 Post subject: Need help with erasing before an RMA
PostPosted: January 27th, 2013, 18:26
I have a WD 1.5 TB RE4 that I need to RMA.
I want to erase the drive completely before sending it back.
The problem is a full erase using MHDD will take somewhere around 50 hours. Too long. :roll:
I know that I only had about 125 GB of data on the disk.
Would I be safe to run the erase script up until it reaches 125 GB ?
The questions I have are:
When a new hard drive is written to, does it start writing on the first sector and then second and so on?
AND, when an erase program is run, does it start from the same spot, sector 1, then on to sector 2.....?
Thnaks for any help.
 Post subject: Re: Need help with erasing before an RMA
PostPosted: January 27th, 2013, 19:44
Use internal security erase . In this case no more than 4-5 hr.
PostPosted: January 27th, 2013, 20:05
What is "internal security erase" ?
I don't know what that means.
Can you be more specific?
PostPosted: January 27th, 2013, 22:48
You haven't said why you want to RMA the drive, but for some faults then any attempt to erase the drive may be unsuccessful.
To answer your earlier questions:
No, because...
That's actually a question about the filesystem, not about the drive itself, and for typical PC filesystems the answer is "no", which is why you can't just erase (overwrite) the first 125GB and expect to prevent access to your data. Filesystem algorithms are typically (much!) more complex than that, especially if there has been much creation & deletion of files.
I don't currently have time to write even more detailed instructions, but the "internal security erase" suggested by BlackST is more commonly known as Secure Erase (although the (S)ATA command has a slightly different name). There are several different techniques / utilities to (try to) invoke a Secure Erase. Since you're not experienced in this procedure, IMHO the two easiest utilities which I can think of to do this process for you, are to use MHDD in a specific way, not the way you're trying at the moment (note the author of this link ;) ):
errata-mhdd-fasterase-t9867.html
and HDDerase:
http://cmrr.ucsd.edu/people/Hughes/SecureErase.shtml
Both of them are DOS programs which (typically) require the PC's SATA controller to be put (temporarily) into IDE / Legacy / Compatibility mode (whatever your BIOS calls it). I'm guessing you've already done this but, in my experience, HDDerase can be more fussy than MHDD. Remove all drives except the one you are trying to erase.
Hopefully this is enough info to get you started. Good luck but, as I said, there is no guarantee of success, especially for a faulty drive.
Users browsing this forum: Google [Bot] and 85 guests
