April 20th, 2013, 18:07
When you read by id you read all modules ok from COPY 02
Try to untick "by id" and tick "second copy map"
April 20th, 2013, 18:10
michael chiklis wrote:SA 2nd copy is on head 1?
If i untick "by ID" i get error on head 0 and also head 1
Yes, 2nd copy is head one.
If head 0 is damaged you will get SA access on head 1 (SA copy)
April 20th, 2013, 18:11
Please TEST IT with your good drives.
If you read modules and the copy number is 01 instead of 02 then on this drive, for some reason SA is been read from copy 2
April 20th, 2013, 18:14
Sorry.
Correction
BY ID means By LBA.
W/O road map will read from ID01 dir map.
April 20th, 2013, 18:15
It's normal then. You should check at least one option on that pannel. Either you tick BY Id or you tick w/o road map.
April 20th, 2013, 18:16
I get this error also with good drive
Mariner (Royl) drive
WDC WD3200BEVT-00A0RT0_01.01A01
michael chiklis on April 20th, 2013, 18:17, edited 1 time in total.
You can allways test on a known good drive and compare the differences. This is a good way to learn how the software works.
April 20th, 2013, 18:22
In the module window i see only "02" under copy, also with the good drive
i can't access to copy 01 even in the good drive, because it always show me only 02
could be a software bug or i'm doing something wrong?
michael chiklis on April 20th, 2013, 18:25, edited 1 time in total.
It's normal then.
The problem is not what i stated then.
That copy 02 means other thing and not the head that is reading SA.
Disregard my posts saying that head 0 is bad and SA is been read from copy 2 on head 1
April 20th, 2013, 18:26
Are you able to do modules backup from copy 01 with version 6.0?
April 20th, 2013, 18:32
Spildit wrote:When you read by id you read all modules ok from COPY 02
I tried it, i get still same errors on modules reading
michael chiklis wrote:Are you able to do modules backup from copy 01 with version 6.0?
Yes, if i turn off head 0 and head 1 is good.
I didn't have time to play with it.
April 20th, 2013, 18:33
michael chiklis wrote:Spildit wrote:When you read by id you read all modules ok from COPY 02
Did you try that with good drive to see if it's diferent ?
April 20th, 2013, 18:34
I think my only choice is to try the head 0 depop.
One of this days i will try
April 20th, 2013, 18:36
Spildit wrote:michael chiklis wrote:Spildit wrote:When you read by id you read all modules ok from COPY 02
Yes i just tried few minutes ago on a good drive:
Exactly the same!!
April 20th, 2013, 18:38
michael chiklis wrote:Spildit wrote:michael chiklis wrote:Spildit wrote:When you read by id you read all modules ok from COPY 02
Exactly the same!!
Ok, so it's a software issue.
April 20th, 2013, 18:39
michael chiklis wrote:I think my only choice is to try the head 0 depop.
I think that the bad head was the head 1, right ?
April 20th, 2013, 18:40
I really don't know, head test it's alway good, only once time i had bad report on head 1
P.S.
I just did again head test, again head 1 "bad" reported after i tried 10 times.
Then again all good head
April 20th, 2013, 18:44
Well, did you consider sending it to a real dr pro ?
April 20th, 2013, 18:49
Not an option, too expensive (i need to get only some pics, which are not so important to spend hundred $)
Most of the pictures (about 80% I have recovered from my girlfriend's pc)
