 Post subject: Seagate ST3000DM001 not detected. Terminal Log LED Error
PostPosted: April 26th, 2013, 12:14
Seagate ST3000DM001 isn't detected in BIOS, is there a way to revive the drive?
Data is not important, firmware is CC4B.
The start sound is normal, terminal log shows some errors:
Boot 0x40M
Spin Up[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes:  40125B20  40122EF8
Seg Write Preamble VBM start: 0000204A end: 00002091
  Footer - start: 00002093 end: 000020DA
Seg Read Preamble VBM - start: 000020DC end: 00002123
  Footer - start: 00002125 end: 0000216C
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 0A61
Nonvolatile MCMT sequence number 000045AE
[RSRS] 0363
Starting LBA of RW Request=000000000002BD0D  Length=00000747
ProcessRWError -Read-   at LBA 000000000002BD0E  Sense Code=43110081!
ProcessRWError -Read-   at LBA 000000000002BD10  Sense Code=43110081!
ProcessRWError -Read-   at LBA 000000000002BD12  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BD14  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BD19  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BD1C  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BD20  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BD25  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BD32  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BDA6  Sense Code=43110081[RA]!
ProcessRWError -Read-   at LBA 000000000002BDB1  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BDB5  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BDBC  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BDCB  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BDCE  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BDD1  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BDD3  Sense Code=43110081!
ProcessRWError -Read-   at LBA 000000000002BDD5  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BDDD  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BDE2  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE14  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE2E  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE54  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE5E  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE61  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE64  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE6F  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE74  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE78  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE7E  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BE82  Sense Code=43110081!
ProcessRWError -Read-   at LBA 000000000002BE83  Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000000000002BE83!
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00005141
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00005141
MCMainPOR: Feature Enabled...
ProcessRWError -Read-   at LBA 000000000002BAA1  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BAA3  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BAAE  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BAB3  Sense Code=40000087
Starting LBA of RW Request=000000000002BAA0  Length=000000CF
ProcessRWError -Read-   at LBA 000000000002BAB4  Sense Code=43110081[RA]!
ProcessRWError -Read-   at LBA 000000000002BACA  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BAD5  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BAD7  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BAF7  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB08  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB25  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB3A  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB4A  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB50  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB53  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB58  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB5B  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB5D  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB6B  Sense Code=40000087
ProcessRWError -Read-   at LBA 000000000002BB6E  Sense Code=40000087
Rst 0x40M
Spin Up
LED:000000BD FAddr:000058E4
 Post subject: Re: Seagate ST3000DM001 not detected. Terminal Log LED Error
PostPosted: April 26th, 2013, 12:22
So far, there are bad sectors in the drive's firmware.
Tested heads, yet?
PostPosted: April 26th, 2013, 12:29
I think heads are ok.
If I do Ctrl + T during Read Errors, I'm in Diag Mode after some seconds and the drive let me reset SMART or G-List.
PostPosted: April 26th, 2013, 12:32
Think? Or you are sure? Check heads resistance in terminal.
PostPosted: April 26th, 2013, 12:54
Head 00 Resistance 019C
Head 01 Resistance 015D
Head 02 Resistance 0176
Head 03 Resistance 00E4
Head 04 Resistance 0138
Head 05 Resistance 0116
So what does it say me?
Maybe Head 3 is broken?
PostPosted: April 26th, 2013, 13:35
No, heads should be fine.
PostPosted: April 26th, 2013, 13:58
FW Bad secs.
PostPosted: April 26th, 2013, 17:30
Alright, thanks for your answers all.
So It's impossible to revive I think.
Maybe flash new Firmware (CC4H)? It's detected sometimes in Bios after long time I just noticed.
If not, I'll keep it for case I need heads or PCB for another drive.
PostPosted: April 26th, 2013, 18:23
It's not impossible. Just hard to find out how.
PostPosted: May 5th, 2013, 4:48
are you try to rewrite FW?
If you get errors writing FW, Secs Problems for sure but if you can write FW without errors other problem.
PostPosted: May 5th, 2013, 5:04
It's not impossible (as long as heads work and "surface" is not damaged)
Won't solve the problem (need other work to make the drive re-usable again completely and cannot be accomplished with simple terminal, neither with SD box or similar tools (and to say it all neither with more expensive tools :mrgreen:).
That's better.
Users browsing this forum: Pi0tR and 231 guests
