 Post subject: st3808110as Fw broken
PostPosted: March 14th, 2013, 4:34
good morning ;
a friend gave me a drive that he was playing the the FW and made the drive unusable, no data is needed .
drive is
seagate st3808110as
fw 3.ahl
drive not detected in bios "and bios hangs when connected"
and terminal showing
Interface task reset
4096k x 16 SDRAM
TONKA2 - 1_Disk M-31 03-22-06 10:53
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)SATA Reset
DiskAccess ReadSector EC=47 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
DiskAccess ReadSector EC=47 at ffffffff.00.022b
Failed sys sect. write! Nwt Er 00 RdWr 1645e.00.022b
DiskAccess ReadSector EC=47 at ffffffff.00.0080
Unable To Load Overlay 01|000A
T>
any way to reuse this drive using terminal ? no data is needed at all .
thank you
 Post subject: Re: st3808110as Fw broken
PostPosted: March 14th, 2013, 5:26
raven4d wrote:
good morning ;
drive is
seagate st3808110as
fw 3.ahl
4096k x 16 SDRAM
Spin Ready
(P)SATA Reset
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
T>
thank you
- highlighted is the key to fix it
- terminal will NEVER solve it w/o the tools & knowing how
good luck
PostPosted: March 14th, 2013, 13:57
No data needed and drive can not longer work after friend played with FW. Do you just want to play around with this and see if you can fix it. No harm done it has already been done before you got this one. If this is a learning experience then it should be fine to do as you wish with this one.
Other wise give up and get a new drive and go forward. There are some who will refurbish drives and maybe you can give it to them for a few bucks and get it back working. Refurbishing drives is a lot cheaper than fixing them and getting data back from them.
Iorana Haraharaini
PostPosted: March 14th, 2013, 16:30
thank you all for the hints ;
the drive is just for tests .
and sorry , i don't have a tool to transfer FW :(
PostPosted: March 15th, 2013, 4:37
check pm
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: March 15th, 2013, 22:58
thank you ..
i had the following
T>
VALID Cert Disk Code Detected - Revision # .0C7
T>i4,1,22
T>Interface task reset
4096k x 16 SDRAM
Spin Ready
(P)SATA Reset
Not Interface Age!
Cert Table loaded
T>/1
1>N1
Can't execute AT overlay calls when cert code is present
smartres.c - ovl L1 failed
1>
now the log is
4096k x 16 SDRAM
Spin Ready
(P)SATA Reset
Not Interface Age!
Cert Table loaded
drive still not detected in bios
PostPosted: March 16th, 2013, 12:08
good evening ;
when i power up the drive it gives
4096k x 16 SDRAM
Spin Ready
(P)SATA Reset
Not Interface Age!
Cert Table loaded
even i didn't call the cert yet
sending ; givving
T>Age=60 Type=00 MxCyl=00000 MxHd=0 MxSct=000 BSz=008M TCode=00000000 ThermFlts=
0000
/1
1>N1
T>N50,,22
Wrong data format. Write Adaptives rejected
Code - FD Track FFFFF(16456).0.1A0 Sns FFF Rty F7FF.50.80FF Rtf 1800 LB
A 0000042E
T>
sending ; again now will give
T>Age=50 Type=00 MxCyl=00000 MxHd=0 MxSct=000 BSz=008M TCode=00000000 ThermFlts=
0000
thank you
PostPosted: March 17th, 2013, 8:07
drive starts like this
4096k x 16 SDRAM
Spin Ready
(P)SATA Reset
Not Interface Age!
Cert Table loaded
T>
drive is still not detected in bios ,and when sending the /1 and N1 command it gives
T>/1
1>N1
1>
thank you ...
PostPosted: March 17th, 2013, 10:40
UNfortunatly , YES
age is 60 after each power off/on
Users browsing this forum: Majestic-12 [Bot] and 43 guests
