registered users and 229 guests
