 Post subject: ST500DM002 Firmware: KC43 New Problem
PostPosted: April 20th, 2013, 1:08
Hi Dear Friends
Todays I Have Comes Seagate Drive. Here Is The Drive Specs.
Model : ST500DM002
Firmware : KC43
Here Is The Terminal Log:
Boot 0x10M
Spin Up[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
SIM Error 1002
RW Error C4440080
SIM Error 1002
RW Error C4440080
SIM Error 1002
RW Error C4440080
(P) SATA Reset
SIM Error 1002
RW Error C4440080
The Registry is corrupt.
LED:000000BD FAddr:00006454
Any One See This New Problem. If Any One Have Any Suggetion PM Me.
Yours Friend
Jignesh
 Post subject: Re: ST500DM002 Firmware: KC43 New Problem
PostPosted: April 20th, 2013, 11:54
No clicks, no spin down, and stays busy (not getting ready), correct?
PostPosted: April 20th, 2013, 12:18
Hi Dear Friend Labtech
Brother You Are Right No Clicks Its Spin Like Butter No Any Strange Sound And Also Constant Bussy But Terminal Work I Try Some V1,V10,V4 N1 And Clear G-List All Command Excuted Normaly But Nothing Happen. I Dont Apply Any Traslator Command I Want To Sure First What Is The Problem First Then I Decide What To Do. If Any Suggestion For Me Then PM Me Plz.
Your Friend
Jignesh
PostPosted: April 20th, 2013, 12:51
Interesting... I am trying to resolve a similar issue on a different drive.
What to you mean by "Registry is corrupt"?
PostPosted: April 20th, 2013, 23:06
Bro Labtech
I Dont Know What Is The Registry Currupt I Never Seen This Type Of Messege In Any Of My Case This Is Also New Problem To Me.
I Am Trying To Understand What And Where Is This Problem If I Got Sucess Then I PM You How I Solve This Case Bcoz Only You Reply And Support Me Here Other Are Just Reading I Know Some One Know How To Solve This Problem But May Be No One Intrested To Reply My Post.
Its Ok I Will Try It And Pm The Case Studies What I Do And What Happend.
Again Thank You For Participating In My Case.
Rightnow I Have Dout On PCB Bcoz Of SIM Error (SIM = System Information Management) But PCB Swap Nothing Happend So Conform That The PCB Is Ok There Is No Problem.
And Other Side I Check The Everything To Find What Is The Problem And What Is The Meaning Of Registry.
Your Friend
Jignesh
PostPosted: April 21st, 2013, 10:49
Spildit wrote:
Can you read firmware from the drive ?
First Thank You Bro Spildit For Reply.
Bro Its Constant Bussy Not Getting Ready Then How I Check The Modules.
I Try Translator Regenation And Its Excuted Completly But No Solution.
Its Stay In Bussy And Smart Fail When I Reset Smart Its Take 3 4 Second And Give Error SIM Error And Drive Reset.
But Not Getting Ready.
Yours Friend
Jignesh
PostPosted: April 21st, 2013, 16:32
I was confused. I thought "The registry is corrupt" was not part of the drive's terminal output. I have not seen that before in those newer F3 drives.
When you sent Vx (where is 10, 40, etc.), does the drive outputs anything in terminal at all? Probably it just returns "Rst ...", right?
Also, there is still a lot of researching done on these drives and as result typical solutions frequently do not resolve the issue(s) with them.
PostPosted: April 21st, 2013, 21:51
Yes Bro Labtech I Also Never Seen This Error REGISTRY CURRUPT I Dont Know What Is The Meaning Of Error Bcoz I Never Seen This Error In Any Seagate Drive Family. And Yes When Get SATA RESET And Drive Reset And Again Boot Process Start Then Try To Some Reconstruction Process And Report Fail And Last LED000 Error And Hanged.
You R Right Bro No Tipical Solution Work In This Problem. We Need To Go Deep In This New Drive Series.
PostPosted: April 22nd, 2013, 4:53
There is fault with the preamp.
PostPosted: April 22nd, 2013, 12:54
First Thank You Dear Friend Northwind For Reply My Post And For Your Suggetion.
Bro Northwind May Be Possible Preamp But I Try Pin Shorting To Read Write Channel And Drive Reconstruction Process Work Defrently And Get Something New Messeges And Its Take Long Time Its Right Now Its In Progress So I Waiting To Finished This Process.
When Its Completed I Reply Here What Happen And If I Get Sucess Then I Submit My Whole Case Studies That What I Doing From Start To End.
So If Some One Have This Problem Then Solve It My Way.
Thank You Again And Sorry For My Poor English.
Yours Friend
Jignesh Pankhania
PostPosted: May 5th, 2013, 12:22
Case Is Solved.
Solution : I Make Case Studies I Post It Step By Step When I Am Free Right Now More Then 40 Case Pending.
Sorry For That.
Yours Friend
Jignesh Pankhania
PostPosted: May 6th, 2013, 7:05
jignesh wrote:
Case Is Solved.
Sorry For That.
Yours Friend
Jignesh Pankhania
Good Job.
When you can, publish Step By Step.
PostPosted: September 11th, 2013, 20:15
I figured out a way to recover seagate drives in this situation,
first you'll need a donnor with same model, fw
connect the donnor HD to the terminal,
type:
/2
Z
(wait for spin down message)
after the hdd stops it's platters you'll unscrew the board (KEEP THE CABLES, the board needs to still powered while doing it) and screw this donnor board to the Pacient HD
type:
U
(wait for spin sucessful message)
/T
F,,22
now wait until the LED message starts, then disconnect the cables and screw the Pacient Board back to the Pacient HD.
Now it's just imaging the HD, once it's already showing as Ready with right LBA. :)
PostPosted: September 12th, 2013, 2:27
type:
/2
Z
type:
U
/T
F,,22
Dear Friend DoutorDoHD
First Thank You For Reply My Post
Friend This Case Is Solved Allready But Not Like You Suggested Method.
My Method Is Totaly Defrent And In My Method I Dont Need Any Donor Or Hot Swap.
Thank You Very Much My Friend For Ur Suggetion.
Yours Friend
Jignesh Pankhania
PostPosted: September 12th, 2013, 14:03
i have this error solution . U need some thing. first mail me picture of pcb from component side and other side. then i tell u the short pins
second send me terminal log , then i tell u when u need to short the pins.
third u need to short the pins until it shows ready status.
fourth after it shows ready u need to enter m0,2,2,,,,,22 then clear smart
then power reset .
then use congen to disable auto relocation of bad sectors.
if u cannot under stand mail me or pm me.
kinldy mail me the pictures .
regards
Waqas Ali
waqasali766@hotmail.com
PostPosted: October 25th, 2013, 21:14
jignesh, Please i have a dic with the same problem could you post the step by step solution thank in advance.
PostPosted: October 28th, 2013, 8:52
I have the same problem Could you tell me the details of method which you solve your drive Thank u jignesh,
Users browsing this forum: Bing [Bot], Google [Bot], napalm_atx and 91 guests
