 Post subject: ST31000528AS donor weirdness
PostPosted: April 30th, 2013, 13:19
ONE of the the heads in my clients drive started reading extremely slowly; obviously i order a donor to replace the heads stack (after i made a copy of the data on 3 working out of 4 heads). The donor is incompatible (drive never gets recognized, just clicks), I cant figure out why... It doesnt say its refurbished and everything that has to match, matched. I put the donor heads back and it works fine and as well the original drive.
Just wondering anyone else experienced this before, I ordered and replaced heads on these 100's of times without an issue.
 Post subject: Re: ST31000528AS donor weirdness
PostPosted: April 30th, 2013, 14:23
Have you looked at the heads really close?
PostPosted: April 30th, 2013, 14:59
what do you mean really close? the head stack is identical, aside from the fact that it doesnt work :-\
PostPosted: April 30th, 2013, 16:36
According to my experience and matching criteria, that donor doesn't look compatible for heads.
Or maybe I'm being too picky :-)
PostPosted: April 30th, 2013, 17:36
Im my experience just certain numbers of the S/N have to match to make it work. Had 99.5% percent success doing it that way over 8 years. This is the first time it doesnt match; anyways, guess I'll have to order another donor and see what happens. Thanks anyways.
Users browsing this forum: Google [Bot], Lukas, Majestic-12 [Bot] and 187 guests
