 Post subject: Toshiba 2,5" drives
PostPosted: July 7th, 2013, 14:55
Hi
I have 2 Toshiba 2,5" 640Gb drives (don't have the full model here).
One produces loud clicks.
I thought this could be heads or media damage, but I opened the drive and all seems fine.
I made a PCB swap from my second drive to this one and the clicks are very, very low, as supposed to be with a different PCB. This PCB on the second drive, doesn't do the loud clicks also.
I swapped them back again and the loud clicks started again. I now think it's a FW problem, but how to solve it?
The second drive, get's RDY, but it can't be recognized. No clicks. Normal sounds.
Any ideas on how to solve this?
I only have SD tool to work with....
ACELab partner
 Post subject: Re: Toshiba 2,5" drives
PostPosted: July 7th, 2013, 17:52
Drive 1 can be SA / heads , the difference is because different PCBs have different AD.
Drive 2 can be a firmware problem.
SD tools can be a limit...
.... but if you see me online the usual way just ring me let's try some remote magic :D
Users browsing this forum: Google [Bot], grevan and 132 guests
