 Post subject: Seagate ST3160212ACE password locked
PostPosted: February 26th, 2013, 7:18
Hi everyone!
Come to here for free solution on how to unlock this hdd. Drive seems not to support master password. No data on disk.
Password set to high.
I have rs-232 adapter. Tried Sediv to save vendor track, but get error while saving with free version. Connection seems OK, this is what I get in hyperterminal:
F>Interface task reset
1024k x 16 buffer detected
TONKA2 - 1_Disk S.53 01-18-06 13:08
(P)PATA Reset
Master
T>
From what I gathered, there is a free solution. Hope there is someone willing to share. Your help is much appreciated.
 Post subject: Re: Seagate ST3160212ACE password locked
PostPosted: February 26th, 2013, 11:22
Use the search function above.
seagate-non-standard-ata-master-password-t12920.html?hilit=SEAGATE%20Non%20Standard%20ATA%20Master%20Password
PostPosted: February 28th, 2013, 4:46
How do I find First Intf System Cylinder ? Command y is inactive.
PostPosted: February 28th, 2013, 8:35
Can anyone confirm it is my password here:
T>y
PhysCyl GrayCyl
1st Sys Cyl 00015D84 00016FBD
1st 0 Offset Cyl 00015D8E 00016FC7
1st App Code Cyl 00015D9A 00016FD3
2nd App Code Cyl 00015D9C 00016FD5
2nd 0 Offset Cyl 00015DA8 00016FE1
3rd App Code Cyl 00015DB4 00016FED
4th App Code Cyl 00015DB6 00016FEF
1st Adaptive Cyl 00015DB8 00016FF1
1st UsrDfect Cyl 00015DBA 00016FF3
1st Alt Pool Cyl 00015DC2 00016FFB
2nd UsrDfect Cyl 00015DE0 00017019
1st CertCode Cyl 00015DE8 00017021
1st IntfCode Cyl 00015DEC 00017025
1st Intf Sys Cyl 00015DF0 00017029
1st Cert Log Cyl 00015E20 00017059
1st Decay Cyl 00015E96 000170CF
1st SPLASH Cyl 00015EB0 000170E9
Last System Cyl 00015EB1 000170EA
T>/2
2>s17029,00,22
2>r,6,1
Code - FE Track 1806A(17029).0.000 Sns 000 Rty F7FF.40.80FF Rtf 1800 LBA 0D9ED708
2>B480,480
buffer 0480 comparing to 0480 RD:0480:10:00 WR:04C4:10:00
Addr 0 1 2 3 4 5 6 7 8 9 A B C D E F 10 1 2 3 4 5 6 7 8 9 A B C D E F
090000 01007219 19050000 00000000 00000000 00000000 00000000 00000000 00000000
090020 0000FC58 99625191 DC85BD0D C6432790 B57A4928 C4C1B401 0058E68D 31611CD1
090040 E97E0420 2402FFFF 01000000 00000000 00000000 00000000 00000000 00000000
090060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
090080 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0900A0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0900C0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0900E0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
090100 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
090120 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
090140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
090160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
090180 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0901A0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0901C0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0901E0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
090200 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
2>
Or need to change something?
PostPosted: March 1st, 2013, 6:51
Thank you Spildit. I knew you were not so stone hearted as in post #3. :)
- Does G1 work with 7200.9 family? (Is it the proper command for vendor track?)
- Can some kind of hdd error prevent writing buffers back? Because it still shows 01, not 00. If yes, what command to use to find this error out?
Users browsing this forum: No registered users and 112 guests
