 Post subject: How do you connect SAS HDD to Regular Desktop?
PostPosted: April 2nd, 2013, 4:00
One PC crashed (HDD & DATA OK).
The user needs to access data from a regular PC.
As I never worked with SAS/SCSI drives, that's why I need some information regarding these who has experience.
Is there any converter exist for connecting these HDD to a regular Desktop SATA Port?
Is there any RAID card required for mounting these drives?
Is there any tweaking required for accessing data?
Any advice regarding this issue will be appreciated.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: How do you connect SAS HDD to Regular Desktop?
PostPosted: April 2nd, 2013, 4:25
You would need a SAS Host Bus Adaptor. Search Google for 'SAS HBA'
PostPosted: April 2nd, 2013, 4:47
thx for the reply.
Drives were connected to HP Integrated Smart Array P410i/256MB Controller in HP SERVER ML350T
SAS HBA contains multi port? As 2 HDDs were connected to the Server
And, do I need to re-config or something to mound data? or will it be directly accessible?
__________
THANK YOU
SHAHI
PostPosted: April 2nd, 2013, 4:50
shahij wrote:
thx for the reply.
There is no such Plug-n-Play but as always Plug-n-Pray
good luck
PostPosted: April 2nd, 2013, 5:08
einstein9 wrote:
shahij wrote:
thx for the reply.
good luck
It's not my expectation if it's PLUG N PLAY and I don't expect also, To clarify, I need to know if these are or not! :)
Anyway, is it possible to make clone to regular SATA HDD by using SAS HBA for SOURCE: SAS HDD to HBA & to DESTINATION SATA HDD to REGULAR SATA PORT?
__________
THANK YOU
SHAHI
PostPosted: April 2nd, 2013, 5:09
with HBA should be directly accessible, no configuring needed.
Also, SAS HBA will allow connecting of SATA devices so you could clone SAS to SATA with both attached to HBA
PostPosted: April 2nd, 2013, 5:24
Thanks, do you have any recommendation on SAS HBA?
__________
THANK YOU
SHAHI
PostPosted: April 2nd, 2013, 5:29
I have LSI controllers like this one SAS3041E-R. Also I have some adaptec controller also, not sure of model for adaptec card I have
PostPosted: April 2nd, 2013, 5:44
Shahij, the ML350 IS actually a SERVER product so 99999999,9999% you have RAIDed array. BE EXTREMELY CAREFUL with it and when handling the disks, as if you destroy metadata or recklessly tinker with the array it is much more complicated to get out of troubles. Likely they are the 300 GB.
PostPosted: April 2nd, 2013, 5:59
Hi Shahij,
You problabyi need a PCI-X HBA or maybe an PCI-e HBA. I work with same HP ML350
But as say BackST
"BE EXTREMELY CAREFUL with it and when handling the disks, as if you destroy metadata or recklessly tinker with the array it is much more complicated to get out of troubles"
PostPosted: April 2nd, 2013, 6:51
Thanks, searching one locally if available.
Yes, it's RAIDed
Is there any chance the disk info modified while booting up with the CARD only?
Logically I don't think so. If it would be then how would be make further analysis through WinHex or other application? Correct me if I am wrong.
hhddrec wrote:
Hi Shahij,
But as say BackST
I will be careful for sure.
__________
THANK YOU
SHAHI
PostPosted: April 2nd, 2013, 7:49
It depends on HOW and WHERE you boot it up. For sure it is unsafe to directly connect to XP / 7 systems.
If you really want to do something, CLONE the drives onto other and then , externally, rebuild the array and collect data (and good luck !)
Otherwise, if you are not familiar with SAS , with HP ProLiant and associated RAID, it's better either to decline the job OR outsource , rather than having a complete mess.
PostPosted: April 2nd, 2013, 7:58
And again, what RAID level was used?
Don't do anything with original drives, except cloning them sector by sector.
Sure, you will need to find some RAID reconstruction software, if RAID level was not a "mirror".
PostPosted: April 2nd, 2013, 9:10
Don't worry my friend! I learned to avoid further data loss at least in last couples of years.
__________
THANK YOU
SHAHI
PostPosted: April 3rd, 2013, 5:13
boot the server from usb or other sata hdd. ML350 has sata port for the dvd. you can use that sata port. Install P410i/256MB drivers.
Copy the data
Of course if the server works, if not image the hdd to sata then play with them. Hopefully is a raid 1
Misha
Users browsing this forum: fabrimote, Google [Bot] and 113 guests
