 Post subject: Hitachi HTS543232L9A300 broken
PostPosted: February 19th, 2013, 14:16
Hi all,
I have a hard disk Hitachi HTS543232L9A300 that suddenly stopped working. I noticed that just doesn't spin anymore.
I unscrewed the PCB and I noticed a burnt chip which, as it burned, stained also the mechanics.
Image Image
I have another hard drive exactly the same model but with different codes in the pcb.
Image Image
I trivially swapped the PCB and, in this way, the hd runs but is not recognized by bios.
I doubt that I will be able to recover the data so I kindly ask you a suggestion of someone (I live in Italy) that can recover data from this hard drive at an affordable price.
Mostly are family files.
Thank you,
armando
 Post subject: Re: Hitachi HTS543232L9A300 broken
PostPosted: February 19th, 2013, 17:01
Hi, contact BlackST he's in Italy:
member5409.html
http://www.rescue-it.se
PostPosted: February 20th, 2013, 4:35
Spildit wrote:
You will need to swap the ROM chip of the damaged board to the new one.
Preferably you will need a PCB that have the same codes on the first 2 lines of the sticker ....
Did you ever REALLY worked with TOW(ADA) in such case ? All the ones that came here had catastrophical failure (mostly from notebook) - still have them as specimen for failure analysis.
And then did heads move / did the drive keep spinning ? 8)
P.S. on these disks playing the "board jockey" without knowing what you're doing is always a REALLY BAD IDEA.
PostPosted: February 20th, 2013, 9:04
I am sorry, I am not authorised to use Private messages.
Did not seem that heads were moving, but the hd was spinning.
Just the time to see that the bios did not recognize it, I turned it off and read this article:
http://www.facebook.com/media/set/?set= ... 3387971584
then I arrived to hddguru.
Dear BlackST,
can you help me?
Currently I have a quotation of 400 euro which is beyond my spending capacity.
Users browsing this forum: Google [Bot], shubhsinghal and 71 guests
