 Post subject: Restoring apple partition table
PostPosted: March 21st, 2013, 7:39
Hello
I accidentally issued a "clean" command using windows "disk part" against the HDD on which MacOSX was installed. Testdisk using "analyse" command recognizes both hdd partitions on that disk but cant write the partition table - "function write_part_mac not implemented" error.
Please have a look at the partitions found by testdisk:
Unfortunatley, I dont have a working MacOS to try a workaround using pdisk package because if I am not mistaken pdisk is avialable only on MacOS.
I was able to burn a bootable USB with Live Knoppix OS which includes "GNU parted 2.3" package. Would you be so kind please and tell me what commands I have to use to restore my partition table to be able to boot to my MacOS?
FYI: print command output against that disk: unrecognised disk label
Thank you very much for your assistance!
 Post subject: Re: Restoring apple partition table
PostPosted: March 21st, 2013, 11:48
check for backup volume header from end of the disk
PostPosted: March 21st, 2013, 11:53
hddguy, thank you for your reply
can you please specify in details what should I do and what is the workaround that you suggest? how this backup volume header from end of the disk can help me to restore the partition table?
thank you
