 Post subject: wd5000aaks-00c8a0 SPT value
PostPosted: March 21st, 2013, 12:49
I'm looking for SPT value of WD5000AAKS-00C8A0
 Post subject: Re: wd5000aaks-00c8a0 SPT value
PostPosted: March 21st, 2013, 12:53
try the 1290
:wink:
good luck
What tool? If you own the DFL I have seen some posted on the forum there might want to check there. If you own ACE legal UDMA might want to search this forum too. You can also put another drive on your tool and see the SPT value. At one time I started to collect SPT values fro drives. Will check my listing to see if I have this one.
Iorana Haraharaini
PostPosted: March 21st, 2013, 13:09
Dear Einstein9 and Poehere,
thank you for replay. I owe SD and DFL.
BR Jure
PostPosted: March 21st, 2013, 13:50
BR Jure
1) Through your SD from the Nearest Window
2) use the other better (for sure)
3) Good Luck man and your are most welcome... :wink:
PostPosted: March 21st, 2013, 14:23
Dear Spildit,
SPT is sectors per track.
If tool doesent show you SPT, than you need to enter it manualy
Dear Einstein9,
with all respect to you, I don't want to judge any of those tools. Every tool has some pros and cons.
I try with your settings for SPT without any success. I was able to recover some files already, but I want to see, if I can do some more
Thank you Einstein9
BR Jure
PostPosted: March 22nd, 2013, 10:50
jerovsek wrote:
Dear Spildit,
Dear Einstein9,
Thank you Einstein9
BR Jure
Most Welcome,,,
for the SD again, are you an OLD user or New?
coz i saw many LAZY SD developers who ignored MANY MANY bugs i reported in their SD from v4 up till now -----> never been solved
and you may read about it in their forum...
back to your Q again,
you may use the H.S. method with higher SPT (but not less) and it depends from family to another.
i have some records of those based on model/family which i gave you, but this is the closest i found for your case
but i have to ADMIT the DFL works and does much better ( no comparison ) between both as a fact.
and good luck again :wink:
Users browsing this forum: No registered users and 46 guests
