 Post subject: Hitachi HTS545050B9A300 BAD SECTORS
PostPosted: February 13th, 2013, 5:00
Banned User
Hello, i've this 2,5" hdd Hitachi HTS545050B9A300 with a lot of bad sectors at the beginning, look the Mediatools log:
I need to know if this is due to a problem with bad sectors or it may be something else wrong, such as heads or firmware
As you can see by doing a simple subtraction, bad sectors are repeated every 1861 good, this will suggest something to you gurus?
Cloning Drive to Drive Report
Date: Wed Feb 13 08:50:49 2013
----------------- Source Drive -------------------
EBIOS HDD 81h
Model Number     : BIOS Drive (Int13x 81h)
Serial Number    : Unknown
Firmware Revision: Unknown
Geometry:
Cylinders: 60801, Heads: 255, Sectors: 63, Sector Size: 512,
Total Sectors: 976773168  (Size: 488.3 GB)
Repair Geometry:
Total Sectors: 976768065  (Size: 488.3 GB)
Starting Position:
Cylinder: 0
Head    : 0
Sector  : 1
LBA     : 0
Finishing Position:
Cylinder: 464
Head    : 117
Sector  : 25
LBA     : 7461555
MD5 Message Digest for Drive Area:
07A7C8F4CE5EF944F6E244384725A750
--------------- Destination Drive ----------------
EBIOS HDD 82h
Model Number     : BIOS Drive (Int13x 82h)
Geometry:
Cylinders: 121597, Heads: 255, Sectors: 63, Sector Size: 512,
Total Sectors: 1953458176  (Size: 976.7 GB)
Repair Geometry:
Total Sectors: 1953455805  (Size: 976.7 GB)
Starting Position:
Cylinder: 0
Head    : 0
Sector  : 1
LBA     : 0
Finishing Position:
Cylinder: 464
Head    : 117
Sector  : 25
LBA     : 7461555
Completion Time:  2 hours 57 minutes
1607 Sector Read Errors (LBA / Sectors):
23986
25847
27708
29568
31429
33290
37351
39212
41073
42933
44794 / 2
46655 / 2
48516 / 2
52577 / 2
54438 / 2
56298 / 2
58159 / 2
60020 / 2
61881 / 2
65942 / 2
67803 / 2
69663 / 2
71524 / 2
73385 / 2
75246 / 2
77107 / 2
81168 / 2
83028 / 2
84889 / 2
86750 / 2
88611 / 2
90472 / 2
94533 / 2
96393 / 2
98254 / 2
100115 / 2
101976 / 2
103837 / 2
105698 / 2
109758 / 2
111619 / 2
113480 / 2
115341 / 2
117202 / 2
119063 / 2
123123 / 2
124984 / 2
126845 / 2
128706 / 2
130567 / 2
132428 / 2
134288 / 2
138349 / 2
140210 / 2
142071 / 2
143932 / 2
145793 / 2
147653 / 2
151714 / 2
153575 / 2
155436 / 2
157297 / 2
159158 / 2
161018 / 2
162879 / 2
166940 / 2
168801 / 2
170662 / 2
172523 / 2
174383 / 2
176244 / 2
180305 / 2
182166 / 2
184027 / 2
185888 / 2
187748 / 2
189609 / 2
191470 / 2
195531 / 2
197392 / 2
742860 / 2
744721 / 2
746582 / 2
750643 / 2
752504 / 2
754365 / 2
756225 / 2
758086 / 2
759947 / 2
764008 / 2
765869 / 2
767730 / 2
769590 / 2
771451 / 2
773312 / 2
775173 / 2
779234 / 2
781095 / 2
782955 / 2
784816 / 2
786677 / 2
788538 / 2
792599 / 2
794460 / 2
796320 / 2
798181 / 2
800042
801903
2407305
2415088
2416949
2418810
2420670
2422531
2969861
2971722
2973582
2975443
2977304
2981365
2983226
2985087
2986947
2988808
2990668 / 2
2994729 / 2
2996590 / 2
2998451 / 2
3000311 / 2
3002172 / 2
3004033 / 2
3005894 / 2
3009955 / 2
3009960
3011816 / 2
3013676 / 2
3015537 / 2
3015542
3017398 / 2
3017403
3019259 / 2
3019264
3023320 / 2
3023325
3025181 / 2
3025186
3027041 / 2
3027045 / 2
3028902 / 2
3028906 / 2
3030763 / 2
3030767 / 2
3032624 / 2
3032628 / 2
3034485 / 2
3034489 / 2
3038546 / 2
3038550 / 2
3040406 / 2
3040410 / 2
3042267 / 2
3042271 / 2
3044128 / 2
3044132 / 2
3045989 / 2
3045993 / 2
3047850 / 2
3047854 / 2
3051911 / 2
3051915 / 2
3053771 / 2
3053775 / 2
3055632 / 2
3055637
3057493 / 2
3057498
3059354 / 2
3059359
3061215 / 2
3061220
3063076 / 2
3063081
3067136 / 2
3067141
3068997 / 2
3069002
3070859
3070863
3072720
3074581
3076442
3080502
3082363
3084224
5252698
5254559
5256420
5260480
5262341
5264206
5266063
5266067
5267928
5269785
5269789
5273845
5273849
5275710
5279432
5281293
5283154
5285014
5981319
6835759
6837621
6841615
6841682
6843469
6845329
6845336
6847190
6847197
6849051
6849058
6850912
6850918 / 2
6854973
6854979 / 2
6856834
6856838
6856840 / 2
6858694
6858698
6858700 / 2
6860555 / 2
6860559
6860561 / 2
6862416 / 2
6862420
6862422 / 2
6864277 / 2
6864280 / 2
6864283 / 2
6866138 / 2
6866141 / 2
6866144 / 2
6870196 / 2
6870199 / 2
6870202 / 2
6870205 / 2
6872056 / 2
6872059 / 2
6872062 / 2
6872065 / 2
6873917 / 5
6873923 / 2
6873926 / 2
7419386 / 5
7419392 / 2
7419395 / 2
7421247 / 5
7421253 / 2
7421256 / 2
7425308 / 5
7425314 / 2
7425317 / 2
7427168 / 5
7427174 / 2
7427177 / 2
7429029 / 5
7429035 / 2
7429038 / 2
7430890 / 8
7430899 / 2
7432751 / 8
7432760 / 2
7434612 / 8
7434621 / 2
7436520 / 130
7438673 / 8
7438682 / 2
7440533 / 8
7440542 / 2
7442394 / 8
7442403 / 2
7442681
7444254 / 9
7444264 / 2
7446115 / 9
7446125 / 2
7447976 / 9
7447986 / 2
7449837 / 9
7449847 / 2
7449950 / 91
7451920
7451922 / 3
7451928 / 6
7451937 / 5
7451947 / 5
7451956 / 2
7451959
7453897 / 9
7453907 / 2
7455758 / 9
7455768 / 2
7455901 / 70
7455972 / 8
7455981 / 5
7455990 / 5
7457619 / 9
7457629 / 209
7457839 / 8
7457851 / 5
7457860 / 3
7457864
7459480 / 9
7459490 / 215
7461341 / 9
7461351 / 205
 Post subject: Re: Hitachi HTS545050B9A300 BAD SECTORS
PostPosted: February 14th, 2013, 16:44
If it is the same in every area, bad head(s) or drive kicked hard. And game over for Mediatools. P.s. If you continue , the drive will soon get unresponsive completely.
PostPosted: February 15th, 2013, 14:33
Banned User
The drive was inside a notebook which has fallen from the desk.
PostPosted: February 15th, 2013, 16:17
So you know the answer.
PostPosted: February 16th, 2013, 16:12
Spildit wrote:
Bad head/platter.
Drive can read with some heads but not with the others.
If you need the data on the drive, you will have to send it to a pro for the drive to be clonned with ddi (with bad head off) and then head stack replacement must be done and finaly the rest of the drive must be cloned too.
NO.
PostPosted: February 16th, 2013, 16:47
Banned User
I do not need a pro anymore, i was able to get all the important data with winhex (folder pics and desktop), i was lucky that the drive was still detected in windows, even asked me to format it.
I copied the folder i needed, but now i have to check the integrity of data (i'm opening all the pics one by one), until now are all ok. 8)
Users browsing this forum: Google [Bot] and 127 guests
