 Post subject: ST_31500341AS hear 11 times click sound and spin down
PostPosted: March 12th, 2013, 1:03
Hello guys,
I have problem with my HD Seagate 1500 Gb
my spes HD is ST_31500341AS firmware CC1H
P/N : 9JU138-302
Date Code 10196
Thailand
the story begin with my HD suddently hang when first boot, then i reset still not detected so i push reset again quickly then show can boot failure or something i forgot, then i reset again quickly (i do reset 3 or 4 times) then I can't find my drive any more
and i hear sound like searching position in my HD 11 times (clik), and then turn spin down
when i see in bios
change they name with ST_M13FQBL 1117F38F
in C/H/S   8025 / 16 / 63
cap 4142 MB
when i get in the windows the drive detected with name ST_M13FQBL, but can see anything
my question is,
for some cooling i put 2 fan (8 cm) on the bottom of HD 1.5 T (gap about 1 cm ) does it matter ?
actually damage my HD is on the PCB or on the motor? how to check it to make sure ?
i really really need help
thanks for help
 Post subject: Re: ST_31500341AS hear 11 times click sound and spin down
PostPosted: March 12th, 2013, 2:09
When a drive changes names it is called factory alais. This is not something you can fix on your own without special tools to diagnose the problem on this one. You will need to find a DR company to fix this for you. If you keep messing with this drive and trying to start it again and again you will only damage this more. I would suggest that you stop this one now if you want the data that is one this drive. Other wise if data is not important check date on this and if possible send back for RMA. Other wise buy a new drive and start over again. The answer is if you ask if this one is bug for Seagate No it is not. This is another issue that needs to be address. Cooling this will not bring back the drive at all. Changing out the PCB will not bring back the drive. All attempts to DIY will not bring back the drive. You need help from a person who understand this problem and can properly fix this. We can help by recommending a person in your area if you are interested in finding a good DR company.
Iorana Haraharaini
PostPosted: March 12th, 2013, 2:47
ow.. So my HD really BAD and useless when i swap PCB live
dou you think error of my HD because i reseting a view times with quickly so impact the pre amp of HEAD
Ok..
can you help me by recommending good Data Recovery in my country (I live in indonesia, Surabaya City) ?
thanks
PostPosted: March 12th, 2013, 8:51
hi,
i think you can contact PRODATA here on hddguru, as i know he's DR PRO in your country.
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: March 15th, 2013, 9:13
do you know the address or web ?
or what name in hdguru ? is a prodata
PostPosted: March 15th, 2013, 9:25
member155.html
PostPosted: March 16th, 2013, 2:51
ok.. but prodata is indonesia..
how about msdot that i found i my city
http://penyelamatdata.com/blog/
but that price is high ? :cry:
I think the price is the same as if I bought the parts Professional Hard Drive Platter Swap, Removal, Exchange Tool for 3.5 "and 2.5" and plus i buy same HD and do it my self
what can I do myself platter swap with such a device?
because I think that my HD was corrupted from head & (IC head / Preamp)
if you can do step by step help with youtube videos that I downloaded or is there specific steps that are not visible in the youtube video?
https://www.youtube.com/watch?v=wZ2J_fwGjO0
https://www.youtube.com/watch?v=einbJzULDb4
https://www.youtube.com/watch?v=G1LnLEV-dk4
https://www.youtube.com/watch?v=IIZzZoBtTAo
https://www.youtube.com/watch?v=farfGX7Hysw
PostPosted: March 17th, 2013, 2:55
You do not value your data much at all. Sorry but you will not make it on your own. Many before you have tried and failed and now their drives are in the trash bin or used as door stops. One was smashed with a hammer. Your data your choice. If you can not afford the guy near you then contact the one we said.
Iorana Haraharaini
PostPosted: March 17th, 2013, 4:53
until i read on forum forum like this
now i belive that i can't get my data with do it my self event i have tool, like you said many people fail.
So from now i consider to find who will be help me to recovery my data &, and i have 3 option :
1. msdot (http://penyelamatdata.com/blog/) location in sidoarjo (near my city)
2. PT HDD Studio Data Recovery Indonesia (http://www.hddstudio.co.id) location in jakarta (i must packing my HD to send it )
3. Indonesia Data Recovery (http://www.indodatarecovery.com/web/main.php ) location in jakarta (i must packing my HD to send it )
of the 3 options do you think is the best in saving my HD? are all the same
but for prodata, i dont know whrere
PostPosted: March 17th, 2013, 6:12
Buy the tool and ask youtube (not us) then. You'll discover that between your expectations and reality there is the so-called know how and many details. Good luck.
PostPosted: March 17th, 2013, 14:52
The only one I know on this list is number 2. I would say go with them. But others could know the other ones here but I do not sorry
Iorana Haraharaini
Users browsing this forum: Majestic-12 [Bot] and 77 guests
