 Post subject: WDC WD20EARS-22MVWB0 - Sadle G6
PostPosted: April 24th, 2013, 9:01
I Guys;
I have here a WD WD20EARS for data recovery, the problem is bad heads, i exchange heads with new ones.
And the drive come ready, but some modules in SA are wrong. (P-lis, G-List, ..., modules are wrong) any way to data extract from here?
I atach log from pc3k.
Thanks to all peple here.
 Post subject: Re: WDC WD20EARS-22MVWB0 - Sadle G6
PostPosted: April 24th, 2013, 9:05
what do you mean are 'wrong'? Are they read but header/checksum reports error? are they read in error? Do they simply give error when trying to read? Can you read tracks?
If it remains powered after heads changed, and previously it powered down, then I would guess heads are compatible and process is good but you have some problem with SA. Need to determine if mods are actually reading or if are bad.
PostPosted: April 24th, 2013, 9:11
Thanks hddguy
they simply give error whe triing to read with PC3K
PostPosted: April 24th, 2013, 9:14
Log from PC3k
_______________________________________________________
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 5
Cyl Count............................... : 256
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 22.00E
ROM generation.......................... : 22.00E
Link table version...................... : 0B.36.
Consolidated ROM version................ : 00220000
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 377 654 (24)
Heads number............................ : 6
Heads number in use..................... : 5
Switched off heads...................... : Yes
Heads map............................... : 0,2,5,6,7
ROM Firmware version.................... : 00220000
Service area:
SA dir reading.......................... : Ok
SA Access............................... : NONE
Configuration reading................... : No SA copy avalabled
HDD resources backup
Read ROM
Into file............................... : <HDD Profile>\Data\SABackup\ROM\ROM.bin
Ok
Read ROM modules
Module : 0A............................. : Ok
Module : 0B............................. : Ok
Module : 20B............................ : Ok
Module : 30............................. : Ok
Module : 47............................. : Ok
Module : 0D............................. : Ok
Module : 4F............................. : Ok
Reading modules
Into folder............................. : <HDD Profile>\Data\SABackup\Modules\
Module : 35............................. : No SA copy avalabled
Module : 33............................. : No SA copy avalabled
Module : 31............................. : No SA copy avalabled
Module : 0C............................. : No SA copy avalabled
Module : 34............................. : No SA copy avalabled
Module : 32............................. : No SA copy avalabled
Module : 36............................. : No SA copy avalabled
Module : 29............................. : No SA copy avalabled
Module : 40............................. : No SA copy avalabled
Module : 41............................. : No SA copy avalabled
Module : 42............................. : No SA copy avalabled
Module : 43............................. : No SA copy avalabled
Module : 4E............................. : No SA copy avalabled
Module : 49............................. : No SA copy avalabled
Module : 4A............................. : No SA copy avalabled
Module : 4D............................. : No SA copy avalabled
Module : 03............................. : No SA copy avalabled
Module : 25............................. : No SA copy avalabled
Module : 26............................. : No SA copy avalabled
Module : 38............................. : No SA copy avalabled
Module : 39............................. : No SA copy avalabled
Module : 37............................. : No SA copy avalabled
Module : 2D............................. : No SA copy avalabled
Module : 2E............................. : No SA copy avalabled
Module : B5............................. : No SA copy avalabled
Module : 6B............................. : No SA copy avalabled
Module : 3A............................. : No SA copy avalabled
Module : 28............................. : No SA copy avalabled
Module : 3B............................. : No SA copy avalabled
Module : 3C............................. : No SA copy avalabled
Module : 3D............................. : No SA copy avalabled
Module : 3E............................. : No SA copy avalabled
Module : 3F............................. : No SA copy avalabled
Module : 6F............................. : No SA copy avalabled
Module : 116............................ : No SA copy avalabled
Module : 118............................ : No SA copy avalabled
Module : 119............................ : No SA copy avalabled
Module : 68............................. : No SA copy avalabled
Module : 69............................. : No SA copy avalabled
Module : 6A............................. : No SA copy avalabled
Module : 120............................ : No SA copy avalabled
Module : 12D............................ : No SA copy avalabled
Module : 04............................. : No SA copy avalabled
Module : 05............................. : No SA copy avalabled
Module : 3700........................... : No SA copy avalabled
Module : DE............................. : No SA copy avalabled
Module : B6............................. : No SA copy avalabled
Module : D5............................. : No SA copy avalabled
Module : 3411........................... : No SA copy avalabled
Module : D1............................. : No SA copy avalabled
Module : DB............................. : No SA copy avalabled
Module : DF............................. : No SA copy avalabled
Module : DD............................. : No SA copy avalabled
Module : 3402........................... : No SA copy avalabled
Module : D7............................. : No SA copy avalabled
Module : D2............................. : No SA copy avalabled
Module : 3300........................... : No SA copy avalabled
Module : 3301........................... : No SA copy avalabled
Module : 3303........................... : No SA copy avalabled
Module : 3500........................... : No SA copy avalabled
Module : BB............................. : No SA copy avalabled
Module : 3400........................... : No SA copy avalabled
Module : 3407........................... : No SA copy avalabled
Module : 3405........................... : No SA copy avalabled
Module : D9............................. : No SA copy avalabled
Module : D4............................. : No SA copy avalabled
Module : DC............................. : No SA copy avalabled
Module : D0............................. : No SA copy avalabled
Module : D3............................. : No SA copy avalabled
Module : F7............................. : No SA copy avalabled
Module : BA............................. : No SA copy avalabled
Module : 3406........................... : No SA copy avalabled
Module : B9............................. : No SA copy avalabled
Module : BC............................. : No SA copy avalabled
Module : 3417........................... : No SA copy avalabled
Module : D8............................. : No SA copy avalabled
Module : BD............................. : No SA copy avalabled
Module : BE............................. : No SA copy avalabled
Module : 3401........................... : No SA copy avalabled
Module : 3302........................... : No SA copy avalabled
Module : 3304........................... : No SA copy avalabled
Module : 3501........................... : No SA copy avalabled
Module : 3502........................... : No SA copy avalabled
Module : 3416........................... : No SA copy avalabled
Module : 3F01........................... : No SA copy avalabled
Module : B8............................. : No SA copy avalabled
Module : BF............................. : No SA copy avalabled
Module : E6............................. : No SA copy avalabled
Module : E7............................. : No SA copy avalabled
Module : 34E7........................... : No SA copy avalabled
Module : 3801........................... : No SA copy avalabled
Module : 3415........................... : No SA copy avalabled
Module : 3418........................... : No SA copy avalabled
Module : 3423........................... : No SA copy avalabled
Module : 3422........................... : No SA copy avalabled
Module : 3421........................... : No SA copy avalabled
Module : 3F00........................... : No SA copy avalabled
Module : 1000........................... : No SA copy avalabled
Module : B1............................. : No SA copy avalabled
Module : B2............................. : No SA copy avalabled
Module : 1001........................... : No SA copy avalabled
Module : 1002........................... : No SA copy avalabled
Module : 1009........................... : No SA copy avalabled
Module : 100A........................... : No SA copy avalabled
Module : 1003........................... : No SA copy avalabled
Module : 100C........................... : No SA copy avalabled
Module : 1005........................... : No SA copy avalabled
Module : 1004........................... : No SA copy avalabled
Module : 1007........................... : No SA copy avalabled
Module : 100B........................... : No SA copy avalabled
Module : 100D........................... : No SA copy avalabled
Module : 100E........................... : No SA copy avalabled
Module : 1008........................... : No SA copy avalabled
Module : C3............................. : No SA copy avalabled
Module : C8............................. : No SA copy avalabled
Module : 8010........................... : No SA copy avalabled
Module : 802C........................... : No SA copy avalabled
Module : 8035........................... : No SA copy avalabled
Module : 8038........................... : No SA copy avalabled
Module : 803C........................... : No SA copy avalabled
Module : 8016........................... : No SA copy avalabled
Module : 801D........................... : No SA copy avalabled
Module : 8044........................... : No SA copy avalabled
Module : 8031........................... : No SA copy avalabled
Module : 8062........................... : No SA copy avalabled
Module : 8063........................... : No SA copy avalabled
Module : 8041........................... : No SA copy avalabled
Module : 8042........................... : No SA copy avalabled
Module : 800E........................... : No SA copy avalabled
Module : 802D........................... : No SA copy avalabled
Module : 8019........................... : No SA copy avalabled
Module : 802F........................... : No SA copy avalabled
Module : 8034........................... : No SA copy avalabled
Module : 802E........................... : No SA copy avalabled
Module : 8032........................... : No SA copy avalabled
Module : 8017........................... : No SA copy avalabled
Module : 8002........................... : No SA copy avalabled
Module : 800B........................... : No SA copy avalabled
Module : 8005........................... : No SA copy avalabled
Module : 8020........................... : No SA copy avalabled
Module : 8046........................... : No SA copy avalabled
Module : 8045........................... : No SA copy avalabled
Module : 8027........................... : No SA copy avalabled
Module : 8014........................... : No SA copy avalabled
Module : 801C........................... : No SA copy avalabled
Module : 8023........................... : No SA copy avalabled
Module : 801F........................... : No SA copy avalabled
Module : 803A........................... : No SA copy avalabled
Module : 803E........................... : No SA copy avalabled
Module : 8012........................... : No SA copy avalabled
Module : 8026........................... : No SA copy avalabled
Module : 802B........................... : No SA copy avalabled
Module : 8029........................... : No SA copy avalabled
Module : 802A........................... : No SA copy avalabled
Module : 8037........................... : No SA copy avalabled
Module : 803B........................... : No SA copy avalabled
Module : 800F........................... : No SA copy avalabled
Module : 800A........................... : No SA copy avalabled
Module : 8025........................... : No SA copy avalabled
Module : 8009........................... : No SA copy avalabled
Module : 800C........................... : No SA copy avalabled
Module : 8006........................... : No SA copy avalabled
Module : 8018........................... : No SA copy avalabled
Module : 800D........................... : No SA copy avalabled
Module : 8008........................... : No SA copy avalabled
Module : 8024........................... : No SA copy avalabled
Module : 8015........................... : No SA copy avalabled
Module : 8007........................... : No SA copy avalabled
Module : 8065........................... : No SA copy avalabled
Module : 801A........................... : No SA copy avalabled
Module : 8030........................... : No SA copy avalabled
Module : 801E........................... : No SA copy avalabled
Module : 8001........................... : No SA copy avalabled
Module : 8022........................... : No SA copy avalabled
Module : 8064........................... : No SA copy avalabled
Module : 8049........................... : No SA copy avalabled
Module : 805D........................... : No SA copy avalabled
Module : 805E........................... : No SA copy avalabled
Module : 805F........................... : No SA copy avalabled
Module : 8060........................... : No SA copy avalabled
Module : 8061........................... : No SA copy avalabled
Module : 8011........................... : No SA copy avalabled
Module : 803F........................... : No SA copy avalabled
Module : 8040........................... : No SA copy avalabled
Module : 8033........................... : No SA copy avalabled
Module : 8043........................... : No SA copy avalabled
Module : 8000........................... : No SA copy avalabled
Module : 8021........................... : No SA copy avalabled
Module : 8FFC........................... : No SA copy avalabled
Module : 8FFD........................... : No SA copy avalabled
Module : 8FFE........................... : No SA copy avalabled
Module : 8047........................... : No SA copy avalabled
Module : 8048........................... : No SA copy avalabled
Module : 8004........................... : No SA copy avalabled
Module : 8003........................... : No SA copy avalabled
Module : 8028........................... : No SA copy avalabled
Module : 8039........................... : No SA copy avalabled
Module : 803D........................... : No SA copy avalabled
Module : 8036........................... : No SA copy avalabled
Module : 801B........................... : No SA copy avalabled
Module : 8013........................... : No SA copy avalabled
Module : 804C........................... : No SA copy avalabled
Module : 804D........................... : No SA copy avalabled
Module : 804E........................... : No SA copy avalabled
Module : 804F........................... : No SA copy avalabled
Module : 804A........................... : No SA copy avalabled
Module : 804B........................... : No SA copy avalabled
Module : 8050........................... : No SA copy avalabled
Module : 8051........................... : No SA copy avalabled
Module : 8052........................... : No SA copy avalabled
Module : 8053........................... : No SA copy avalabled
Module : 8054........................... : No SA copy avalabled
Module : 8055........................... : No SA copy avalabled
Module : 8056........................... : No SA copy avalabled
Module : 8057........................... : No SA copy avalabled
Module : 8058........................... : No SA copy avalabled
Module : 8059........................... : No SA copy avalabled
Module : 805A........................... : No SA copy avalabled
Module : 805B........................... : No SA copy avalabled
Module : 805C........................... : No SA copy avalabled
Module : 8066........................... : No SA copy avalabled
Module : 8067........................... : No SA copy avalabled
Module : 8068........................... : No SA copy avalabled
Module : 8069........................... : No SA copy avalabled
Module : 806A........................... : No SA copy avalabled
Module : 806B........................... : No SA copy avalabled
Module : 806C........................... : No SA copy avalabled
Module : 806D........................... : No SA copy avalabled
Module : 806E........................... : No SA copy avalabled
Module : 91............................. : No SA copy avalabled
Module : AE............................. : No SA copy avalabled
Module : C2............................. : No SA copy avalabled
Module : AA............................. : No SA copy avalabled
Module : AC............................. : No SA copy avalabled
Module : 2904........................... : No SA copy avalabled
Module : C4............................. : No SA copy avalabled
Module : A2............................. : No SA copy avalabled
Module : C5............................. : No SA copy avalabled
Module : 2900........................... : No SA copy avalabled
Module : 2901........................... : No SA copy avalabled
Module : 2903........................... : No SA copy avalabled
Module : 2F00........................... : No SA copy avalabled
Module : 2802........................... : No SA copy avalabled
Module : 2909........................... : No SA copy avalabled
Module : 290A........................... : No SA copy avalabled
Module : 2A02........................... : No SA copy avalabled
Module : 1121........................... : No SA copy avalabled
Module : 1100........................... : No SA copy avalabled
Module : 150F........................... : No SA copy avalabled
Module : 150E........................... : No SA copy avalabled
Module : 150D........................... : No SA copy avalabled
Module : 150C........................... : No SA copy avalabled
Module : 1507........................... : No SA copy avalabled
Module : 1506........................... : No SA copy avalabled
Module : 1505........................... : No SA copy avalabled
Module : 1504........................... : No SA copy avalabled
Module : 1101........................... : No SA copy avalabled
Module : 1503........................... : No SA copy avalabled
Module : 1502........................... : No SA copy avalabled
Module : 1501........................... : No SA copy avalabled
Module : 1500........................... : No SA copy avalabled
Module : 80FE........................... : No SA copy avalabled
Module : 806F........................... : No SA copy avalabled
Module : 3604........................... : No SA copy avalabled
Module : 2077........................... : No SA copy avalabled
Module : 2076........................... : No SA copy avalabled
Module : 2075........................... : No SA copy avalabled
Module : 2074........................... : No SA copy avalabled
Module : 2073........................... : No SA copy avalabled
Module : 2072........................... : No SA copy avalabled
Module : 2071........................... : No SA copy avalabled
Module : 2070........................... : No SA copy avalabled
Module : 2067........................... : No SA copy avalabled
Module : 2066........................... : No SA copy avalabled
Module : 2065........................... : No SA copy avalabled
Module : 2064........................... : No SA copy avalabled
Module : 2063........................... : No SA copy avalabled
Module : 2062........................... : No SA copy avalabled
Module : 2061........................... : No SA copy avalabled
Module : 2060........................... : No SA copy avalabled
Module : 2057........................... : No SA copy avalabled
Module : 2056........................... : No SA copy avalabled
Module : 2055........................... : No SA copy avalabled
Module : 2054........................... : No SA copy avalabled
Module : 2053........................... : No SA copy avalabled
Module : 2052........................... : No SA copy avalabled
Module : 2051........................... : No SA copy avalabled
Module : 2050........................... : No SA copy avalabled
Module : 2047........................... : No SA copy avalabled
Module : 2046........................... : No SA copy avalabled
Module : 2045........................... : No SA copy avalabled
Module : 2044........................... : No SA copy avalabled
Module : 2043........................... : No SA copy avalabled
Module : 2042........................... : No SA copy avalabled
Module : 2041........................... : No SA copy avalabled
Module : 2040........................... : No SA copy avalabled
Module : 2017........................... : No SA copy avalabled
Module : 2016........................... : No SA copy avalabled
Module : 2015........................... : No SA copy avalabled
Module : 2014........................... : No SA copy avalabled
Module : 2013........................... : No SA copy avalabled
Module : 2012........................... : No SA copy avalabled
Module : 2011........................... : No SA copy avalabled
Module : 2010........................... : No SA copy avalabled
Module : 2037........................... : No SA copy avalabled
Module : 2036........................... : No SA copy avalabled
Module : 2035........................... : No SA copy avalabled
Module : 2034........................... : No SA copy avalabled
Module : 2033........................... : No SA copy avalabled
Module : 2032........................... : No SA copy avalabled
Module : 2031........................... : No SA copy avalabled
Module : 2030........................... : No SA copy avalabled
Module : 2027........................... : No SA copy avalabled
Module : 2026........................... : No SA copy avalabled
Module : 2025........................... : No SA copy avalabled
Module : 2024........................... : No SA copy avalabled
Module : 2023........................... : No SA copy avalabled
Module : 2022........................... : No SA copy avalabled
Module : 2021........................... : No SA copy avalabled
Module : 2020........................... : No SA copy avalabled
Module : 2007........................... : No SA copy avalabled
Module : 2006........................... : No SA copy avalabled
Module : 2005........................... : No SA copy avalabled
Module : 2004........................... : No SA copy avalabled
Module : 2003........................... : No SA copy avalabled
Module : 2002........................... : No SA copy avalabled
Module : 2001........................... : No SA copy avalabled
Module : 2000........................... : No SA copy avalabled
Module : 9A............................. : No SA copy avalabled
Module : A0............................. : No SA copy avalabled
Module : A5............................. : No SA copy avalabled
Module : A9............................. : No SA copy avalabled
Module : 97............................. : No SA copy avalabled
Module : 96............................. : No SA copy avalabled
Module : C9............................. : No SA copy avalabled
Module : C6............................. : No SA copy avalabled
Module : 93............................. : No SA copy avalabled
Module : CE............................. : No SA copy avalabled
Module : 98............................. : No SA copy avalabled
Module : 128............................ : No SA copy avalabled
Module : 121............................ : No SA copy avalabled
Module : 94............................. : No SA copy avalabled
Module : CF............................. : No SA copy avalabled
Module : 99............................. : No SA copy avalabled
Module : AF............................. : No SA copy avalabled
Module : 280A........................... : No SA copy avalabled
Module : CA............................. : No SA copy avalabled
Module : 3C00........................... : No SA copy avalabled
Module : FA............................. : No SA copy avalabled
Module : C1............................. : No SA copy avalabled
Module : EE............................. : No SA copy avalabled
Module : B7............................. : No SA copy avalabled
Module : 9C............................. : No SA copy avalabled
Module : CC............................. : No SA copy avalabled
Module : C7............................. : No SA copy avalabled
Module : FC............................. : No SA copy avalabled
Module : 11............................. : No SA copy avalabled
Module : 01............................. : No SA copy avalabled
Module : 9E............................. : No SA copy avalabled
Module : FD............................. : No SA copy avalabled
Module : 3E00........................... : No SA copy avalabled
Module : 5C............................. : No SA copy avalabled
Module : 122............................ : No SA copy avalabled
Module : 6D............................. : No SA copy avalabled
Module : 4002........................... : No SA copy avalabled
Module : AC55........................... : No SA copy avalabled
Module : 6E............................. : No SA copy avalabled
Module : 1F............................. : No SA copy avalabled
Module : 62............................. : No SA copy avalabled
Module : 61............................. : No SA copy avalabled
Module : 115............................ : No SA copy avalabled
Module : 53............................. : No SA copy avalabled
Module : 52............................. : No SA copy avalabled
Module : 51............................. : No SA copy avalabled
Module : 50............................. : No SA copy avalabled
Module : 12............................. : No SA copy avalabled
Module : 19............................. : No SA copy avalabled
Module : 24............................. : No SA copy avalabled
Module : 23............................. : No SA copy avalabled
Module : 21............................. : No SA copy avalabled
Module : 2A............................. : No SA copy avalabled
Module : 2F............................. : No SA copy avalabled
Module : 1E............................. : No SA copy avalabled
Module : 15............................. : No SA copy avalabled
Module : 14............................. : No SA copy avalabled
Module : 1C............................. : No SA copy avalabled
Module : 17............................. : No SA copy avalabled
Module : 02............................. : No SA copy avalabled
Module : 109............................ : No SA copy avalabled
Module : 108............................ : No SA copy avalabled
Module : 106............................ : No SA copy avalabled
Module : 105............................ : No SA copy avalabled
Module : 104............................ : No SA copy avalabled
Module : 103............................ : No SA copy avalabled
Module : 102............................ : No SA copy avalabled
Module : 110............................ : No SA copy avalabled
Module : AD............................. : No SA copy avalabled
Module : 1430........................... : No SA copy avalabled
Module : E0............................. : No SA copy avalabled
Module : E1............................. : No SA copy avalabled
Module : E2............................. : No SA copy avalabled
Module : E3............................. : No SA copy avalabled
Module : E4............................. : No SA copy avalabled
Module : E5............................. : No SA copy avalabled
Module : FE............................. : No SA copy avalabled
Module : 120F........................... : No SA copy avalabled
Module : 1213........................... : No SA copy avalabled
Module : 2906........................... : No SA copy avalabled
Module : 2908........................... : No SA copy avalabled
Module : 121F........................... : No SA copy avalabled
Module : E8............................. : No SA copy avalabled
Module : E9............................. : No SA copy avalabled
Module : EA............................. : No SA copy avalabled
Module : EB............................. : No SA copy avalabled
Module : EC............................. : No SA copy avalabled
Module : ED............................. : No SA copy avalabled
Module : 1400........................... : No SA copy avalabled
Reading service tracks
Into folder............................. : <HDD Profile>\Data\SABackup\Tracks
Reading heads........................... : 0,2
Cyl -1; Head 0.......................... : Ok
Cyl -1; Head 2.......................... : Ok
Cyl -2; Head 0.......................... : Ok
Cyl -2; Head 2.......................... : Ok
Cyl -3; Head 0.......................... : Ok
Cyl -3; Head 2.......................... : Ok
Cyl -4; Head 0.......................... : Ok
Cyl -4; Head 2.......................... : Ok
Cyl -5; Head 0.......................... : Ok
Cyl -5; Head 2.......................... : Ok
Cyl -6; Head 0.......................... : Ok
Cyl -6; Head 2.......................... : Ok
Cyl -7; Head 0.......................... : Ok
Cyl -7; Head 2.......................... : Ok
Cyl -8; Head 0.......................... : Ok
Cyl -8; Head 2.......................... : Ok
Cyl -9; Head 0.......................... : Ok
Cyl -9; Head 2.......................... : Ok
Cyl -10; Head 0......................... : Ok
Cyl -10; Head 2......................... : Ok
Cyl -11; Head 0......................... : Ok
Cyl -11; Head 2......................... : Ok
Cyl -12; Head 0......................... : Ok
Cyl -12; Head 2......................... : Ok
Cyl -13; Head 0......................... : Ok
Cyl -13; Head 2......................... : Ok
Cyl -14; Head 0......................... : Ok
Cyl -14; Head 2......................... : Ok
Cyl -15; Head 0......................... : Ok
Cyl -15; Head 2......................... : Ok
Cyl -16; Head 0......................... : Ok
Cyl -16; Head 2......................... : Ok
Cyl -17; Head 0......................... : Ok
Cyl -17; Head 2......................... : Ok
Cyl -18; Head 0......................... : Ok
Cyl -18; Head 2......................... : Ok
Cyl -19; Head 0......................... : Ok
Cyl -19; Head 2......................... : Ok
Cyl -20; Head 0......................... : Ok
Cyl -20; Head 2......................... : Ok
Cyl -21; Head 0......................... : Ok
Cyl -21; Head 2......................... : Ok
Cyl -22; Head 0......................... : Ok
Cyl -22; Head 2......................... : Ok
Cyl -23; Head 0......................... : Ok
Cyl -23; Head 2......................... : Ok
Cyl -24; Head 0......................... : Ok
Cyl -24; Head 2......................... : Ok
Cyl -25; Head 0......................... : Ok
Cyl -25; Head 2......................... : Ok
Cyl -26; Head 0......................... : Ok
Cyl -26; Head 2......................... : Ok
Cyl -27; Head 0......................... : Ok
Cyl -27; Head 2......................... : Ok
Cyl -28; Head 0......................... : Ok
Cyl -28; Head 2......................... : Ok
Cyl -29; Head 0......................... : Ok
Cyl -29; Head 2......................... : Ok
Cyl -30; Head 0......................... : Ok
Cyl -30; Head 2......................... : Ok
Cyl -31; Head 0......................... : Ok
Cyl -31; Head 2......................... : Ok
Cyl -32; Head 0......................... : Ok
Cyl -32; Head 2......................... : Ok
Cyl -33; Head 0......................... : Ok
Cyl -33; Head 2......................... : Ok
Cyl -34; Head 0......................... : Ok
Cyl -34; Head 2......................... : Ok
Cyl -35; Head 0......................... : Ok
Cyl -35; Head 2......................... : Ok
Cyl -36; Head 0......................... : Ok
Cyl -36; Head 2......................... : Ok
Cyl -37; Head 0......................... : Ok
Cyl -37; Head 2......................... : Ok
Cyl -38; Head 0......................... : Ok
Cyl -38; Head 2......................... : Ok
Cyl -39; Head 0......................... : Ok
Cyl -39; Head 2......................... : Ok
Cyl -40; Head 0......................... : Ok
Cyl -40; Head 2......................... : Ok
Cyl -41; Head 0......................... : Ok
Cyl -41; Head 2......................... : Ok
Cyl -42; Head 0......................... : Ok
Cyl -42; Head 2......................... : Ok
Cyl -43; Head 0......................... : Ok
Cyl -43; Head 2......................... : Ok
Cyl -44; Head 0......................... : Ok
Cyl -44; Head 2......................... : Ok
Cyl -45; Head 0......................... : Ok
Cyl -45; Head 2......................... : Ok
Cyl -46; Head 0......................... : Ok
Cyl -46; Head 2......................... : Ok
Cyl -47; Head 0......................... : Ok
Cyl -47; Head 2......................... : Ok
Cyl -48; Head 0......................... : Ok
Cyl -48; Head 2......................... : Ok
Cyl -49; Head 0......................... : Ok
Cyl -49; Head 2......................... : Ok
Cyl -50; Head 0......................... : Ok
Cyl -50; Head 2......................... : Ok
Cyl -51; Head 0......................... : Ok
Cyl -51; Head 2......................... : Ok
Cyl -52; Head 0......................... : Ok
Cyl -52; Head 2......................... : Ok
Cyl -53; Head 0......................... : Ok
Cyl -53; Head 2......................... : Ok
Cyl -54; Head 0......................... : Ok
Cyl -54; Head 2......................... : Ok
Cyl -55; Head 0......................... : Ok
Cyl -55; Head 2......................... : Ok
Cyl -56; Head 0......................... : Ok
Cyl -56; Head 2......................... : Ok
Cyl -57; Head 0......................... : Ok
Cyl -57; Head 2......................... : Ok
Cyl -58; Head 0......................... : Ok
Cyl -58; Head 2......................... : Ok
Cyl -59; Head 0......................... : Ok
Cyl -59; Head 2......................... : Ok
Cyl -60; Head 0......................... : Ok
Cyl -60; Head 2......................... : Ok
Cyl -61; Head 0......................... : Ok
Cyl -61; Head 2......................... : Ok
Cyl -62; Head 0......................... : Ok
Cyl -62; Head 2......................... : Ok
Cyl -63; Head 0......................... : Ok
Cyl -63; Head 2......................... : Ok
Cyl -64; Head 0......................... : Ok
Cyl -64; Head 2......................... : Ok
Cyl -65; Head 0......................... : Ok
Cyl -65; Head 2......................... : Ok
Cyl -66; Head 0......................... : Ok
Cyl -66; Head 2......................... : Ok
Cyl -67; Head 0......................... : Ok
Cyl -67; Head 2......................... : Ok
Cyl -68; Head 0......................... : Ok
Cyl -68; Head 2......................... : Ok
Cyl -69; Head 0......................... : Ok
Cyl -69; Head 2......................... : Ok
Cyl -70; Head 0......................... : Ok
Cyl -70; Head 2......................... : Ok
Cyl -71; Head 0......................... : Ok
Cyl -71; Head 2......................... : Ok
Cyl -72; Head 0......................... : Ok
Cyl -72; Head 2......................... : Ok
Cyl -73; Head 0......................... : Ok
Cyl -73; Head 2......................... : Ok
Cyl -74; Head 0......................... : Ok
Cyl -74; Head 2......................... : Ok
Cyl -75; Head 0......................... : Ok
Cyl -75; Head 2......................... : Ok
Cyl -76; Head 0......................... : Ok
Cyl -76; Head 2......................... : Ok
Cyl -77; Head 0......................... : Ok
Cyl -77; Head 2......................... : Ok
Cyl -78; Head 0......................... : Ok
Cyl -78; Head 2......................... : Ok
Cyl -79; Head 0......................... : Ok
Cyl -79; Head 2......................... : Ok
Cyl -80; Head 0......................... : Ok
Cyl -80; Head 2......................... : Ok
Cyl -81; Head 0......................... : Ok
Cyl -81; Head 2......................... : Ok
Cyl -82; Head 0......................... : Ok
Cyl -82; Head 2......................... : Ok
Cyl -83; Head 0......................... : Ok
Cyl -83; Head 2......................... : Ok
Cyl -84; Head 0......................... : Ok
Cyl -84; Head 2......................... : Ok
Cyl -85; Head 0......................... : Ok
Cyl -85; Head 2......................... : Ok
Cyl -86; Head 0......................... : Ok
Cyl -86; Head 2......................... : Ok
Cyl -87; Head 0......................... : Ok
Cyl -87; Head 2......................... : Ok
Cyl -88; Head 0......................... : Ok
Cyl -88; Head 2......................... : Ok
Cyl -89; Head 0......................... : Ok
Cyl -89; Head 2......................... : Ok
Cyl -90; Head 0......................... : Ok
Cyl -90; Head 2......................... : Ok
Cyl -91; Head 0......................... : Ok
Cyl -91; Head 2......................... : Ok
Cyl -92; Head 0......................... : Ok
Cyl -92; Head 2......................... : Ok
Cyl -93; Head 0......................... : Ok
Cyl -93; Head 2......................... : Ok
Cyl -94; Head 0......................... : Ok
Cyl -94; Head 2......................... : Ok
Cyl -95; Head 0......................... : Ok
Cyl -95; Head 2......................... : Ok
Cyl -96; Head 0......................... : Ok
Cyl -96; Head 2......................... : Ok
Cyl -97; Head 0......................... : Ok
Cyl -97; Head 2......................... : Ok
Cyl -98; Head 0......................... : Ok
Cyl -98; Head 2......................... : Ok
Cyl -99; Head 0......................... : Ok
Cyl -99; Head 2......................... : Ok
Cyl -100; Head 0........................ : Ok
Cyl -100; Head 2........................ : Ok
Cyl -101; Head 0........................ : Ok
Cyl -101; Head 2........................ : Ok
Cyl -102; Head 0........................ : Ok
Cyl -102; Head 2........................ : Ok
Cyl -103; Head 0........................ : Ok
Cyl -103; Head 2........................ : Ok
Cyl -104; Head 0........................ : Ok
Cyl -104; Head 2........................ : Ok
Cyl -105; Head 0........................ : Ok
Cyl -105; Head 2........................ : Ok
Cyl -106; Head 0........................ : Ok
Cyl -106; Head 2........................ : Ok
Cyl -107; Head 0........................ : Ok
Cyl -107; Head 2........................ : Ok
Cyl -108; Head 0........................ : Ok
Cyl -108; Head 2........................ : Ok
Cyl -109; Head 0........................ : Ok
Cyl -109; Head 2........................ : Ok
Cyl -110; Head 0........................ : Ok
Cyl -110; Head 2........................ : Ok
Cyl -111; Head 0........................ : Ok
Cyl -111; Head 2........................ : Ok
Cyl -112; Head 0........................ : Ok
Cyl -112; Head 2........................ : Ok
Cyl -113; Head 0........................ : Ok
Cyl -113; Head 2........................ : Ok
Cyl -114; Head 0........................ : Ok
Cyl -114; Head 2........................ : Ok
Cyl -115; Head 0........................ : Ok
Cyl -115; Head 2........................ : Ok
Cyl -116; Head 0........................ : Ok
Cyl -116; Head 2........................ : Ok
Cyl -117; Head 0........................ : Ok
Cyl -117; Head 2........................ : Ok
Cyl -118; Head 0........................ : Ok
Cyl -118; Head 2........................ : Ok
Cyl -119; Head 0........................ : Ok
Cyl -119; Head 2........................ : Ok
Cyl -120; Head 0........................ : Ok
Cyl -120; Head 2........................ : Ok
Cyl -121; Head 0........................ : Ok
Cyl -121; Head 2........................ : Ok
Cyl -122; Head 0........................ : Ok
Cyl -122; Head 2........................ : Ok
Cyl -123; Head 0........................ : Ok
Cyl -123; Head 2........................ : Ok
Cyl -124; Head 0........................ : Ok
Cyl -124; Head 2........................ : Ok
Cyl -125; Head 0........................ : Ok
Cyl -125; Head 2........................ : Ok
Cyl -126; Head 0........................ : Ok
Cyl -126; Head 2........................ : Ok
Cyl -127; Head 0........................ : Ok
Cyl -127; Head 2........................ : Ok
Cyl -128; Head 0........................ : Ok
Cyl -128; Head 2........................ : Ok
Cyl -129; Head 0........................ : Ok
Cyl -129; Head 2........................ : Ok
Cyl -130; Head 0........................ : Ok
Cyl -130; Head 2........................ : Ok
Cyl -131; Head 0........................ : Ok
Cyl -131; Head 2........................ : Ok
Cyl -132; Head 0........................ : Ok
Cyl -132; Head 2........................ : Ok
Cyl -133; Head 0........................ : Ok
Cyl -133; Head 2........................ : Ok
Cyl -134; Head 0........................ : Ok
Cyl -134; Head 2........................ : Ok
Cyl -135; Head 0........................ : Ok
Cyl -135; Head 2........................ : Ok
Cyl -136; Head 0........................ : Ok
Cyl -136; Head 2........................ : Ok
Cyl -137; Head 0........................ : Ok
Cyl -137; Head 2........................ : Ok
Cyl -138; Head 0........................ : Ok
Cyl -138; Head 2........................ : Ok
Cyl -139; Head 0........................ : Ok
Cyl -139; Head 2........................ : Ok
Cyl -140; Head 0........................ : Ok
Cyl -140; Head 2........................ : Ok
Cyl -141; Head 0........................ : Ok
Cyl -141; Head 2........................ : Ok
Cyl -142; Head 0........................ : Ok
Cyl -142; Head 2........................ : Ok
Cyl -143; Head 0........................ : Ok
Cyl -143; Head 2........................ : Ok
Cyl -144; Head 0........................ : Ok
Cyl -144; Head 2........................ : Ok
Cyl -145; Head 0........................ : Ok
Cyl -145; Head 2........................ : Ok
Cyl -146; Head 0........................ : Ok
Cyl -146; Head 2........................ : Ok
Cyl -147; Head 0........................ : Ok
Cyl -147; Head 2........................ : Ok
Cyl -148; Head 0........................ : Ok
Cyl -148; Head 2........................ : Ok
Cyl -149; Head 0........................ : Ok
Cyl -149; Head 2........................ : Ok
Cyl -150; Head 0........................ : Ok
Cyl -150; Head 2........................ : Ok
Cyl -151; Head 0........................ : Ok
Cyl -151; Head 2........................ : Ok
Cyl -152; Head 0........................ : Ok
Cyl -152; Head 2........................ : Ok
Cyl -153; Head 0........................ : Ok
Cyl -153; Head 2........................ : Ok
Cyl -154; Head 0........................ : Ok
Cyl -154; Head 2........................ : Ok
Cyl -155; Head 0........................ : Ok
Cyl -155; Head 2........................ : Ok
Cyl -156; Head 0........................ : Ok
Cyl -156; Head 2........................ : Ok
Cyl -157; Head 0........................ : Ok
Cyl -157; Head 2........................ : Ok
Cyl -158; Head 0........................ : Ok
Cyl -158; Head 2........................ : Ok
Cyl -159; Head 0........................ : Ok
Cyl -159; Head 2........................ : Ok
Cyl -160; Head 0........................ : Ok
Cyl -160; Head 2........................ : Ok
Cyl -161; Head 0........................ : Ok
Cyl -161; Head 2........................ : Ok
Cyl -162; Head 0........................ : Ok
Cyl -162; Head 2........................ : Ok
Cyl -163; Head 0........................ : Ok
Cyl -163; Head 2........................ : Ok
Cyl -164; Head 0........................ : Ok
Cyl -164; Head 2........................ : Ok
Cyl -165; Head 0........................ : Ok
Cyl -165; Head 2........................ : Ok
Cyl -166; Head 0........................ : Ok
Cyl -166; Head 2........................ : Ok
Cyl -167; Head 0........................ : Ok
Cyl -167; Head 2........................ : Ok
Cyl -168; Head 0........................ : Ok
Cyl -168; Head 2........................ : Ok
Cyl -169; Head 0........................ : Ok
Cyl -169; Head 2........................ : Ok
Cyl -170; Head 0........................ : Ok
Cyl -170; Head 2........................ : Ok
Cyl -171; Head 0........................ : Ok
Cyl -171; Head 2........................ : Ok
Cyl -172; Head 0........................ : Ok
Cyl -172; Head 2........................ : Ok
Cyl -173; Head 0........................ : Ok
Cyl -173; Head 2........................ : Ok
Cyl -174; Head 0........................ : Ok
Cyl -174; Head 2........................ : Ok
Cyl -175; Head 0........................ : Ok
Cyl -175; Head 2........................ : Ok
Cyl -176; Head 0........................ : Ok
Cyl -176; Head 2........................ : Ok
Cyl -177; Head 0........................ : Ok
Cyl -177; Head 2........................ : Ok
Cyl -178; Head 0........................ : Ok
Cyl -178; Head 2........................ : Ok
Cyl -179; Head 0........................ : Ok
Cyl -179; Head 2........................ : Ok
Cyl -180; Head 0........................ : Ok
Cyl -180; Head 2........................ : Ok
Cyl -181; Head 0........................ : Ok
Cyl -181; Head 2........................ : Ok
Cyl -182; Head 0........................ : Ok
Cyl -182; Head 2........................ : Ok
Cyl -183; Head 0........................ : Ok
Cyl -183; Head 2........................ : Ok
Cyl -184; Head 0........................ : Ok
Cyl -184; Head 2........................ : Ok
Cyl -185; Head 0........................ : Ok
Cyl -185; Head 2........................ : Ok
Cyl -186; Head 0........................ : Ok
Cyl -186; Head 2........................ : Ok
Cyl -187; Head 0........................ : Ok
Cyl -187; Head 2........................ : Ok
Cyl -188; Head 0........................ : Ok
Cyl -188; Head 2........................ : Ok
Cyl -189; Head 0........................ : Ok
Cyl -189; Head 2........................ : Ok
Cyl -190; Head 0........................ : Ok
Cyl -190; Head 2........................ : Ok
Cyl -191; Head 0........................ : Ok
Cyl -191; Head 2........................ : Ok
Cyl -192; Head 0........................ : Ok
Cyl -192; Head 2........................ : Ok
Cyl -193; Head 0........................ : Ok
Cyl -193; Head 2........................ : Ok
Cyl -194; Head 0........................ : Ok
Cyl -194; Head 2........................ : Ok
Cyl -195; Head 0........................ : Ok
Cyl -195; Head 2........................ : Ok
Cyl -196; Head 0........................ : Ok
Cyl -196; Head 2........................ : Ok
Cyl -197; Head 0........................ : Ok
Cyl -197; Head 2........................ : Ok
Cyl -198; Head 0........................ : Ok
Cyl -198; Head 2........................ : Ok
Cyl -199; Head 0........................ : Ok
Cyl -199; Head 2........................ : Ok
Cyl -200; Head 0........................ : Ok
Cyl -200; Head 2........................ : Ok
Cyl -201; Head 0........................ : Ok
Cyl -201; Head 2........................ : Ok
Cyl -202; Head 0........................ : Ok
Cyl -202; Head 2........................ : Ok
Cyl -203; Head 0........................ : Ok
Cyl -203; Head 2........................ : Ok
Cyl -204; Head 0........................ : Ok
Cyl -204; Head 2........................ : Ok
Cyl -205; Head 0........................ : Ok
Cyl -205; Head 2........................ : Ok
Cyl -206; Head 0........................ : Ok
Cyl -206; Head 2........................ : Ok
Cyl -207; Head 0........................ : Ok
Cyl -207; Head 2........................ : Ok
Cyl -208; Head 0........................ : Ok
Cyl -208; Head 2........................ : Ok
Cyl -209; Head 0........................ : Ok
Cyl -209; Head 2........................ : Ok
Cyl -210; Head 0........................ : Ok
Cyl -210; Head 2........................ : Ok
Cyl -211; Head 0........................ : Ok
Cyl -211; Head 2........................ : Ok
Cyl -212; Head 0........................ : Ok
Cyl -212; Head 2........................ : Ok
Cyl -213; Head 0........................ : Ok
Cyl -213; Head 2........................ : Ok
Cyl -214; Head 0........................ : Ok
Cyl -214; Head 2........................ : Ok
Cyl -215; Head 0........................ : Ok
Cyl -215; Head 2........................ : Ok
Cyl -216; Head 0........................ : Ok
Cyl -216; Head 2........................ : Ok
Cyl -217; Head 0........................ : Ok
Cyl -217; Head 2........................ : Ok
Cyl -218; Head 0........................ : Ok
Cyl -218; Head 2........................ : Ok
Cyl -219; Head 0........................ : Ok
Cyl -219; Head 2........................ : Ok
Cyl -220; Head 0........................ : Ok
Cyl -220; Head 2........................ : Ok
Cyl -221; Head 0........................ : Ok
Cyl -221; Head 2........................ : Ok
Cyl -222; Head 0........................ : Ok
Cyl -222; Head 2........................ : Ok
Cyl -223; Head 0........................ : Ok
Cyl -223; Head 2........................ : Ok
Cyl -224; Head 0........................ : Ok
Cyl -224; Head 2........................ : Ok
Cyl -225; Head 0........................ : Ok
Cyl -225; Head 2........................ : Ok
Cyl -226; Head 0........................ : Ok
Cyl -226; Head 2........................ : Ok
Cyl -227; Head 0........................ : Ok
Cyl -227; Head 2........................ : Ok
Cyl -228; Head 0........................ : Ok
Cyl -228; Head 2........................ : Ok
Cyl -229; Head 0........................ : Ok
Cyl -229; Head 2........................ : Ok
Cyl -230; Head 0........................ : Ok
Cyl -230; Head 2........................ : Ok
Cyl -231; Head 0........................ : Ok
Cyl -231; Head 2........................ : Ok
Cyl -232; Head 0........................ : Ok
Cyl -232; Head 2........................ : Ok
Cyl -233; Head 0........................ : Ok
Cyl -233; Head 2........................ : Ok
Cyl -234; Head 0........................ : Ok
Cyl -234; Head 2........................ : Ok
Cyl -235; Head 0........................ : Ok
Cyl -235; Head 2........................ : Ok
Cyl -236; Head 0........................ : Ok
Cyl -236; Head 2........................ : Ok
Cyl -237; Head 0........................ : Ok
Cyl -237; Head 2........................ : Ok
Cyl -238; Head 0........................ : Ok
Cyl -238; Head 2........................ : Ok
Cyl -239; Head 0........................ : Ok
Cyl -239; Head 2........................ : Ok
Cyl -240; Head 0........................ : Ok
Cyl -240; Head 2........................ : Ok
Cyl -241; Head 0........................ : Ok
Cyl -241; Head 2........................ : Ok
Cyl -242; Head 0........................ : Ok
Cyl -242; Head 2........................ : Ok
Cyl -243; Head 0........................ : Ok
Cyl -243; Head 2........................ : Ok
Cyl -244; Head 0........................ : Ok
Cyl -244; Head 2........................ : Ok
Cyl -245; Head 0........................ : Ok
Cyl -245; Head 2........................ : Ok
Cyl -246; Head 0........................ : Ok
Cyl -246; Head 2........................ : Ok
Cyl -247; Head 0........................ : Ok
Cyl -247; Head 2........................ : Ok
Cyl -248; Head 0........................ : Ok
Cyl -248; Head 2........................ : Ok
Cyl -249; Head 0........................ : Ok
Cyl -249; Head 2........................ : Ok
Cyl -250; Head 0........................ : Ok
Cyl -250; Head 2........................ : Ok
Cyl -251; Head 0........................ : Ok
Cyl -251; Head 2........................ : Ok
Cyl -252; Head 0........................ : Ok
Cyl -252; Head 2........................ : Ok
Cyl -253; Head 0........................ : Ok
Cyl -253; Head 2........................ : Ok
Cyl -254; Head 0........................ : Ok
Cyl -254; Head 2........................ : Ok
Cyl -255; Head 0........................ : Ok
Cyl -255; Head 2........................ : Ok
Cyl -256; Head 0........................ : Ok
Cyl -256; Head 2........................ : Ok
Backup process completed
View ROM information
Firmware version........................ : 00220000
ROM Modules
0A : Heads map
0B : Flash ROM dir
20B : Flash ROM dir (ext)
30 : SA Translator
47 : SA Adaptives
0D : Flash configuration
4F : Microprogram version
SA Regions
N : ABA : Size
0 : 0 : 380 160
1 : 506 880 : 380 160
2 : 1 013 760 : 380 160
3 : 1 520 640 : 380 160
4 : 2 027 520 : 380 160
5 : 2 534 400 : 380 160
Micro Jogs
LH : PH : Micro Jog (Hex/Dec)
0 : 0 : C6A/3178
1 : 2 : D13/3347
2 : 5 : C44/3140
3 : 6 : D0D/3341
4 : 7 : C10/3088
Read ROM
Into file............................... : <HDD Profile>\Data\ROM\ROM_WDC WD20EARS-22MVWB0.bin
Ok
Read ROM modules
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 0,2,5,6,7
Head 0.................................. : Ok
Head 2.................................. : Ok
Head 5.................................. : Ok
Head 6.................................. : Ok
Head 7.................................. : Ok
PostPosted: April 24th, 2013, 9:18
SA structure test
Module 0035............................. : Ok
Module ID 33 reading error Data request error - Drive is not ready
Module 0033............................. : Error
Module 0031............................. : Ok
Module 000C............................. : Ok
Module ID 34 reading error Data request error - Drive is not ready
Module 0034............................. : Error
Module ID 32 reading error Data request error - Drive is not ready
Module 0032............................. : Error
Module ID 36 reading error Data request error - Drive is not ready
Module 0036............................. : Error
Module 0029............................. : Ok
Module ID 40 reading error Data request error - Drive is not ready
Module 0040............................. : Error
Module ID 41 reading error Data request error - Drive is not ready
Module 0041............................. : Error
Module ID 42 reading error Data request error - Drive is not ready
Module 0042............................. : Error
Module ID 43 reading error Data request error - Drive is not ready
Module 0043............................. : Error
Module ID 4E reading error Data request error - Drive is not ready
Module 004E............................. : Error
Module ID 49 reading error Data request error - Drive is not ready
Module 0049............................. : Error
Module 004A............................. : Ok
Module 004D............................. : Ok
Module 0003............................. : Ok
Module 0025............................. : Ok
Module 0026............................. : Ok
Module 0038............................. : Ok
Module 0039............................. : Ok
Module 0037............................. : Ok
Module 002D............................. : Ok
Module 002E............................. : Ok
Module 00B5............................. : Ok
Module 006B............................. : Ok
Module 003A............................. : Ok
Module 0028............................. : Ok
Module 003B............................. : Ok
Module 003C............................. : Ok
Module 003D............................. : Ok
Module 003E............................. : Ok
Module 003F............................. : Ok
Module 006F............................. : CS
Module 0116............................. : Ok
Module 0118............................. : Ok
Module 0119............................. : Ok
Module 0068............................. : Ok
Module 0069............................. : Ok
Module 006A............................. : Ok
Module ID 120 reading error Data request error - Drive is not ready
Module 0120............................. : Error
Module 012D............................. : Ok
Module 0004............................. : Ok
Module 0005............................. : Ok
Module 3700............................. : Ok
Module 00DE............................. : Ok
Module 00B6............................. : Ok
Module 00D5............................. : Ok
Module 3411............................. : Ok
Module 00D1............................. : Ok
Module 00DB............................. : Ok
Module 00DF............................. : Ok
Module 00DD............................. : Ok
Module 3402............................. : Ok
Module 00D7............................. : Ok
Module 00D2............................. : Ok
Module 3300............................. : Ok
Module 3301............................. : Ok
Module 3303............................. : Ok
Module 3500............................. : Ok
Module 00BB............................. : Ok
Module 3400............................. : Ok
Module 3407............................. : Ok
Module 3405............................. : Ok
Module 00D9............................. : Ok
Module 00D4............................. : Ok
Module 00DC............................. : Ok
Module 00D0............................. : Ok
Module 00D3............................. : Ok
Module 00F7............................. : Ok
Module 00BA............................. : Ok
Module 3406............................. : Ok
Module 00B9............................. : Ok
Module 00BC............................. : Ok
Module 3417............................. : Ok
Module 00D8............................. : Ok
Module 00BD............................. : Ok
Module 00BE............................. : Ok
Module 3401............................. : Ok
Module 3302............................. : Ok
Module 3304............................. : Ok
Module 3501............................. : Ok
Module 3502............................. : Ok
Module 3416............................. : Ok
Module 3F01............................. : Ok
Module 00B8............................. : Ok
Module 00BF............................. : Ok
Module 00E6............................. : Ok
Module 00E7............................. : Ok
Module 34E7............................. : Ok
Module 3801............................. : Ok
Module 3415............................. : Ok
Module 3418............................. : Ok
Module 3423............................. : Ok
Module 3422............................. : Ok
Module 3421............................. : Ok
Module 3F00............................. : Ok
Module 1000............................. : Ok
Module 00B1............................. : Ok
Module 00B2............................. : Ok
Module 1001............................. : Ok
Module 1002............................. : Ok
Module 1009............................. : Ok
Module 100A............................. : Ok
Module 1003............................. : Ok
Module 100C............................. : Ok
Module 1005............................. : Ok
Module 1004............................. : Ok
Module 1007............................. : Ok
Module 100B............................. : Ok
Module 100D............................. : Ok
Module 100E............................. : Ok
Module 1008............................. : Ok
Module 00C3............................. : Ok
Module 00C8............................. : Ok
Module 8010............................. : Ok
Module 802C............................. : Ok
Module 8035............................. : Ok
Module 8038............................. : Ok
Module 803C............................. : Ok
Module 8016............................. : Ok
Module 801D............................. : Ok
Module 8044............................. : Ok
Module 8031............................. : Ok
Module 8062............................. : Ok
Module 8063............................. : Ok
Module 8041............................. : Ok
Module 8042............................. : Ok
Module 800E............................. : Ok
Module 802D............................. : Ok
Module 8019............................. : Ok
Module 802F............................. : Ok
Module 8034............................. : Ok
Module 802E............................. : Ok
Module 8032............................. : Ok
Module 8017............................. : Ok
Module 8002............................. : Ok
Module 800B............................. : Ok
Module 8005............................. : Ok
Module 8020............................. : Ok
Module 8046............................. : Ok
Module 8045............................. : Ok
Module 8027............................. : Ok
Module 8014............................. : Ok
Module 801C............................. : Ok
Module 8023............................. : Ok
Module 801F............................. : Ok
Module 803A............................. : Ok
Module 803E............................. : Ok
Module 8012............................. : Ok
Module 8026............................. : Ok
Module 802B............................. : Ok
Module 8029............................. : Ok
Module 802A............................. : Ok
Module 8037............................. : Ok
Module 803B............................. : Ok
Module 800F............................. : Ok
Module 800A............................. : Ok
Module 8025............................. : Ok
Module 8009............................. : Ok
Module 800C............................. : Ok
Module 8006............................. : Ok
Module 8018............................. : Ok
Module 800D............................. : Ok
Module 8008............................. : Ok
Module 8024............................. : Ok
Module 8015............................. : Ok
Module 8007............................. : Ok
Module 8065............................. : Ok
Module 801A............................. : Ok
Module 8030............................. : Ok
Module 801E............................. : Ok
Module 8001............................. : Ok
Module 8022............................. : Ok
Module 8064............................. : Ok
Module 8049............................. : Ok
Module 805D............................. : Ok
Module 805E............................. : Ok
Module 805F............................. : Ok
Module 8060............................. : Ok
Module 8061............................. : Ok
Module 8011............................. : Ok
Module 803F............................. : Ok
Module 8040............................. : Ok
Module 8033............................. : Ok
Module 8043............................. : Ok
Module 8000............................. : Ok
Module 8021............................. : Ok
Module 8FFC............................. : Ok
Module 8FFD............................. : Ok
Module 8FFE............................. : Ok
Module 8047............................. : Ok
Module 8048............................. : Ok
Module 8004............................. : Ok
Module 8003............................. : Ok
Module 8028............................. : Ok
Module 8039............................. : Ok
Module 803D............................. : Ok
Module 8036............................. : Ok
Module 801B............................. : Ok
Module 8013............................. : Ok
Module 804C............................. : Ok
Module 804D............................. : Ok
Module 804E............................. : Ok
Module 804F............................. : Ok
Module 804A............................. : Ok
Module 804B............................. : Ok
Module 8050............................. : Ok
Module 8051............................. : Ok
Module 8052............................. : Ok
Module 8053............................. : Ok
Module 8054............................. : Ok
Module 8055............................. : Ok
Module 8056............................. : Ok
Module 8057............................. : Ok
Module 8058............................. : Ok
Module 8059............................. : Ok
Module 805A............................. : Ok
Module 805B............................. : Ok
Module 805C............................. : Ok
Module 8066............................. : Ok
Module 8067............................. : Ok
Module 8068............................. : Ok
Module 8069............................. : Ok
Module 806A............................. : Ok
Module 806B............................. : Ok
Module 806C............................. : Ok
Module 806D............................. : Ok
Module 806E............................. : Ok
Module 0091............................. : Ok
Module 00AE............................. : Ok
Module 00C2............................. : Ok
Module 00AA............................. : Ok
Module 00AC............................. : Ok
Module 2904............................. : Ok
Module 00C4............................. : Ok
Module 00A2............................. : Ok
Module 00C5............................. : Ok
Module 2900............................. : Ok
Module 2901............................. : Ok
Module 2903............................. : Ok
Module 2F00............................. : Ok
Module 2802............................. : Ok
Module 2909............................. : Ok
Module 290A............................. : Ok
Module 2A02............................. : Ok
Module 1121............................. : Ok
Module 1100............................. : Ok
Module 150F............................. : Ok
Module 150E............................. : Ok
Module 150D............................. : Ok
Module 150C............................. : Ok
Module 1507............................. : Ok
Module 1506............................. : Ok
Module 1505............................. : Ok
Module 1504............................. : Ok
Module 1101............................. : Ok
Module 1503............................. : Ok
Module 1502............................. : Ok
Module 1501............................. : Ok
Module 1500............................. : Ok
Module 80FE............................. : Ok
Module 806F............................. : Ok
Module 3604............................. : Ok
Module 2077............................. : Ok
Module 2076............................. : Ok
Module 2075............................. : Ok
Module 2074............................. : Ok
Module 2073............................. : Ok
Module 2072............................. : Ok
Module 2071............................. : Ok
Module 2070............................. : Ok
Module 2067............................. : Ok
Module 2066............................. : Ok
Module 2065............................. : Ok
Module 2064............................. : Ok
Module 2063............................. : Ok
Module 2062............................. : Ok
Module 2061............................. : Ok
Module 2060............................. : Ok
Module 2057............................. : Ok
Module 2056............................. : Ok
Module 2055............................. : Ok
Module 2054............................. : Ok
Module 2053............................. : Ok
Module 2052............................. : Ok
Module 2051............................. : Ok
Module 2050............................. : Ok
Module 2047............................. : Ok
Module 2046............................. : Ok
Module 2045............................. : Ok
Module 2044............................. : Ok
Module 2043............................. : Ok
Module 2042............................. : Ok
Module 2041............................. : Ok
Module 2040............................. : Ok
Module 2017............................. : Ok
Module 2016............................. : Ok
Module 2015............................. : Ok
Module 2014............................. : Ok
Module 2013............................. : Ok
Module 2012............................. : Ok
Module 2011............................. : Ok
Module 2010............................. : Ok
Module 2037............................. : Ok
Module 2036............................. : Ok
Module 2035............................. : Ok
Module 2034............................. : Ok
Module 2033............................. : Ok
Module 2032............................. : Ok
Module 2031............................. : Ok
Module 2030............................. : Ok
Module 2027............................. : Ok
Module 2026............................. : Ok
Module 2025............................. : Ok
Module 2024............................. : Ok
Module 2023............................. : Ok
Module 2022............................. : Ok
Module 2021............................. : Ok
Module 2020............................. : Ok
Module 2007............................. : Ok
Module 2006............................. : Ok
Module 2005............................. : Ok
Module 2004............................. : Ok
Module 2003............................. : Ok
Module 2002............................. : Ok
Module 2001............................. : Ok
Module 2000............................. : Ok
Module 009A............................. : Ok
Module 00A0............................. : Ok
Module 00A5............................. : Ok
Module 00A9............................. : Ok
Module 0097............................. : Ok
Module 0096............................. : Ok
Module 00C9............................. : Ok
Module 00C6............................. : Ok
Module 0093............................. : Ok
Module 00CE............................. : Ok
Module 0098............................. : Ok
Module 0128............................. : Ok
Module 0121............................. : Ok
Module 0094............................. : Ok
Module 00CF............................. : Ok
Module 0099............................. : Ok
Module 00AF............................. : Ok
Module 280A............................. : Ok
Module 00CA............................. : Ok
Module 3C00............................. : Ok
Module 00FA............................. : Ok
Module 00C1............................. : Ok
Module 00EE............................. : Ok
Module 00B7............................. : Ok
Module 009C............................. : Ok
Module 00CC............................. : Ok
Module 00C7............................. : Ok
Module 00FC............................. : Ok
Module ID 11 reading error Data request error - Drive is not ready
Module 0011............................. : Error
Module 0001............................. : Ok
Module 009E............................. : Ok
Module 00FD............................. : Ok
Module 3E00............................. : Ok
Module 005C............................. : Ok
Module 0122............................. : Ok
Module 006D............................. : Ok
Module ID 4002 reading error Data request error - Drive is not ready
Module 4002............................. : Error
Module AC55............................. : Ok
Module 006E............................. : Ok
Module 001F............................. : Ok
Module 0062............................. : Ok
Module 0061............................. : Ok
Module 0115............................. : Ok
Module 0053............................. : Ok
Module 0052............................. : Ok
Module 0051............................. : Ok
Module 0050............................. : Ok
Module 0012............................. : Ok
Module 0019............................. : Ok
Module 0024............................. : Ok
Module 0023............................. : Ok
Module ID 21 reading error Data request error - Drive is not ready
Module 0021............................. : Error
Module 002A............................. : Ok
Module 002F............................. : Ok
Module 001E............................. : Ok
Module 0015............................. : Ok
Module 0014............................. : Ok
Module 001C............................. : Ok
Module 0017............................. : Ok
Module 0002............................. : Ok
Module 0109............................. : Ok
Module 0108............................. : Ok
Module 0106............................. : Ok
Module 0105............................. : Ok
Module 0104............................. : Ok
Module 0103............................. : Ok
Module 0102............................. : Ok
Module 0110............................. : Ok
Module 00AD............................. : Ok
Module 1430............................. : Ok
Module 00E0............................. : Ok
Module 00E1............................. : Ok
Module 00E2............................. : Ok
Module 00E3............................. : Ok
Module 00E4............................. : Ok
Module 00E5............................. : Ok
Module 00FE............................. : Ok
Module 120F............................. : Ok
Module 1213............................. : Ok
Module 2906............................. : Ok
Module 2908............................. : Ok
Module 121F............................. : Ok
Module 00E8............................. : Ok
Module 00E9............................. : Ok
Module 00EA............................. : Ok
Module 00EB............................. : Ok
Module 00EC............................. : Ok
Module 00ED............................. : Ok
Module 1400............................. : Ok
_______________________________________________________
 Post subject: Re: WDC WD20EARS-22MVWB0 - Sadle G6
PostPosted: April 24th, 2013, 9:19
Id : Importance: ABA :Size:Read : Hdr : CS : CS Value: Vers. : Desription
0035: Dd : 0: 10:Yes : Ok : Ok : 004C :1023-Q12:SA Defects
0033: Dd : 10:2560:No : : : : :P-List (Primary defect list)
0031: Ad : 2570:1718:Yes : Ok : Ok : 004C :00400000:Translator
000C: B : 4288: 10:Yes : Ok : Ok : 004C :00010100:Models table
0034: C : 4298: 23:No : : : : :G-List (Grown defect list)
0032: B : 4321: 32:No : : : : :Relo Bad Block Module
0036: Ad : 4353: 14:No : : : : :T-List Module
0029: B : 4367: 6:Yes : Ok : Ok : 004C :00010000:Loaded part of microprogram code
0040: As : 4373: 132:No : : : : :Adaptive data
0041: As : 4505: 132:No : : : : :Adaptive data
0042: As : 4637: 132:No : : : : :Adaptive data
0043: As : 4769: 132:No : : : : :Adaptive data
004E: B : 4901: 692:No : : : : :Loaded part of microprogram code
0049: As : 5593: 4:No : : : : :Adaptive data
004A: As : 5597: 13:Yes : Ok : Ok : 004C :00010000:Adaptive data
004D: As : 5610: 1:Yes : Ok : Ok : 004C :00010000:Adaptive data
0003: As : 5611: 95:Yes : Ok : Ok : 004C :00020000:Format Select Data Module
0025: : 5706: 257:Yes : Ok : Ok : 004C :00220001:
0026: : 5963: 129:Yes : Ok : Ok : 004C :00220001:
0038: B : 6092: 257:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0039: B : 6349: 17:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0037: Dr : 6366: 1:Yes : Ok : Ok : 004C :00010000:Gain Call Data Module
002D: Dr : 6367: 450:Yes : Ok : Ok : 004C :00020004:Debug Log
002E: B : 6817: 450:Yes : Ok : Ok : 004C :00020004:Loaded part of microprogram code
00B5: Dr : 7267: 255:Yes : Ok : Ok : 004C :00220001:WRRO Log Module
006B: B : 7522: 4:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
003A: : 7526: 12:Yes : Ok : Ok : 004C :00000100:
0028: Dr : 7538: 16:Yes : Ok : Ok : 004C :00030000:Factory Self Test script
003B: : 7554: 16:Yes : Ok : Ok : 004C :00030000:
003C: : 7570: 16:Yes : Ok : Ok : 004C :00030000:
003D: : 7586: 16:Yes : Ok : Ok : 004C :00030000:
003E: : 7602: 16:Yes : Ok : Ok : 004C :00030000:
003F: : 7618: 16:Yes : Ok : Ok : 004C :00030000:
006F: B : 7634:3224:Yes : Ok :Error:004C/008F:AOZ30000:Loaded part of microprogram code
0116: : 10858: 6:Yes : Ok : Ok : 004C :00220001:
0118: : 10864: 27:Yes : Ok : Ok : 004C :00220001:
0119: : 10891: 5:Yes : Ok : Ok : 004C :0100....:
0068: : 10896: 124:Yes : Ok : Ok : 004C :00810021:
0069: : 11020: 124:Yes : Ok : Ok : 004C :00810021:
006A: : 11144: 124:Yes : Ok : Ok : 004C :00810021:
0120: : 11268: 482:No : : : : :
012D: : 11750: 450:Yes : Ok : Ok : 004C :00020004:
0004: B : 12200:10781:Yes : Ok : Ok : 004C :00020000:Family models configuration (Main)
0005: B : 22981:10781:Yes : Ok : Ok : 004C :00020000:Family models configuration (Alt1)
3700: : 33762: 233:Yes : Ok : Ok : 004C :1023-Q12:
00DE: Dr : 33995: 248:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00B6: Dr : 34243: 235:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00D5: Dr : 34478: 213:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
3411: : 34691: 141:Yes : Ok : Ok : 004C :1023-Q12:
00D1: : 34832: 267:Yes : Ok : Ok : 004C :1023-Q12:
00DB: Dr : 35099: 237:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00DF: Dr : 35336: 258:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00DD: Dr : 35594: 229:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
3402: : 35823: 239:Yes : Ok : Ok : 004C :1023-Q12:
00D7: Dr : 36062: 233:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00D2: Dr : 36295: 159:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
3300: : 36454: 162:Yes : Ok : Ok : 004C :1023-Q12:
3301: : 36616: 184:Yes : Ok : Ok : 004C :1023-Q12:
3303: : 36800: 143:Yes : Ok : Ok : 004C :1023-Q12:
3500: : 36943: 201:Yes : Ok : Ok : 004C :1023-Q12:
00BB: Dr : 37144: 179:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
3400: : 37323: 215:Yes : Ok : Ok : 004C :1023-Q12:
3407: : 37538: 201:Yes : Ok : Ok : 004C :1023-Q12:
3405: : 37739: 205:Yes : Ok : Ok : 004C :1023-Q12:
00D9: Dr : 37944: 229:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00D4: Dr : 38173: 155:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00DC: Dr : 38328: 165:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00D0: Dr : 38493: 176:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00D3: Dr : 38669: 139:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00F7: : 38808: 229:Yes : Ok : Ok : 004C :1023-Q12:
00BA: Dr : 39037: 209:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
3406: : 39246: 201:Yes : Ok : Ok : 004C :1023-Q12:
00B9: Dr : 39447: 205:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00BC: Dr : 39652: 202:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
3417: : 39854: 208:Yes : Ok : Ok : 004C :1023-Q12:
00D8: Dr : 40062: 144:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00BD: : 40206: 264:Yes : Ok : Ok : 004C :1023-Q12:
00BE: Dr : 40470: 27:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
3401: : 40497: 198:Yes : Ok : Ok : 004C :1023-Q12:
3302: : 40695: 161:Yes : Ok : Ok : 004C :1023-Q12:
3304: : 40856: 160:Yes : Ok : Ok : 004C :1023-Q12:
3501: : 41016: 205:Yes : Ok : Ok : 004C :1023-Q12:
3502: : 41221: 200:Yes : Ok : Ok : 004C :1023-Q12:
3416: : 41421: 164:Yes : Ok : Ok : 004C :1023-Q12:
3F01: : 41585: 8:Yes : Ok : Ok : 004C :1023-Q12:
00B8: Dr : 41593: 2:Yes : Ok : Ok : 004C :1023-Q12:Single Plug Test Communication Module
00BF: Dr : 41595: 8:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
00E6: Dr : 41603: 67:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test log
00E7: Dr : 41670: 32:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test parameters module
34E7: : 41702: 32:Yes : Ok : Ok : 004C :1023-Q12:
3801: : 41734: 32:Yes : Ok : Ok : 004C :1023-Q12:
3415: : 41766: 423:Yes : Ok : Ok : 004C :1023-Q12:
3418: : 42189: 169:Yes : Ok : Ok : 004C :1023-Q12:
3423: : 42358: 174:Yes : Ok : Ok : 004C :1023-Q12:
3422: : 42532: 179:Yes : Ok : Ok : 004C :1023-Q12:
3421: : 42711: 167:Yes : Ok : Ok : 004C :1023-Q12:
3F00: : 42878: 50:Yes : Ok : Ok : 004C :1023-Q12:
1000: : 42928: 20:Yes : Ok : Ok : 004C :00000001:
00B1: : 42948: 22:Yes : Ok : Ok : 004C :00000001:
00B2: : 42970: 26:Yes : Ok : Ok : 004C :00000001:
1001: : 42996: 18:Yes : Ok : Ok : 004C :00000001:
1002: : 43014: 21:Yes : Ok : Ok : 004C :00000001:
1009: : 43035: 25:Yes : Ok : Ok : 004C :00000001:
100A: : 43060: 23:Yes : Ok : Ok : 004C :00000001:
1003: : 43083: 27:Yes : Ok : Ok : 004C :00000001:
100C: : 43110: 16:Yes : Ok : Ok : 004C :00000001:
1005: : 43126: 17:Yes : Ok : Ok : 004C :00000001:
1004: : 43143: 30:Yes : Ok : Ok : 004C :00000001:
1007: : 43173: 17:Yes : Ok : Ok : 004C :00000001:
100B: : 43190: 14:Yes : Ok : Ok : 004C :00000001:
100D: : 43204: 14:Yes : Ok : Ok : 004C :00000001:
100E: : 43218: 15:Yes : Ok : Ok : 004C :00000001:
1008: : 43233: 27:Yes : Ok : Ok : 004C :00000001:
00C3: : 43260: 372:Yes : Ok : Ok : 004C :GJ.1719B:
00C8: : 43632: 395:Yes : Ok : Ok : 004C :GJ.1719B:
8010: Dr : 44027: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
802C: Dr : 44032: 3:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8035: Dr : 44035: 16:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8038: Dr : 44051: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
803C: Dr : 44053: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8016: Dr : 44055: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
801D: Dr : 44060: 33:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8044: Dr : 44093: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8031: Dr : 44095: 4:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8062: : 44099: 13:Yes : Ok : Ok : 004C :6416....:
8063: : 44112: 13:Yes : Ok : Ok : 004C :6416....:
8041: Dr : 44125: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8042: Dr : 44127: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
800E: Dr : 44129: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
802D: Dr : 44134: 65:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8019: Dr : 44199: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
802F: Dr : 44204: 8:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8034: Dr : 44212: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
802E: Dr : 44225: 8:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8032: Dr : 44233: 8:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8017: Dr : 44241: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8002: Dr : 44246: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
800B: Dr : 44248: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8005: Dr : 44250: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8020: Dr : 44252: 4:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8046: Dr : 44256: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8045: Dr : 44258: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8027: Dr : 44260: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8014: Dr : 44262: 1:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
801C: Dr : 44263: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8023: Dr : 44265: 3:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
801F: Dr : 44268: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
803A: Dr : 44270: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
803E: Dr : 44272: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8012: Dr : 44274: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8026: Dr : 44279: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
802B: Dr : 44292: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8029: Dr : 44297: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
802A: Dr : 44299: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8037: Dr : 44301: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
803B: Dr : 44303: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
800F: Dr : 44305: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
800A: Dr : 44310: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8025: Dr : 44312: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8009: Dr : 44314: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
800C: Dr : 44316: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8006: Dr : 44318: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8018: Dr : 44320: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
800D: Dr : 44322: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8008: Dr : 44327: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8024: Dr : 44329: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8015: Dr : 44331: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8007: Dr : 44333: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8065: : 44335: 33:Yes : Ok : Ok : 004C :6416....:
801A: Dr : 44368: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8030: Dr : 44373: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
801E: Dr : 44375: 101:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8001: Dr : 44476: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8022: Dr : 44478: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8064: : 44483: 5:Yes : Ok : Ok : 004C :6416....:
8049: Dr : 44488: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
805D: : 44501: 5:Yes : Ok : Ok : 004C :6416....:
805E: : 44506: 13:Yes : Ok : Ok : 004C :6416....:
805F: : 44519: 16:Yes : Ok : Ok : 004C :6416....:
8060: : 44535: 2:Yes : Ok : Ok : 004C :6416....:
8061: : 44537: 2:Yes : Ok : Ok : 004C :6416....:
8011: Dr : 44539: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
803F: Dr : 44544: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8040: Dr : 44546: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8033: Dr : 44548: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8043: Dr : 44561: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8000: Dr : 44563: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8021: Dr : 44565: 3:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8FFC: : 44568: 1:Yes : Ok : Ok : 004C :6416....:
8FFD: : 44569: 8:Yes : Ok : Ok : 004C :6416....:
8FFE: : 44577: 16:Yes : Ok : Ok : 004C :6416....:
8047: Dr : 44593: 33:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8048: Dr : 44626: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8004: Dr : 44639: 3:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8003: Dr : 44642: 3:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8028: Dr : 44645: 3:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8039: Dr : 44648: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
803D: Dr : 44650: 2:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8036: Dr : 44652: 16:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
801B: Dr : 44668: 33:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8013: Dr : 44701: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
804C: Dr : 44706: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
804D: Dr : 44711: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
804E: Dr : 44724: 100:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
804F: Dr : 44824: 3:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
804A: Dr : 44827: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
804B: Dr : 44832: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8050: Dr : 44845: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8051: Dr : 44850: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8052: Dr : 44863: 16:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8053: Dr : 44879: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8054: Dr : 44884: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8055: Dr : 44897: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8056: Dr : 44902: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8057: Dr : 44915: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8058: Dr : 44920: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
8059: Dr : 44933: 5:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
805A: Dr : 44938: 13:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
805B: Dr : 44951: 16:Yes : Ok : Ok : 004C :6416....:Single Plug Test Log Module
805C: : 44967: 2:Yes : Ok : Ok : 004C :6416....:
8066: : 44969: 2:Yes : Ok : Ok : 004C :6416....:
8067: : 44971: 5:Yes : Ok : Ok : 004C :6416....:
8068: : 44976: 13:Yes : Ok : Ok : 004C :6416....:
8069: : 44989: 15:Yes : Ok : Ok : 004C :6416....:
806A: : 45004: 3:Yes : Ok : Ok : 004C :6416....:
806B: : 45007: 3:Yes : Ok : Ok : 004C :6416....:
806C: : 45010: 4:Yes : Ok : Ok : 004C :6416....:
806D: : 45014: 11:Yes : Ok : Ok : 004C :6416....:
806E: : 45025: 33:Yes : Ok : Ok : 004C :6416....:
0091: Dr : 45058: 8:Yes : Ok : Ok : 004C :GJ.1719B:Calibrations module
00AE: : 45066: 276:Yes : Ok : Ok : 004C :GJ.1719B:
00C2: Dr : 45342: 2:Yes : Ok : Ok : 004C :GJ.1719B:Calibrations module
00AA: : 45344: 197:Yes : Ok : Ok : 004C :GJ.1719B:
00AC: : 45541: 206:Yes : Ok : Ok : 004C :GJ.1719B:
2904: : 45747: 170:Yes : Ok : Ok : 004C :GJ.1719B:
00C4: Dr : 45917: 439:Yes : Ok : Ok : 004C :GJ.1719B:Calibrations module
00A2: : 46356: 173:Yes : Ok : Ok : 004C :GJ.1719B:
00C5: Dr : 46529: 405:Yes : Ok : Ok : 004C :GJDE-E11:Calibration script (DCM)
2900: : 46934: 150:Yes : Ok : Ok : 004C :GJ.1719B:
2901: : 47084: 349:Yes : Ok : Ok : 004C :GJ.1719B:
2903: : 47433: 200:Yes : Ok : Ok : 004C :GJ.1719B:
2F00: : 47633: 333:Yes : Ok : Ok : 004C :GJ.1719B:
2802: : 47966: 219:Yes : Ok : Ok : 004C :GJ.1719B:
2909: : 48185: 441:Yes : Ok : Ok : 004C :GJ.1719B:
290A: : 48626: 201:Yes : Ok : Ok : 004C :GJ.1719B:
2A02: : 48827: 211:Yes : Ok : Ok : 004C :GJ.1719B:
1121: : 49038: 128:Yes : Ok : Ok : 004C :NOT_INIT:
1100: : 49166: 16:Yes : Ok : Ok : 004C :NOT_INIT:
150F: : 49182: 80:Yes : Ok : Ok : 004C :NOT_INIT:
150E: : 49262: 80:Yes : Ok : Ok : 004C :NOT_INIT:
150D: : 49342: 80:Yes : Ok : Ok : 004C :NOT_INIT:
150C: : 49422: 16:Yes : Ok : Ok : 004C :NOT_INIT:
1507: : 49438: 80:Yes : Ok : Ok : 004C :NOT_INIT:
1506: : 49518: 80:Yes : Ok : Ok : 004C :NOT_INIT:
1505: : 49598: 80:Yes : Ok : Ok : 004C :NOT_INIT:
1504: : 49678: 16:Yes : Ok : Ok : 004C :NOT_INIT:
1101: : 49694: 16:Yes : Ok : Ok : 004C :NOT_INIT:
1503: : 49710: 80:Yes : Ok : Ok : 004C :NOT_INIT:
1502: : 49790: 80:Yes : Ok : Ok : 004C :NOT_INIT:
1501: : 49870: 80:Yes : Ok : Ok : 004C :NOT_INIT:
1500: : 49950: 16:Yes : Ok : Ok : 004C :NOT_INIT:
80FE: : 49966: 16:Yes : Ok : Ok : 004C :NOT_INIT:
806F: : 49982: 10:Yes : Ok : Ok : 004C :NOT_INIT:
3604: : 49992: 16:Yes : Ok : Ok : 004C :NOT_INIT:
2077: : 50008: 28:Yes : Ok : Ok : 004C :NOT_INIT:
2076: : 50036: 28:Yes : Ok : Ok : 004C :NOT_INIT:
2075: : 50064: 28:Yes : Ok : Ok : 004C :NOT_INIT:
2074: : 50092: 28:Yes : Ok : Ok : 004C :NOT_INIT:
2073: : 50120: 28:Yes : Ok : Ok : 004C :NOT_INIT:
2072: : 50148: 28:Yes : Ok : Ok : 004C :NOT_INIT:
2071: : 50176: 28:Yes : Ok : Ok : 004C :NOT_INIT:
2070: : 50204: 28:Yes : Ok : Ok : 004C :NOT_INIT:
2067: : 50232: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2066: : 50632: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2065: : 51032: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2064: : 51432: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2063: : 51832: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2062: : 52232: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2061: : 52632: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2060: : 53032: 400:Yes : Ok : Ok : 004C :NOT_INIT:
2057: : 53432: 56:Yes : Ok : Ok : 004C :NOT_INIT:
2056: : 53488: 56:Yes : Ok : Ok : 004C :NOT_INIT:
2055: : 53544: 56:Yes : Ok : Ok : 004C :NOT_INIT:
2054: : 53600: 56:Yes : Ok : Ok : 004C :NOT_INIT:
2053: : 53656: 56:Yes : Ok : Ok : 004C :NOT_INIT:
2052: : 53712: 56:Yes : Ok : Ok : 004C :NOT_INIT:
2051: : 53768: 56:Yes : Ok : Ok : 004C :NOT_INIT:
2050: : 53824: 56:Yes : Ok : Ok : 004C :NOT_INIT:
2047: : 53880: 450:Yes : Ok : Ok : 004C :NOT_INIT:
2046: : 54330: 450:Yes : Ok : Ok : 004C :NOT_INIT:
2045: : 54780: 450:Yes : Ok : Ok : 004C :NOT_INIT:
2044: : 55230: 450:Yes : Ok : Ok : 004C :NOT_INIT:
2043: : 55680: 450:Yes : Ok : Ok : 004C :NOT_INIT:
2042: : 56130: 450:Yes : Ok : Ok : 004C :NOT_INIT:
2041: : 56580: 450:Yes : Ok : Ok : 004C :NOT_INIT:
2040: : 57030: 450:Yes : Ok : Ok : 004C :NOT_INIT:
2017: : 57480: 240:Yes : Ok : Ok : 004C :NOT_INIT:
2016: : 57720: 240:Yes : Ok : Ok : 004C :NOT_INIT:
2015: : 57960: 240:Yes : Ok : Ok : 004C :NOT_INIT:
2014: : 58200: 240:Yes : Ok : Ok : 004C :NOT_INIT:
2013: : 58440: 240:Yes : Ok : Ok : 004C :NOT_INIT:
2012: : 58680: 240:Yes : Ok : Ok : 004C :NOT_INIT:
2011: : 58920: 240:Yes : Ok : Ok : 004C :NOT_INIT:
2010: : 59160: 240:Yes : Ok : Ok : 004C :NOT_INIT:
2037: : 59400: 900:Yes : Ok : Ok : 004C :NOT_INIT:
2036: : 60300: 900:Yes : Ok : Ok : 004C :NOT_INIT:
2035: : 61200: 900:Yes : Ok : Ok : 004C :NOT_INIT:
2034: : 62100: 900:Yes : Ok : Ok : 004C :NOT_INIT:
2033: : 63000: 900:Yes : Ok : Ok : 004C :NOT_INIT:
2032: : 63900: 900:Yes : Ok : Ok : 004C :NOT_INIT:
2031: : 64800: 900:Yes : Ok : Ok : 004C :NOT_INIT:
2030: : 65700: 900:Yes : Ok : Ok : 004C :NOT_INIT:
2027: : 66600: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2026: : 66680: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2025: : 66760: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2024: : 66840: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2023: : 66920: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2022: : 67000: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2021: : 67080: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2020: : 67160: 80:Yes : Ok : Ok : 004C :NOT_INIT:
2007: : 67240:1900:Yes : Ok : Ok : 004C :NOT_INIT:
2006: : 69140:1900:Yes : Ok : Ok : 004C :NOT_INIT:
2005: : 71040:1900:Yes : Ok : Ok : 004C :NOT_INIT:
2004: : 72940:1900:Yes : Ok : Ok : 004C :NOT_INIT:
2003: : 74840:1900:Yes : Ok : Ok : 004C :NOT_INIT:
2002: : 76740:1900:Yes : Ok : Ok : 004C :NOT_INIT:
2001: : 78640:1900:Yes : Ok : Ok : 004C :NOT_INIT:
2000: : 80540:1900:Yes : Ok : Ok : 004C :NOT_INIT:
009A: : 82440: 60:Yes : Ok : Ok : 004C :NOT_INIT:
00A0: : 82500: 64:Yes : Ok : Ok : 004C :NOT_INIT:
00A5: : 82564: 51:Yes : Ok : Ok : 004C :NOT_INIT:
00A9: : 82615: 120:Yes : Ok : Ok : 004C :NOT_INIT:
0097: : 82735: 24:Yes : Ok : Ok : 004C :NOT_INIT:
0096: : 82759: 122:Yes : Ok : Ok : 004C :NOT_INIT:
00C9: : 82881: 82:Yes : Ok : Ok : 004C :NOT_INIT:
00C6: : 82963: 155:Yes : Ok : Ok : 004C :NOT_INIT:
0093: Dr : 83118: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CE: Dr : 83130: 641:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
0098: : 83771: 24:Yes : Ok : Ok : 004C :NOT_INIT:
0128: : 83795: 129:Yes : Ok : Ok : 004C :NOT_INIT:
0121: : 83924:8193:Yes : Ok : Ok : 004C :NOT_INIT:
0094: : 92117: 10:Yes : Ok : Ok : 004C :NOT_INIT:
00CF: Dr : 92127: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
0099: : 92139: 12:Yes : Ok : Ok : 004C :NOT_INIT:
00AF: :375729:1000:Yes : Ok : Ok : 004C :GJ.1719B:
280A: : 92152: 4:Yes : Ok : Ok : 004C :NOT_INIT:
00CA: Dr : 92156: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
3C00: : 92168: 32:Yes : Ok : Ok : 004C :NOT_INIT:
00FA: Dr : 92200: 256:Yes : Ok : Ok : 004C :NOT_INIT:Butterfly Log
00C1: Dr : 92456: 1:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00EE: Dr : 92457: 4:Yes : Ok : Ok : 004C :NOT_INIT:RRO Data Log
00B7: Dr : 92461: 19:Yes : Ok : Ok : 004C :NOT_INIT:Test Clamp Data
009C: : 92480: 1:Yes : Ok : Ok : 004C :NOT_INIT:
00CC: Dr : 92481: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00C7: Dr : 92493: 1:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00FC: Dr : 92494: 4:Yes : Ok : Ok : 004C :NOT_INIT:Factory Self Test module
0011: B :376729: 925:No : : : : :Loaded part of microprogram code
0001: B :377654: 24:Yes : Ok : Ok : 004C :00020000:Modules directory
009E: Dr :377678: 5:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00FD: Dr :377683: 64:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
3E00: :377747: 4:Yes : Ok : Ok : 004C :1023-Q12:
005C: :378303: 290:Yes : Ok : Ok : 004C :00220001:
0122: :378736: 1:Yes : Ok : Ok : 004C :00010000:
006D: :378737: 1:Yes : Ok : Ok : 004C :00010000:
4002: :378738: 1:No : : : : :
AC55: :378739: 1:Yes : Ok : Ok : 004C :00220001:
006E: B :378740: 2:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
001F: B :378742: 21:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0062: :378763: 1:Yes : Ok : Ok : 004C :00010000:
0061: B :378764: 29:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0115: :378793: 123:Yes : Ok : Ok : 004C :........:
0053: As :378916: 4:Yes : Ok : Ok : 004C :00220001:Parameters table 4
0052: As :378920: 4:Yes : Ok : Ok : 004C :00220001:Parameters table 3
0051: As :378924: 4:Yes : Ok : Ok : 004C :00220001:Parameters table 2
0050: As :378928: 4:Yes : Ok : Ok : 004C :00220001:Parameters table 1
0012: B :378932: 49:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0019: B :378981: 31:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0024: B :379012: 124:Yes : Ok : Ok : 004C :00810021:S.M.A.R.T. Log (reserved)
0023: B :379136: 124:Yes : Ok : Ok : 004C :00810021:S.M.A.R.T. Log (reserved)
0021: B :379260: 124:No : : : : :S.M.A.R.T.
002A: B :379384: 6:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
002F: B :379390: 6:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
001E: B :379396: 22:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0015: B :379418: 18:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0014: B :379436: 29:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
001C: B :379465: 48:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0017: B :379513: 63:Yes : Ok : Ok : 004C :00220001:Loaded part of microprogram code
0002: B :379576: 4:Yes : Ok : Ok : 004C :00080000:Configuration (HDD ID)
0109: Dd :379580: 513:Yes : Ok : Ok : 004C :00010000:ROM image
0108: Dr :380093: 35:Yes : Ok : Ok : 004C :00220001:IBI packet
0106: Dd :380128: 2:Yes : Ok : Ok : 004C :NOT_INIT:ROM module image
0105: Dd :380130: 2:Yes : Ok : Ok : 004C :NOT_INIT:ROM translator SA images
0104: Dd :380132: 1:Yes : Ok : Ok : 004C :NOT_INIT:Microprogram version image
0103: Dd :380133: 2:Yes : Ok : Ok : 004C :NOT_INIT:ROM adaptives SA images
0102: Dd :380135: 1:Yes : Ok : Ok : 004C :NOT_INIT:Heads map module image
0110: B :380136: 24:Yes : Ok : Ok : 004C :00020000:Modules directory (base part)
00AD: :378702: 34:Yes : Ok : Ok : 004C :NOT_INIT:
1430: :378685: 17:Yes : Ok : Ok : 004C :NOT_INIT:
00E0: Dr :373229:2500:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test defects log
00E1: Dr :370729:2500:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test defects log
00E2: Dr :368229:2500:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test defects log
00E3: Dr :365729:2500:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test defects log
00E4: Dr :363229:2500:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test defects log
00E5: Dr :360729:2500:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test defects log
00FE: Dr :359229:1500:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test module
120F: :378668: 17:Yes : Ok : Ok : 004C :NOT_INIT:
1213: :378652: 16:Yes : Ok : Ok : 004C :NOT_INIT:
2906: :358574: 655:Yes : Ok : Ok : 004C :........:
2908: :378233: 70:Yes : Ok : Ok : 004C :....È...:
121F: :378636: 16:Yes : Ok : Ok : 004C :NOT_INIT:
00E8: Dr :357519:1055:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test head 0 defects log
00E9: Dr :356464:1055:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test head 1 defects log
00EA: Dr :355409:1055:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test head 2 defects log
00EB: Dr :354354:1055:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test head 3 defects log
00EC: Dr :353299:1055:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test head 4 defects log
00ED: Dr :352244:1055:Yes : Ok : Ok : 004C :1023-Q12:Factory Self Test head 5 defects log
1400: :378619: 17:Yes : Ok : Ok : 004C :NOT_INIT:
Zone allocation table
HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
MODULES DIRECTORY (01)
Location State
ABA:377654 Size:24 Ok
Modules number.......................... : 417
CONFIGURATION MODULE (02)
Location State
ABA:379576 Size:4 Ok
HDD Identify
Model................................... : WDC WD20EARS-22MVWB0
Serial number........................... : WD-WCAZA7398761.....
Logical parameters...................... : LBA : 3 907 029 167
Master-password
Set..................................... : No
User-password
Security level.......................... : High
Log DCM (C5)
Location State
ABA:46529 Size:405 Ok
Unknown DCM
Candidate (32)
Location State
ABA:4321 Size:32 Error
Defects number.......................... : 0
P-List (33)
Location State
ABA:10 Size:2560 Error
G-List (34)
Location State
ABA:4298 Size:23 Error
Hardware modules checking
Id : Copy 0 : Copy 1 : Desription
0035 : Err: BE : Err: 01 : SA Defects
0033 : Err: BE : Err: 01 : P-List (Primary defect list)
0031 : Err: BE : Err: 01 : Translator
000C : Err: BE : Err: 01 : Models table
0034 : Err: BE : Err: 01 : G-List (Grown defect list)
0032 : Err: BE : Err: 01 : Relo Bad Block Module
0036 : Err: BE : Err: 01 : T-List Module
0029 : Err: BE : Err: 01 : Loaded part of microprogram code
0040 : Err: BE : Err: 01 : Adaptive data
0041 : Err: BE : Err: 01 : Adaptive data
0042 : Err: BE : Err: 01 : Adaptive data
0043 : Err: BE : Err: 01 : Adaptive data
004E : Err: BE : Err: 01 : Loaded part of microprogram code
0049 : Err: BE : Err: 01 : Adaptive data
004A : Err: BE : Err: 01 : Adaptive data
004D : Err: BE : Err: 01 : Adaptive data
0003 : Err: BE : Err: 01 : Format Select Data Module
0025 : Err: BE : Err: 01 :
0026 : Err: BE : Err: 01 :
0038 : Err: BE : Err: 01 : Loaded part of microprogram code
0039 : Err: BE : Err: 01 : Loaded part of microprogram code
0037 : Err: BE : Err: 01 : Gain Call Data Module
002D : Err: BE : Err: 01 : Debug Log
002E : Err: BE : Err: 01 : Loaded part of microprogram code
00B5 : Err: BE : Err: 01 : WRRO Log Module
006B : Err: BE : Err: 01 : Loaded part of microprogram code
003A : Err: BE : Err: 01 :
0028 : Err: BE : Err: 01 : Factory Self Test script
003B : Err: BE : Err: 01 :
003C : Err: BE : Err: 01 :
003D : Err: BE : Err: 01 :
003E : Err: BE : Err: 01 :
003F : Err: BE : Err: 01 :
006F : Err: BE : Err: 01 : Loaded part of microprogram code
0116 : Err: BE : Err: 01 :
0118 : Err: BE : Err: 01 :
0119 : Err: BE : Err: 01 :
0068 : Err: BE : Err: 01 :
0069 : Err: BE : Err: 01 :
006A : Err: BE : Err: 01 :
0120 : Err: BE : Err: 01 :
012D : Err: BE : Err: 01 :
0004 : Err: BE : Err: 01 : Family models configuration (Main)
0005 : Err: BE : Err: 01 : Family models configuration (Alt1)
3700 : Err: BE : Err: 01 :
00DE : Err: BE : Err: 01 : Factory Self Test module
00B6 : Err: BE : Err: 01 : Factory Self Test module
00D5 : Err: BE : Err: 01 : Factory Self Test module
3411 : Err: BE : Err: 01 :
00D1 : Err: BE : Err: 01 :
00DB : Err: BE : Err: 01 : Factory Self Test module
00DF : Err: BE : Err: 01 : Factory Self Test module
00DD : Err: BE : Err: 01 : Factory Self Test module
3402 : Err: BE : Err: 01 :
00D7 : Err: BE : Err: 01 : Factory Self Test module
00D2 : Err: BE : Err: 01 : Factory Self Test module
3300 : Err: BE : Err: 01 :
3301 : Err: BE : Err: 01 :
3303 : Err: BE : Err: 01 :
3500 : Err: BE : Err: 01 :
00BB : Err: BE : Err: 01 : Factory Self Test module
3400 : Err: BE : Err: 01 :
3407 : Err: BE : Err: 01 :
3405 : Err: BE : Err: 01 :
00D9 : Err: BE : Err: 01 : Factory Self Test module
00D4 : Err: BE : Err: 01 : Factory Self Test module
00DC : Err: BE : Err: 01 : Factory Self Test module
00D0 : Err: BE : Err: 01 : Factory Self Test module
00D3 : Err: BE : Err: 01 : Factory Self Test module
00F7 : Err: BE : Err: 01 :
00BA : Err: BE : Err: 01 : Factory Self Test module
3406 : Err: BE : Err: 01 :
00B9 : Err: BE : Err: 01 : Factory Self Test module
00BC : Err: BE : Err: 01 : Factory Self Test module
3417 : Err: BE : Err: 01 :
00D8 : Err: BE : Err: 01 : Factory Self Test module
00BD : Err: BE : Err: 01 :
00BE : Err: BE : Err: 01 : Factory Self Test module
3401 : Err: BE : Err: 01 :
3302 : Err: BE : Err: 01 :
3304 : Err: BE : Err: 01 :
3501 : Err: BE : Err: 01 :
3502 : Err: BE : Err: 01 :
3416 : Err: BE : Err: 01 :
3F01 : Err: BE : Err: 01 :
00B8 : Err: BE : Err: 01 : Single Plug Test Communication Module
00BF : Err: BE : Err: 01 : Factory Self Test module
00E6 : Err: BE : Err: 01 : Factory Self Test log
00E7 : Err: BE : Err: 01 : Factory Self Test parameters module
34E7 : Err: BE : Err: 01 :
3801 : Err: BE : Err: 01 :
3415 : Err: BE : Err: 01 :
3418 : Err: BE : Err: 01 :
3423 : Err: BE : Err: 01 :
3422 : Err: BE : Err: 01 :
3421 : Err: BE : Err: 01 :
3F00 : Err: BE : Err: 01 :
1000 : Err: BE : Err: 01 :
00B1 : Err: BE : Err: 01 :
00B2 : Err: BE : Err: 01 :
1001 : Err: BE : Err: 01 :
1002 : Err: BE : Err: 01 :
1009 : Err: BE : Err: 01 :
100A : Err: BE : Err: 01 :
1003 : Err: BE : Err: 01 :
100C : Err: BE : Err: 01 :
1005 : Err: BE : Err: 01 :
1004 : Err: BE : Err: 01 :
1007 : Err: BE : Err: 01 :
100B : Err: BE : Err: 01 :
100D : Err: BE : Err: 01 :
100E : Err: BE : Err: 01 :
1008 : Err: BE : Err: 01 :
00C3 : Err: BE : Err: 01 :
00C8 : Err: BE : Err: 01 :
8010 : Err: BE : Err: 01 : Single Plug Test Log Module
802C : Err: BE : Err: 01 : Single Plug Test Log Module
8035 : Err: BE : Err: 01 : Single Plug Test Log Module
8038 : Err: BE : Err: 01 : Single Plug Test Log Module
803C : Err: BE : Err: 01 : Single Plug Test Log Module
8016 : Err: BE : Err: 01 : Single Plug Test Log Module
801D : Err: BE : Err: 01 : Single Plug Test Log Module
8044 : Err: BE : Err: 01 : Single Plug Test Log Module
8031 : Err: BE : Err: 01 : Single Plug Test Log Module
8062 : Err: BE : Err: 01 :
8063 : Err: BE : Err: 01 :
8041 : Err: BE : Err: 01 : Single Plug Test Log Module
8042 : Err: BE : Err: 01 : Single Plug Test Log Module
800E : Err: BE : Err: 01 : Single Plug Test Log Module
802D : Err: BE : Err: 01 : Single Plug Test Log Module
8019 : Err: BE : Err: 01 : Single Plug Test Log Module
802F : Err: BE : Err: 01 : Single Plug Test Log Module
8034 : Err: BE : Err: 01 : Single Plug Test Log Module
802E : Err: BE : Err: 01 : Single Plug Test Log Module
8032 : Err: BE : Err: 01 : Single Plug Test Log Module
8017 : Err: BE : Err: 01 : Single Plug Test Log Module
8002 : Err: BE : Err: 01 : Single Plug Test Log Module
800B : Err: BE : Err: 01 : Single Plug Test Log Module
8005 : Err: BE : Err: 01 : Single Plug Test Log Module
8020 : Err: BE : Err: 01 : Single Plug Test Log Module
8046 : Err: BE : Err: 01 : Single Plug Test Log Module
8045 : Err: BE : Err: 01 : Single Plug Test Log Module
8027 : Err: BE : Err: 01 : Single Plug Test Log Module
8014 : Err: BE : Err: 01 : Single Plug Test Log Module
801C : Err: BE : Err: 01 : Single Plug Test Log Module
8023 : Err: BE : Err: 01 : Single Plug Test Log Module
801F : Err: BE : Err: 01 : Single Plug Test Log Module
803A : Err: BE : Err: 01 : Single Plug Test Log Module
803E : Err: BE : Err: 01 : Single Plug Test Log Module
8012 : Err: BE : Err: 01 : Single Plug Test Log Module
8026 : Err: BE : Err: 01 : Single Plug Test Log Module
802B : Err: BE : Err: 01 : Single Plug Test Log Module
8029 : Err: BE : Err: 01 : Single Plug Test Log Module
802A : Err: BE : Err: 01 : Single Plug Test Log Module
8037 : Err: BE : Err: 01 : Single Plug Test Log Module
803B : Err: BE : Err: 01 : Single Plug Test Log Module
800F : Err: BE : Err: 01 : Single Plug Test Log Module
800A : Err: BE : Err: 01 : Single Plug Test Log Module
8025 : Err: BE : Err: 01 : Single Plug Test Log Module
8009 : Err: BE : Err: 01 : Single Plug Test Log Module
800C : Err: BE : Err: 01 : Single Plug Test Log Module
8006 : Err: BE : Err: 01 : Single Plug Test Log Module
8018 : Err: BE : Err: 01 : Single Plug Test Log Module
800D : Err: BE : Err: 01 : Single Plug Test Log Module
8008 : Err: BE : Err: 01 : Single Plug Test Log Module
8024 : Err: BE : Err: 01 : Single Plug Test Log Module
8015 : Err: BE : Err: 01 : Single Plug Test Log Module
8007 : Err: BE : Err: 01 : Single Plug Test Log Module
8065 : Err: BE : Err: 01 :
801A : Err: BE : Err: 01 : Single Plug Test Log Module
8030 : Err: BE : Err: 01 : Single Plug Test Log Module
801E : Err: BE : Err: 01 : Single Plug Test Log Module
8001 : Err: BE : Err: 01 : Single Plug Test Log Module
8022 : Err: BE : Err: 01 : Single Plug Test Log Module
8064 : Err: BE : Err: 01 :
8049 : Err: BE : Err: 01 : Single Plug Test Log Module
805D : Err: BE : Err: 01 :
805E : Err: BE : Err: 01 :
805F : Err: BE : Err: 01 :
8060 : Err: BE : Err: 01 :
8061 : Err: BE : Err: 01 :
8011 : Err: BE : Err: 01 : Single Plug Test Log Module
803F : Err: BE : Err: 01 : Single Plug Test Log Module
8040 : Err: BE : Err: 01 : Single Plug Test Log Module
8033 : Err: BE : Err: 01 : Single Plug Test Log Module
8043 : Err: BE : Err: 01 : Single Plug Test Log Module
8000 : Err: BE : Err: 01 : Single Plug Test Log Module
8021 : Err: BE : Err: 01 : Single Plug Test Log Module
8FFC : Err: BE : Err: 01 :
8FFD : Err: BE : Err: 01 :
8FFE : Err: BE : Err: 01 :
8047 : Err: BE : Err: 01 : Single Plug Test Log Module
8048 : Err: BE : Err: 01 : Single Plug Test Log Module
8004 : Err: BE : Err: 01 : Single Plug Test Log Module
8003 : Err: BE : Err: 01 : Single Plug Test Log Module
8028 : Err: BE : Err: 01 : Single Plug Test Log Module
8039 : Err: BE : Err: 01 : Single Plug Test Log Module
803D : Err: BE : Err: 01 : Single Plug Test Log Module
8036 : Err: BE : Err: 01 : Single Plug Test Log Module
801B : Err: BE : Err: 01 : Single Plug Test Log Module
8013 : Err: BE : Err: 01 : Single Plug Test Log Module
804C : Err: BE : Err: 01 : Single Plug Test Log Module
804D : Err: BE : Err: 01 : Single Plug Test Log Module
804E : Err: BE : Err: 01 : Single Plug Test Log Module
804F : Err: BE : Err: 01 : Single Plug Test Log Module
804A : Err: BE : Err: 01 : Single Plug Test Log Module
804B : Err: BE : Err: 01 : Single Plug Test Log Module
8050 : Err: BE : Err: 01 : Single Plug Test Log Module
8051 : Err: BE : Err: 01 : Single Plug Test Log Module
8052 : Err: BE : Err: 01 : Single Plug Test Log Module
8053 : Err: BE : Err: 01 : Single Plug Test Log Module
8054 : Err: BE : Err: 01 : Single Plug Test Log Module
8055 : Err: BE : Err: 01 : Single Plug Test Log Module
8056 : Err: BE : Err: 01 : Single Plug Test Log Module
8057 : Err: BE : Err: 01 : Single Plug Test Log Module
8058 : Err: BE : Err: 01 : Single Plug Test Log Module
8059 : Err: BE : Err: 01 : Single Plug Test Log Module
805A : Err: BE : Err: 01 : Single Plug Test Log Module
805B : Err: BE : Err: 01 : Single Plug Test Log Module
805C : Err: BE : Err: 01 :
8066 : Err: BE : Err: 01 :
8067 : Err: BE : Err: 01 :
8068 : Err: BE : Err: 01 :
8069 : Err: BE : Err: 01 :
806A : Err: BE : Err: 01 :
806B : Err: BE : Err: 01 :
806C : Err: BE : Err: 01 :
806D : Err: BE : Err: 01 :
806E : Err: BE : Err: 01 :
0091 : Err: BE : Err: 01 : Calibrations module
00AE : Err: BE : Err: 01 :
00C2 : Err: BE : Err: 01 : Calibrations module
00AA : Err: BE : Err: 01 :
00AC : Err: BE : Err: 01 :
2904 : Err: BE : Err: 01 :
00C4 : Err: BE : Err: 01 : Calibrations module
00A2 : Err: BE : Err: 01 :
00C5 : Err: BE : Err: 01 : Calibration script (DCM)
2900 : Err: BE : Err: 01 :
2901 : Err: BE : Err: 01 :
2903 : Err: BE : Err: 01 :
2F00 : Err: BE : Err: 01 :
2802 : Err: BE : Err: 01 :
2909 : Err: BE : Err: 01 :
290A : Err: BE : Err: 01 :
2A02 : Err: BE : Err: 01 :
1121 : Err: BE : Err: 01 :
1100 : Err: BE : Err: 01 :
150F : Err: BE : Err: 01 :
150E : Err: BE : Err: 01 :
150D : Err: BE : Err: 01 :
150C : Err: BE : Err: 01 :
1507 : Err: BE : Err: 01 :
1506 : Err: BE : Err: 01 :
1505 : Err: BE : Err: 01 :
1504 : Err: BE : Err: 01 :
1101 : Err: BE : Err: 01 :
1503 : Err: BE : Err: 01 :
1502 : Err: BE : Err: 01 :
1501 : Err: BE : Err: 01 :
1500 : Err: BE : Err: 01 :
80FE : Err: BE : Err: 01 :
806F : Err: BE : Err: 01 :
3604 : Err: BE : Err: 01 :
2077 : Err: BE : Err: 01 :
2076 : Err: BE : Err: 01 :
2075 : Err: BE : Err: 01 :
2074 : Err: BE : Err: 01 :
2073 : Err: BE : Err: 01 :
2072 : Err: BE : Err: 01 :
2071 : Err: BE : Err: 01 :
2070 : Err: BE : Err: 01 :
2067 : Err: BE : Err: 01 :
2066 : Err: BE : Err: 01 :
2065 : Err: BE : Err: 01 :
2064 : Err: BE : Err: 01 :
2063 : Err: BE : Err: 01 :
2062 : Err: BE : Err: 01 :
2061 : Err: BE : Err: 01 :
2060 : Err: BE : Err: 01 :
2057 : Err: BE : Err: 01 :
2056 : Err: BE : Err: 01 :
2055 : Err: BE : Err: 01 :
2054 : Err: BE : Err: 01 :
2053 : Err: BE : Err: 01 :
2052 : Err: BE : Err: 01 :
2051 : Err: BE : Err: 01 :
2050 : Err: BE : Err: 01 :
2047 : Err: BE : Err: 01 :
2046 : Err: BE : Err: 01 :
2045 : Err: BE : Err: 01 :
2044 : Err: BE : Err: 01 :
2043 : Err: BE : Err: 01 :
2042 : Err: BE : Err: 01 :
2041 : Err: BE : Err: 01 :
2040 : Err: BE : Err: 01 :
2017 : Err: BE : Err: 01 :
2016 : Err: BE : Err: 01 :
2015 : Err: BE : Err: 01 :
2014 : Err: BE : Err: 01 :
2013 : Err: BE : Err: 01 :
2012 : Err: BE : Err: 01 :
2011 : Err: BE : Err: 01 :
2010 : Err: BE : Err: 01 :
2037 : Err: BE : Err: 01 :
2036 : Err: BE : Err: 01 :
2035 : Err: BE : Err: 01 :
2034 : Err: BE : Err: 01 :
2033 : Err: BE : Err: 01 :
2032 : Err: BE : Err: 01 :
2031 : Err: BE : Err: 01 :
2030 : Err: BE : Err: 01 :
2027 : Err: BE : Err: 01 :
2026 : Err: BE : Err: 01 :
2025 : Err: BE : Err: 01 :
2024 : Err: BE : Err: 01 :
2023 : Err: BE : Err: 01 :
2022 : Err: BE : Err: 01 :
2021 : Err: BE : Err: 01 :
2020 : Err: BE : Err: 01 :
2007 : Err: BE : Err: 01 :
2006 : Err: BE : Err: 01 :
2005 : Err: BE : Err: 01 :
2004 : Err: BE : Err: 01 :
2003 : Err: BE : Err: 01 :
2002 : Err: BE : Err: 01 :
2001 : Err: BE : Err: 01 :
2000 : Err: BE : Err: 01 :
009A : Err: BE : Err: 01 :
00A0 : Err: BE : Err: 01 :
00A5 : Err: BE : Err: 01 :
00A9 : Err: BE : Err: 01 :
0097 : Err: BE : Err: 01 :
0096 : Err: BE : Err: 01 :
00C9 : Err: BE : Err: 01 :
00C6 : Err: BE : Err: 01 :
0093 : Err: BE : Err: 01 : Calibrations module
00CE : Err: BE : Err: 01 : Calibrations module
0098 : Err: BE : Err: 01 :
0128 : Err: BE : Err: 01 :
0121 : Err: BE : Err: 01 :
0094 : Err: BE : Err: 01 :
00CF : Err: BE : Err: 01 : Calibrations module
0099 : Err: BE : Err: 01 :
00AF : Err: BE : Err: 01 :
280A : Err: BE : Err: 01 :
00CA : Err: BE : Err: 01 : Calibrations module
3C00 : Err: BE : Err: 01 :
00FA : Err: BE : Err: 01 : Butterfly Log
00C1 : Err: BE : Err: 01 : Calibrations module
00EE : Err: BE : Err: 01 : RRO Data Log
00B7 : Err: BE : Err: 01 : Test Clamp Data
009C : Err: BE : Err: 01 :
00CC : Err: BE : Err: 01 : Calibrations module
00C7 : Err: BE : Err: 01 : Calibrations module
00FC : Err: BE : Err: 01 : Factory Self Test module
0011 : Err: BE : Err: 01 : Loaded part of microprogram code
0001 : Err: BE : Err: 01 : Modules directory
009E : Err: BE : Err: 01 : Calibrations module
00FD : Err: BE : Err: 01 : Factory Self Test module
3E00 : Err: BE : Err: 01 :
005C : Err: BE : Err: 01 :
0122 : Err: BE : Err: 01 :
006D : Err: BE : Err: 01 :
4002 : Err: BE : Err: 01 :
AC55 : Err: BE : Err: 01 :
006E : Err: BE : Err: 01 : Loaded part of microprogram code
001F : Err: BE : Err: 01 : Loaded part of microprogram code
0062 : Err: BE : Err: 01 :
0061 : Err: BE : Err: 01 : Loaded part of microprogram code
0115 : Err: BE : Err: 01 :
0053 : Err: BE : Err: 01 : Parameters table 4
0052 : Err: BE : Err: 01 : Parameters table 3
0051 : Err: BE : Err: 01 : Parameters table 2
0050 : Err: BE : Err: 01 : Parameters table 1
0012 : Err: BE : Err: 01 : Loaded part of microprogram code
0019 : Err: BE : Err: 01 : Loaded part of microprogram code
0024 : Err: BE : Err: 01 : S.M.A.R.T. Log (reserved)
0023 : Err: BE : Err: 01 : S.M.A.R.T. Log (reserved)
0021 : Err: BE : Err: 01 : S.M.A.R.T.
002A : Err: BE : Err: 01 : Loaded part of microprogram code
002F : Err: BE : Err: 01 : Loaded part of microprogram code
001E : Err: BE : Err: 01 : Loaded part of microprogram code
0015 : Err: BE : Err: 01 : Loaded part of microprogram code
0014 : Err: BE : Err: 01 : Loaded part of microprogram code
001C : Err: BE : Err: 01 : Loaded part of microprogram code
0017 : Err: BE : Err: 01 : Loaded part of microprogram code
0002 : Err: BE : Err: 01 : Configuration (HDD ID)
0109 : Err: BE : Err: 01 : ROM image
0108 : Err: BE : Err: 01 : IBI packet
0106 : Err: BE : Err: 01 : ROM module image
0105 : Err: BE : Err: 01 : ROM translator SA images
0104 : Err: BE : Err: 01 : Microprogram version image
0103 : Err: BE : Err: 01 : ROM adaptives SA images
0102 : Err: BE : Err: 01 : Heads map module image
0110 : Err: BE : Err: 01 : Modules directory (base part)
00AD : Err: BE : Err: 01 :
1430 : Err: BE : Err: 01 :
00E0 : Err: BE : Err: 01 : Factory Self Test defects log
00E1 : Err: BE : Err: 01 : Factory Self Test defects log
00E2 : Err: BE : Err: 01 : Factory Self Test defects log
00E3 : Err: BE : Err: 01 : Factory Self Test defects log
00E4 : Err: BE : Err: 01 : Factory Self Test defects log
00E5 : Err: BE : Err: 01 : Factory Self Test defects log
00FE : Err: BE : Err: 01 : Factory Self Test module
120F : Err: BE : Err: 01 :
1213 : Err: BE : Err: 01 :
2906 : Err: BE : Err: 01 :
2908 : Err: BE : Err: 01 :
121F : Err: BE : Err: 01 :
00E8 : Err: BE : Err: 01 : Factory Self Test head 0 defects log
00E9 : Err: BE : Err: 01 : Factory Self Test head 1 defects log
00EA : Err: BE : Err: 01 : Factory Self Test head 2 defects log
00EB : Err: BE : Err: 01 : Factory Self Test head 3 defects log
00EC : Err: BE : Err: 01 : Factory Self Test head 4 defects log
00ED : Err: BE : Err: 01 : Factory Self Test head 5 defects log
1400 : Err: BE : Err: 01 :
01 : Module has invalid header
02 : Data error reading module
03 : Servo error reading module
04 : Wrong / Incompatible module
05 : The two copies do not match / Checksums Different
06 : Invalid checksum
07 : Module state reading error
PostPosted: April 24th, 2013, 9:38
Why this?
Heads number............................ : 6
Heads number in use..................... : 5
Switched off heads...................... : Yes
Heads map............................... : 0,2,5,6,7
Data Recovery Cape Town
PostPosted: April 24th, 2013, 9:41
this is head confuguration without touchig nothing in SA
but what you think if i put heads map 012345 to see what happens?
PostPosted: April 24th, 2013, 9:43
but i put heads map 012345 to see what happens
Why are you changing it to 012345? Map on these is normally 012567
You need to save adaptives off and adapt a donor for hotswap. Is easiest and quickest soluition, but maybe you should double check head map, for 2TB there are no heads deactivated as far as I remember?
PostPosted: April 24th, 2013, 9:52
Agree, not that I've seen on an EARS anyway.
PostPosted: April 24th, 2013, 10:41
any body can confirm me head map on WD 2GB?
Model: WDC WD20EARS-22MVWB0 - Sadle G6
Thanks guys.
PostPosted: April 24th, 2013, 10:49
From a WD20EARS-00MVWB0:
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1980
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 50.7JB
>ROM generation.......................... : 50.7JB
>Link table version...................... : 0B.21.
>Consolidated ROM version................ : 0050007J
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 6
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,5,6,7
>ROM Firmware version.................... : 0050007J
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
PostPosted: April 24th, 2013, 12:53
Thanks labtech for your help
PostPosted: April 26th, 2013, 11:52
anybody have this FW version?
ROM Firmware version.................... : 00220000
LOG FROM PC3K
RAM:
Heads number............................ : 5
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM version............................. : 22.00E
ROM generation.......................... : 22.00E
Link table version...................... : 0B.36.
Consolidated ROM version................ : 00220000
ROM Modules:
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 377 654 (24)
Service area:
SA dir reading.......................... : Ok
SA Access............................... : NONE
Configuration reading................... : No SA copy avalabled
Users browsing this forum: Google [Bot] and 205 guests
