 Post subject: WD1600 not cloning from H1
PostPosted: March 28th, 2013, 11:38
3 head swap with 3 different donors, same results: no SA or DATA area access from H1.
if i put back heads on donor, all heads are perfectly working.
on patient are always working but only 3 heads/on 4.
always same head: #1 is not cloning
drive is not dropped
not bad noises
model: WD1600JD-00HBB0 (eagle)
out of reasonable ideas..
 Post subject: Re: WD1600 not cloning from H1
PostPosted: March 28th, 2013, 11:44
Did you try changing the PCB? Just had a case where we figured it would be heads. After the first PCB swap, the drive detected and read 4 of 6 heads 100%, 1 of 6 was partial and 1 of 6 was not at all. We were thinking we'd have to change the heads, but changed the PCB to another and voila! All but 1 sector read with all heads on.
Ironically enough, we also just finished a project where the tech thought it was a PCB issue and changed the PCB to find they could not read the data...it had lots of head issues that required multiple head changes.
PostPosted: March 28th, 2013, 11:47
@ lcoughey
i forgot to tell that this drive is started by smart hot swap, can't initialize by itself.
the same pcb, by hot swap, can read also from head 1 from the donors.
it's not pcb related for sure.
PostPosted: March 28th, 2013, 12:10
Diagnosis is quite simple: it's an Eagle drive
They can be very picky about heads
PostPosted: March 28th, 2013, 12:18
+1
totally agree with you here
PostPosted: March 28th, 2013, 12:26
i made many eagles and always solved with many many heads swap and fight with customer to make understand overquote.
this one is really in good health, and i don't get the issue.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 39 guests
