 Post subject: My Laptop HDD (seagate)fall
PostPosted: May 3rd, 2013, 4:44
My Laptop HHD Seagate Momentus 5400.6 (320 GB) fall down and stop working and when try to connect it through USB to other laptop , it give a peep sound for some time and stop and didnot be accessible. i dont want it to be repaired. just i need to take off the data as it is very important :(:(
 Post subject: Re: My Laptop HDD (seagate)fall
PostPosted: May 3rd, 2013, 4:46
Then take it to a professional data recovery place.
NOTHING you can do DIY, it's a physical internal problem.
PostPosted: May 3rd, 2013, 9:09
yes, the drive was powered on when it fell :(
PostPosted: May 3rd, 2013, 9:27
Stiction, and most likely head damage. Heads in those drives fail very easily.
PostPosted: May 4th, 2013, 15:46
Yep, Seagate Momentus drives are delicate, one tap and they go funny, more than likely the heads are buggered on it. I would not power it up anymore, take it to a Pro to get data recovered. Anything you do now will only damage it further.
PostPosted: May 6th, 2013, 6:49
heads damage, sticion or platters damage. If your data is important contact with local pro
in case off heads damage or sticion a pro will be able to get your data
but, in case off platters damageno way to get your data.
Users browsing this forum: Bing [Bot] and 266 guests
