 Post subject: Samsung 1TB HD103SJ
PostPosted: February 14th, 2013, 9:35
I have damaged the pcb of my Samsung 1TB HD103SJ, as you can see one of the 4R7 coils is damaged.
The best way to fix is probably to replace that coil.
I came across the digikey iste, thanks to this forum, but don't know what type of coil I need to order.
Did a search on coil 4R7 and these are the results, seems like a lot of variations ...
http://www.digikey.com/product-search/e ... 7323?k=4r7
Can anyone help out here?
Best Regards,
Robin.
 Post subject: Re: Samsung 1TB HD103SJ
PostPosted: February 14th, 2013, 10:06
If you have an old hdd laying arround not being used you could check to see if it has an 4R7 you could use?
Loki
PostPosted: February 14th, 2013, 11:03
If I had, would have done that already ...
Problem is on that site there so many different models available of that 4R7 coil, don't know which one to pick
Users browsing this forum: No registered users and 68 guests
