 Post subject: WD Sabre 53 the proble is writing module E0,E1
PostPosted: April 24th, 2013, 20:20
WD Sabre 53 the proble is writing module E0,E1 selfscan module are not being writing for drive ihave change pcb but problem is still remain how to fix this isue ???any expet know this problem solution?
 Post subject: Re: WD Sabre 53 the proble is writing module E0,E1
PostPosted: April 24th, 2013, 20:37
but spildit before writing a module how to fix a bad sec
my drive
passport is wd rom model sabre
any solution ??
PostPosted: April 24th, 2013, 20:46
E0 & E1 are not needed for data recovery.
http://www.datasaversllc.com
PostPosted: April 24th, 2013, 20:49
but brother i want to repair this module and repair this fault for hdd i have a lot of quantity of this drive so any solution ?? please reply me soon
PostPosted: April 24th, 2013, 20:51
If the drive can write to SA hen you can replace module in the module map
If drive cannot write then it's probably heads issue
PostPosted: April 24th, 2013, 20:52
are u sure to head is bad??
PostPosted: April 25th, 2013, 6:13
Not sure.
Maybe a SA problem or maybe a Heads problem
is necesary to test it.
Can you write any mod in HDD?
if you can HEADS are ok, them the problem is on Sec.
if you can not HEADS are bad.
PostPosted: April 25th, 2013, 13:47
i have check the wdr and and head is good but write a module bute erorr has been shown only e0,and e1 e series module is not being write
any idea how can i solve this?
PostPosted: April 25th, 2013, 14:00
Spildit wrote:
Can you write other modules ?
NOT the E0 and E1 but OTHER ones, does it WRITES ?
If so you have BAD SECTOR on SA on the location of E0 and E1 module.
What is the problem with the drive ?
Should work fine even with those damaged modules.
What is your version of WDR ?
Yes, can you write other modeules?
PostPosted: April 25th, 2013, 14:22
yes i have write a other module an it works well but my drive when i write module e0 e1 and e series other modules then shown erorr
i am using pc3000
PostPosted: April 25th, 2013, 15:04
spildit my drive problem is it"s card is burn
i change the card but my drive show passport is wdc-rom-model-sabre
then it must be module issue
you tell am i right??
PostPosted: April 25th, 2013, 15:35
i am using pc3000
Change modules location in the map and try again
PostPosted: April 25th, 2013, 15:46
but spildit i have try to some time write a rom after write the rom a pcb is'nt spin and pcb rom has not working how to matching the rom ver and write the correct rom?
PostPosted: April 25th, 2013, 18:42
Spildit wrote:
The damaged modules are self scan ones that are not needed for the working of the drive
Maybe he wants to run selfscan
Obviously the drive should be initialized first
Users browsing this forum: No registered users and 95 guests
cron
