 Post subject: WD 5000KMVV 2,5 USB initio
PostPosted: February 23rd, 2013, 5:44
there is a way to find a head's donor for this hdd without spending 270€ ?
it is a 6 heads, 12,5 CM height.
Not a problem to me encryption here, and sata board, just problem with this drives that mostly arrive in lab with heads fucked and some demages on sufaces.
 Post subject: Re: WD 5000KMVV 2,5 USB initio
PostPosted: July 19th, 2013, 3:53
What is the full model of the hard drive?
FYI 5000KMVV series hard drives around $200 in USA market. I'm pretty sure for another $20-30 they will ship it to you
Think before you act => Most of the time there is only one chance for recovering lost data !
PostPosted: July 19th, 2013, 3:57
You could try sourcing it based on the model of the enclosure. Often its the same or a compatible donor, but its not guaranteed.
Will be much cheaper to source from this
PostPosted: July 19th, 2013, 9:10
I just purchased one based on the model of the enclosure. $70+shipping. Expecting to arrive to see what the enclosed drive is and if it is compatible with mine.
I found other donor as well, so it is not big deal in this case.
Users browsing this forum: No registered users and 160 guests
