 Post subject: Have you seen this codes yet in Terminal 2TB Seagate
PostPosted: April 5th, 2013, 11:04
Boot 0x40M
Spin Up
TCC-001F[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001F
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 0064C1D7
[RSRS] 00CD
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTStateFlags 0000002A MCStateFlags 0000D141
MCMainPOR: Feature Enabled...
Starting LBA of RW Request=0000000000087495 Length=0000010C
ProcessRWError -Read- at LBA 0000000000087495 Sense Code=43110081
Starting LBA of RW Request=0000000000087499 Length=00000108
ProcessRWError -Read- at LBA 0000000000087499 Sense Code=43110081
Starting LBA of RW Request=000000000008749D Length=00000104
ProcessRWError -Read- at LBA 000000000008749D Sense Code=C3160080
Starting LBA of RW Request=00000000000874A1 Length=00000100
ProcessRWError -Read- at LBA 00000000000874A1 Sense Code=43110081
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Have you seen this codes yet in Terminal 2TB Seagate
PostPosted: April 5th, 2013, 11:14
You get ID and Capacity after some waiting?
PostPosted: April 5th, 2013, 11:51
what's the problem with HDD?
symptoms?
PostPosted: April 5th, 2013, 12:02
you have media errors
LBA
87495
87499
8749D
874A1
PostPosted: April 5th, 2013, 13:56
No, READY but LBA 0
symptoms?
Not Detected
LBA
87495
87499
8749D
874A1
thx
here is the FULL LOG
Boot 0x40M
Spin Up
TCC-001E[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
Spin Up
TCC-001E
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 0064C1D8
[RSRS] 00CD
[MCMTWS]
Starting LBA of RW Request=00000000000874A5  Length=000000FC
ProcessRWError -Read-   at LBA 00000000000874A5  Sense Code=43110081
Starting LBA of RW Request=00000000000874A9  Length=000000F8
ProcessRWError -Read-   at LBA 00000000000874A9  Sense Code=43110081
Starting LBA of RW Request=00000000000874AD  Length=000000F4
ProcessRWError -Read-   at LBA 00000000000874AD  Sense Code=43110081
Starting LBA of RW Request=00000000000874B1  Length=000000F0
ProcessRWError -Read-   at LBA 00000000000874B1  Sense Code=43110081
Starting LBA of RW Request=00000000000874B5  Length=000000EC
ProcessRWError -Read-   at LBA 00000000000874B5  Sense Code=43110081
Starting LBA of RW Request=00000000000874B9  Length=000000E8
ProcessRWError -Read-   at LBA 00000000000874B9  Sense Code=43110081
Starting LBA of RW Request=00000000000874BD  Length=000000E4
ProcessRWError -Read-   at LBA 00000000000874BD  Sense Code=43110081
Starting LBA of RW Request=00000000000874C1  Length=000000E0
ProcessRWError -Read-   at LBA 00000000000874C1  Sense Code=43110081
Starting LBA of RW Request=00000000000874C5  Length=000000DC
ProcessRWError -Read-   at LBA 00000000000874C5  Sense Code=43110081
Starting LBA of RW Request=00000000000874C9  Length=000000D8
ProcessRWError -Read-   at LBA 00000000000874C9  Sense Code=43110081
Starting LBA of RW Request=00000000000874CD  Length=000000D4
ProcessRWError -Read-   at LBA 00000000000874CD  Sense Code=43110081
Starting LBA of RW Request=00000000000874D1  Length=000000D0
ProcessRWError -Read-   at LBA 00000000000874D1  Sense Code=43110081
Starting LBA of RW Request=00000000000874D5  Length=000000CC
ProcessRWError -Read-   at LBA 00000000000874D5  Sense Code=43110081
Starting LBA of RW Request=00000000000874D9  Length=000000C8
ProcessRWError -Read-   at LBA 00000000000874D9  Sense Code=43110081
Starting LBA of RW Request=00000000000874DD  Length=000000C4
ProcessRWError -Read-   at LBA 00000000000874DD  Sense Code=43110081
Starting LBA of RW Request=00000000000874E1  Length=000000C0
ProcessRWError -Read-   at LBA 00000000000874E1  Sense Code=43110081
Starting LBA of RW Request=00000000000874E5  Length=000000BC
ProcessRWError -Read-   at LBA 00000000000874E5  Sense Code=43110081
Starting LBA of RW Request=00000000000874E9  Length=000000B8
ProcessRWError -Read-   at LBA 00000000000874E9  Sense Code=43110081
Starting LBA of RW Request=00000000000874ED  Length=000000B4
ProcessRWError -Read-   at LBA 00000000000874ED  Sense Code=43110081
Starting LBA of RW Request=00000000000874F1  Length=000000B0
ProcessRWError -Read-   at LBA 00000000000874F1  Sense Code=43110081
Starting LBA of RW Request=00000000000874F5  Length=000000AC
ProcessRWError -Read-   at LBA 00000000000874F5  Sense Code=43110081
Starting LBA of RW Request=00000000000874F9  Length=000000A8
ProcessRWError -Read-   at LBA 00000000000874F9  Sense Code=43110081
Starting LBA of RW Request=00000000000874FD  Length=000000A4
ProcessRWError -Read-   at LBA 00000000000874FD  Sense Code=43110081
Starting LBA of RW Request=0000000000087501  Length=000000A0
ProcessRWError -Read-   at LBA 0000000000087501  Sense Code=43110081
Starting LBA of RW Request=0000000000087505  Length=0000009C
ProcessRWError -Read-   at LBA 0000000000087505  Sense Code=43110081
Starting LBA of RW Request=0000000000087509  Length=00000098
ProcessRWError -Read-   at LBA 0000000000087509  Sense Code=43110081
Starting LBA of RW Request=000000000008750D  Length=00000094
ProcessRWError -Read-   at LBA 000000000008750D  Sense Code=43110081
Starting LBA of RW Request=0000000000087511  Length=00000090
ProcessRWError -Read-   at LBA 0000000000087511  Sense Code=43110081
Starting LBA of RW Request=0000000000087515  Length=0000008C
ProcessRWError -Read-   at LBA 0000000000087515  Sense Code=43110081
Starting LBA of RW Request=0000000000087519  Length=00000088
ProcessRWError -Read-   at LBA 0000000000087519  Sense Code=43110081
Starting LBA of RW Request=000000000008751D  Length=00000084
ProcessRWError -Read-   at LBA 000000000008751D  Sense Code=43110081
Starting LBA of RW Request=0000000000087521  Length=00000080
ProcessRWError -Read-   at LBA 0000000000087521  Sense Code=43110081
Starting LBA of RW Request=0000000000087525  Length=0000007C
ProcessRWError -Read-   at LBA 0000000000087525  Sense Code=43110081
Starting LBA of RW Request=0000000000087529  Length=00000078
ProcessRWError -Read-   at LBA 0000000000087529  Sense Code=43110081
Starting LBA of RW Request=000000000008752D  Length=00000074
ProcessRWError -Read-   at LBA 000000000008752D  Sense Code=43110081
Starting LBA of RW Request=0000000000087531  Length=00000070
ProcessRWError -Read-   at LBA 0000000000087531  Sense Code=43110081
Starting LBA of RW Request=0000000000087535  Length=0000006C
ProcessRWError -Read-   at LBA 0000000000087535  Sense Code=43110081
Starting LBA of RW Request=0000000000087539  Length=00000068
ProcessRWError -Read-   at LBA 0000000000087539  Sense Code=43110081
Starting LBA of RW Request=000000000008753D  Length=00000064
ProcessRWError -Read-   at LBA 000000000008753D  Sense Code=43110081
Starting LBA of RW Request=0000000000087541  Length=00000060
ProcessRWError -Read-   at LBA 0000000000087541  Sense Code=43110081
Starting LBA of RW Request=0000000000087545  Length=0000005C
ProcessRWError -Read-   at LBA 0000000000087545  Sense Code=43110081
Starting LBA of RW Request=0000000000087549  Length=00000058
ProcessRWError -Read-   at LBA 0000000000087549  Sense Code=43110081
Starting LBA of RW Request=000000000008754D  Length=00000054
ProcessRWError -Read-   at LBA 000000000008754D  Sense Code=43110081
Starting LBA of RW Request=0000000000087551  Length=00000050
ProcessRWError -Read-   at LBA 0000000000087551  Sense Code=43110081
Starting LBA of RW Request=0000000000087555  Length=0000004C
ProcessRWError -Read-   at LBA 0000000000087555  Sense Code=43110081
Starting LBA of RW Request=0000000000087559  Length=00000048
ProcessRWError -Read-   at LBA 0000000000087559  Sense Code=43110081
Starting LBA of RW Request=000000000008755D  Length=00000044
ProcessRWError -Read-   at LBA 000000000008755D  Sense Code=43110081
Starting LBA of RW Request=0000000000087561  Length=00000040
ProcessRWError -Read-   at LBA 0000000000087561  Sense Code=43110081
Starting LBA of RW Request=0000000000087565  Length=0000003C
ProcessRWError -Read-   at LBA 0000000000087565  Sense Code=43110081
Starting LBA of RW Request=0000000000087569  Length=00000038
ProcessRWError -Read-   at LBA 0000000000087569  Sense Code=43110081
Starting LBA of RW Request=000000000008756D  Length=00000034
ProcessRWError -Read-   at LBA 000000000008756D  Sense Code=43110081
Starting LBA of RW Request=0000000000087571  Length=00000030
ProcessRWError -Read-   at LBA 0000000000087571  Sense Code=43110081
Starting LBA of RW Request=0000000000087575  Length=0000002C
ProcessRWError -Read-   at LBA 0000000000087575  Sense Code=43110081
Starting LBA of RW Request=0000000000087579  Length=00000028
ProcessRWError -Read-   at LBA 0000000000087579  Sense Code=43110081
Starting LBA of RW Request=000000000008757D  Length=00000024
ProcessRWError -Read-   at LBA 000000000008757D  Sense Code=43110081
Starting LBA of RW Request=0000000000087581  Length=00000020
ProcessRWError -Read-   at LBA 0000000000087581  Sense Code=43110081
Starting LBA of RW Request=0000000000087585  Length=0000001C
ProcessRWError -Read-   at LBA 0000000000087585  Sense Code=43110081
Starting LBA of RW Request=0000000000087589  Length=00000018
ProcessRWError -Read-   at LBA 0000000000087589  Sense Code=43110081
Starting LBA of RW Request=000000000008758D  Length=00000014
ProcessRWError -Read-   at LBA 000000000008758D  Sense Code=43110081
Starting LBA of RW Request=0000000000087591  Length=00000010
ProcessRWError -Read-   at LBA 0000000000087591  Sense Code=43110081
Starting LBA of RW Request=0000000000087595  Length=0000000C
ProcessRWError -Read-   at LBA 0000000000087595  Sense Code=43110081
Starting LBA of RW Request=0000000000087599  Length=00000008
ProcessRWError -Read-   at LBA 0000000000087599  Sense Code=43110081
Starting LBA of RW Request=000000000008759D  Length=00000004
ProcessRWError -Read-   at LBA 000000000008759D  Sense Code=43110081
Dither
TCC-0021
ProcessRWError -Read-   at LBA 0000000000004B33  Sense Code=40000087
ProcessRWError -Read-   at LBA 0000000000004B35  Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000004B35!
Seg Read Error at LBA 00000000000259A8
InitiateMarkPendingReallocateRequest for disc_lba: 00000000119F4FD4
(DOS)STE OGHT: 0x0000000000000000 - 0x0000000000000000 - 0x000451EE - 0x0004520C Count 006F
(DOS)CMP Count 006F
(DOS)STE OGHT: 0x0000000005808CDE - 0x000000000580C16B - 0x0000A166 - 0x0000A184 Count 0048
(DOS)CMP Count 0048
(DOS)STE OGHT: 0x00000000019893D6 - 0x000000000198C863 - 0x000031CC - 0x000031EA Count 0050
(DOS) Refresh Start.
__________
THANK YOU
SHAHI
PostPosted: April 5th, 2013, 15:32
It's still media errors.
PostPosted: April 6th, 2013, 2:21
shahij,
The description of this error -
0x43110081: RW_EDAC_HW_UNCORR_ERR - Disc Xfr - EDAC HW uncorrectable error.
