 Post subject: Anyone got this Problem with Seagate 1 & 2 TB`s
PostPosted: April 10th, 2013, 6:27
Dear Experts,
Anyone of you saw those 2 of Seagate, 1TB & 2TB
Problem:
when you partition both into 1/2 capacity, and almost FILL both of them with Data (till almost 97%) of total capacity
in both partitions, all the sudden, one day, the 2nd. partition will DISAPPEAR
and you will have 1/2 Capacity only, which is the 1st. partition only.
so far on the last 6 months, and based on the comments from my clients, i wrote those notes
about each case, and i came across a match in 9 cases so far. (total 1 & 2 TB)
the problem is SOLVED, no issues, but wondering if anyone got the same?
thank you
 Post subject: Re: Anyone got this Problem with Seagate 1 & 2 TB`s
PostPosted: April 10th, 2013, 7:14
einstein9 wrote:
Dear Experts,
Problem:
thank you
Interesting sugestion i'll try it with some ST 1, 2 TB.
But i think is normal because the common fail in this drives is ocasionated by bad managing about bac secs translator and smat. When more data in HDD more bab secs, smart info and so on. In cosecuence more failure probabilityes.
PostPosted: April 10th, 2013, 7:19
which OS did you use to see that partition was gone/hidden?
PostPosted: April 10th, 2013, 7:36
to hhddrec ----->> no relation since drive is NEW is most of the cases
positivebit ------>> Win7 most
thank you
PostPosted: April 10th, 2013, 8:59
Please try with win xp and report here.
PostPosted: April 10th, 2013, 9:40
heheh, my dear not related to OS
the issue is else where
anyway, i got few PM`s n replies about it, crystal clear now
thank you all
case closed.
:wink:
PostPosted: April 10th, 2013, 15:49
Seen none up today, but we have time :D
Any relationship with a particular firmware ?
PostPosted: April 11th, 2013, 4:01
in fact no relation (i`ve checked those FW with their online tool)
but as far as i MIGHT got to know, this might be a factory defect, but really Series Problem if you have some data on it.
:wink:
PostPosted: April 11th, 2013, 4:03
Interesting :mrgreen:
PostPosted: April 11th, 2013, 4:05
To me was different. 2TB seagate manufactured 1 year ago about, full of data ( about 98% )
plugged onto win 7, data was not accesible.
on xp yes.
tested on different machines.
PostPosted: April 11th, 2013, 4:21
on xp yes.
looks like Diff. case scenarios here my dear
cases i got here are totally Diff. than yours.
:D
