 Post subject: Free harddrive recovery program
PostPosted: February 25th, 2013, 21:58
Hi everyone. I accidently formatted the wrong harddrive today. Does anybody know a free recovery program that I can get online. And if there aren't any for free, what is a good but affordable one. Thanks
 Post subject: Re: Free harddrive recovery program
PostPosted: February 25th, 2013, 23:37
alpianin,
STOP! Before you go any further, make a clone/copy of the hard drive. You already made a serious mistake and formatted the wrong drive. Make a copy of the drive to be recovered and work off of the copy. ddrescue is a decent tool to use to make a copy. You can get it here: http://www.gnu.org/software/ddrescue/ddrescue.html
A program called testdisk may do what you need to do. You can get it here:
http://www.cgsecurity.org/wiki/TestDisk
Both of these programs were originally written for Linux. There is a version of testdisk that will run under Windows. I'm not sure about ddrescue, remember Google is your friend!
How was the format done? What Operating System?
If it was Windows Vista or Windows 7 AND you managed to use the full format (default in Vista) rather that the quick format (default in Windows 7), your data is gone. The full format in both Windows Vista and Windows 7 writes binary zeros to every sector before formatting the drive. See: http://support.microsoft.com/kb/941961. If you used Windows XP, your data is likely to be there.
If the format process took a REAL LONG TIME, hours rather than minutes then you happened to use the full format. OOPS! No hope of data recovery.
Good luck.
TonyC
PostPosted: February 26th, 2013, 0:26
R-studio
PostPosted: February 26th, 2013, 3:24
You should try photorec...just google for it and you will get it...
PostPosted: February 26th, 2013, 4:22
Testdisk
Go online and read the instructions/manual. Make sure you have a second drive to recover to.
Users browsing this forum: No registered users and 111 guests
