 Post subject: SAMSUNG HD253GJ
PostPosted: April 24th, 2013, 13:27
Hi all I'm trying to fix this hdd that i had on a computer and now is not working, the problem that I'm having is that when i power on the drive it clicks 2 times then it shuts down and that's the end of it, this error could be head, SA, FW issue or a physical error, what i want to know is witch pins are the Tx, Rx and ground of this drive cause i want to try something out.
I was searching for a service manual for this hdd and nothing regarding this type of drive. Any help would be great, i know the DIY problems that can occur but i don't care if the data is lost i just want to get this hdd working.
SAMSUNG : HD253GJ
HDD P/N : HD253GJ/D
SATA
250 GB
RPM 7200
FW : 1AJ0001
Data Recovery in the Dominican Republic
https://www.recuperamidata.com/
 Post subject: Re: SAMSUNG HD253GJ
PostPosted: April 25th, 2013, 6:10
Have you got Term log?.
Here que can take a look, to know what is the problem in your HDD.
Users browsing this forum: Google [Bot] and 324 guests
