 Post subject: usb to sata universal converter ?
PostPosted: March 18th, 2013, 4:02
good morning .
i was thinking of making a USB to sata "universal" adapter , as mentioned here in the forum , to use the USB native drives with my ddi ,
i saw several pinouts for several USB adapters types , but i was thinking .
all usb adapters have the same end to connect to the pc ; located in here
http://upload.wikimedia.org/wikipedia/e ... er_alt.jpg
why not making an adapter that has a female USB connecter of the above end , and have the sata on the other end ?
just a theoretical idea :roll:
what's your opinion ?
thank you
 Post subject: Re: usb to sata universal converter ?
PostPosted: June 27th, 2013, 2:33
I was unable to open your link, please reupload it.
PostPosted: June 27th, 2013, 8:55
Unless you are using the USB Add-On with DDI4, your USB to SATA bridge may not work so well with DDI3 units. If you are thinking about such a bridge, which would be very cool, you may want to correspond with Andrei at DeepSpar. He is a wealth of knowledge and I'm sure that he'd let you know of any hurdles you might encounter on the way.
Users browsing this forum: Google [Bot] and 53 guests
