 Post subject: Firmware problem in ST3500418A CC35 and CC37
PostPosted: March 1st, 2013, 12:34
hi. I have two HDD. The A is an Seagate ST3500418AS with CC35 firmware and it works fine. The B HDD is the same ST3500418AS but with CC37 firmware.
The problem is that the B HDD board is burned. So I decided to change the boards. I do this but my PC cannot read the B HDD. The driver spin ok but cannot recognized.
So i want to ask:
1.Is the firmware a problem(A CC35 and B CC37) ?
2.If update(CC43) the A HDD and then put the board in B HDD maybe works???
3. Is any other way to solve this problem?My data in B HDD is very important for me....
 Post subject: Re: Firmware problem in ST3500418A CC35 and CC37
PostPosted: March 1st, 2013, 13:07
Unique firmware for each drive, board swaps do not work on these unless you move the rom chip over to the other board too.
Post a pic and we can tell you which one that needs moving
Disclaimer... trying this yourself could cause more damage if you have no idea what you are doing.
PostPosted: March 2nd, 2013, 4:25
This is the boards... Which chip is the ROM???
http://img33.imageshack.us/img33/6114/photopcm.jpg
Users browsing this forum: Google [Bot] and 120 guests
